Author Topic: Posting Photos  (Read 31283 times)
Offline DanG
Posting Photos
« on: May 28, 2005, 09:30:15 AM »
THIS TUTORIAL HAS BEEN REPLACED WITH AN UPDATED TUTORIAL FOUND HERE
Note from Forestry Forum Administration
The Forestry Forum no longer allows linking to photos on other web sites.
Photos used on the Forestry Forum must reside on the Forestry Forum Servers.
Photos used on this Forum may only be used with permission of the photo's owner,
unless it already resides in the Forestry Forum Gallery.
Please use this tutorial to learn how to place your photos within your gallery.
-explanation of creation of an album in your gallery-
https://forestryforum.com/board/index.php?topic=12936.msg180416#msg180416
Photos uploaded to the Forestry Forum that are used within a post must not
ever be deleted!
Here's how to post your pics.  If I make any boo-boos, you admins feel free to make corrections. :)
First you need to resize and compress your pic.  I use the image optimizer found at  www.xat.com .  They have a 30 day free trial, but the program remains in your puter and is usable after that.  Tips on using it:
Cropping your image will greatly reduce the image size.(number of pixels)  Crop as close as you can without losing the integrity of the subject. This way, you won't have to reduce quality so much and will post a clearer pic.
Close and re-open your pic after each step.  It makes it easier.  If you don't, you'll be working with an image smaller than a postage stamp. ::) :D
Resize your image next.  I'm still using limits of 350x350 pixels. Jeff can tell us if that has been liberalized, but it seems to give me a nice sized image.
Compress the image by reducing image quality.  You shouldn't have to reduce it much if you have cropped well.  Here again, I'm still using the old limit of 20kb, but the limit may be higher now.
When saving your image to your puter, only use hyphens or dashes for spaces and never ever use !@#$%^&*()+":;?
As they are all illegal naming characters.
You should now have a postable image in your folder. (in your computer)  You're finished with the image optimizer now, and are ready to upload the image into your gallery.
Assuming you've already started the post you want to add a photo to,  click on "Additional options" below the box you're typing in. (You can also go directly to your gallery before beginning your post.)   This will take you to the Forum Gallery, so you have to click "My Gallery" to get into your own collection.  Once there, click on "Upload Image".  Here you will see five Browse buttons. Poke one of them and it will take you back to your folders where you click the image that you already optimized. Click the "Open" button, then you'll have to hit "Continue" a few times until it takes you back to the Forum Gallery.  A thumbnail of your image should be there among the new images, or you can return to your own gallery and see the same thumbnail pic.
Now here is where most people seem to get lost, so LISTEN UP! ;)  Double click that thumbnail and you'll get the real photo.  Just below and to the left of it, you'll see "Copy Image Code" and when you poke that it will highlight the image code below the pic.  You're done with the gallery at this point.
All that's left is to return to your post, position the cursor where you want the pic, click Edit, then Paste, and the image code will appear in your post.  When you post it to the Forum, the photo will be there.  You won't see the photo while you're typing, just the image code.
I hope this helps some of you.  We really like to see pics of you and your stuff. ;D
Offline tnlogger
Re: Posting Photos
« Reply #1 on: May 28, 2005, 11:36:00 AM »
DanG thanks for doing this 8) I was thinking about it and just way too lazy to get it done. :D
gene
Offline Buzz-sawyer
  • To see it is to saw it....
Re: Posting Photos
« Reply #2 on: May 28, 2005, 12:53:32 PM »
GOOD SHOW DANG I AM ADDING SOME PICS TO YOUR FINE EXPLAINATION.......IT TAKES A WHILE TO GET THIS DONE SO ITS WORK IN PROGRESS RIGHT NOW we can further refine our text and pics to make this fool proof????
When you start a post this box will appear ,  click on "Additional options" below the box you're typing in.
Then click on ,"Click here for member photo gallery"
Next look to the upper right for ,"Upload file" click it
 This will take you to the Forum Gallery,  "Upload Image".  Here you will see five Browse buttons. Poke one of them and it will take you back to your computer where you stored the image that you already optimized.
Now here is where most people seem to get lost, so LISTEN UP!   Double click that thumbnail and you'll get the real photo.  Just below and to the left of it, you'll see "Copy Image Code" and when you poke that it will highlight the image code below the pic.  You're done with the gallery at this point.
    HEAR THAT BLADE SING!
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Creating a new album in your gallery
« Reply #3 on: June 29, 2005, 07:05:24 AM »
Before uploading photos to your gallery, you must first have an album to put them in. Once you create an album, you are ready to upload. Go up and click the "image Archive" button to get started. This opens a window with your Gallery page in it.
If you have never created an album look for this:
Click on the Create / order my albums and you will see this:
Click the "New" button, you will then see text that says "New Album". Edit that text in the lower box such as I did in this example. Mine says "Jeff's sawmill photos".
Then click "Apply modifications".
You have now created an album and have a place to upload photos to. Now just look for the "Upload file" link
Offline Bibbyman
    • Warden Sawmill
Re: Posting Photos
« Reply #4 on: June 30, 2005, 09:25:38 AM »
Jeff,  now that I've got some pictures in my gallery,  I'd like to better orginize them by making some new albums and moving pictures from the main one I got to another.
Is that possable?   ::)
Will the posts where they're shown now not have the pictures linked?
Sawing since '94
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Posting Photos
« Reply #5 on: June 30, 2005, 02:52:27 PM »
No, it is not possible.  If you do, you will break all the links to your photos.  I had a member delete his entire album last month and cause broken links throughout the forum. Luckily he had backup on his computer, and after me jumping him, he spen a whole bunch of time, which I appreciate, restoring things.  In the thread about the gallery, I say that I wont stand for people deleting photos. Once you use them, they are there.  My alternative for this software is to set it so I have to approve each action. I DONT want to do that.
I suggest you start being neat from this point on. :)
Offline Bibbyman
    • Warden Sawmill
Re: Posting Photos
« Reply #6 on: June 30, 2005, 05:25:57 PM »
You say that like you never change anything..   ::)
Sawing since '94
Offline SwampDonkey
  • Large Tooth
Re: Posting Photos
« Reply #7 on: July 03, 2005, 06:45:20 AM »
Bib, if you make additional albums you can place a picture from an existing album into the new one without breaking links.
Go into My Albums, click edit files and you'll see a drop down lister with your album names and you can change what album that file resides in. I've done it and it doesn't break the link because the url doesn't include the album name, just the user's ID number.
No amount of belief makes something a fact. James Randi
Offline JP
Re: Posting Photos
« Reply #8 on: November 03, 2005, 06:14:51 PM »
Ok i can post 1 picture into my post but im having trouble with the 2ed ,3rd one---JP
Norwood lm2000,Newholland 30 hp tractor, log carrier/winch, log arch  JP
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Posting Photos
« Reply #9 on: November 03, 2005, 06:27:16 PM »
JP,  simply go back to your gallery and select the code for the next picture, then come back to your post and paste the code in where you want the photo to appear.  You can do this as many times as you can stand it. :D   Holler back if I mixed you up.
Offline ohsoloco
  • Can we stay outside and play in the sawdust?
Re: Posting Photos
« Reply #10 on: November 05, 2005, 02:35:07 PM »
I was trying to optimize some pictures just now, and I can't figure out how to rotate pictures using xat.  I can't see why it wouldn't let you do that.  Does anyone know how it's done  ???
Re: Posting Photos
« Reply #11 on: November 05, 2005, 02:54:35 PM »
It's not available on the "free" version.
What I do is use one of the photo programs like Adobe or PictureIt or HP Photosmart  or something like that.  I do all of my picture adjustments of contrast, lightening, darkening, cropping turning, retouching and all that with my favorite photo program.
Then I save that copy of the changed photo to a folder of stuff that I want to optimize.  I even rename it.
Then I load xat and optimize that picture for putting on the forum or for emailing or whatever.
That way I still have the original saved in it's little folder and I can find the optimized ones if I need them later.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: Posting Photos
« Reply #12 on: November 05, 2005, 11:45:11 PM »
You can also crop and rotate after you've loaded them to your FF album.  Click on the pic to open it and under it is a crop and rotate button that opens the photo editor
Offline ohsoloco
Re: Posting Photos
« Reply #13 on: November 06, 2005, 07:24:45 PM »
Corley5, that worked like a charm, thanks  ;D
Offline Corley5
    • Whittaker Farms
Re: Posting Photos
« Reply #14 on: November 06, 2005, 07:27:01 PM »
 8) 8)  Anytime :)
Offline davemartin88
Re: Posting Photos
« Reply #15 on: December 03, 2005, 06:56:41 AM »
Was able to get one picture to post but getting a message saying my "pixel allowance" is exceeded. The file was compressed on only 14K with xat as suggested but looks like something else is coming in to play.
Offline SwampDonkey
  • Large Tooth
Re: Posting Photos
« Reply #16 on: December 03, 2005, 07:43:10 AM »
It must have exceded 350 pixels wide or tall. Shrink it a bit to less than 350 pixels. ;)
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Posting Photos
« Reply #17 on: December 03, 2005, 09:02:56 AM »
Actually 400 or less is the limit but 400 is hard to crunch the file size. 350 seems about perfect so is the recommendation.
Offline highpockets
  • I'm old
    • our page
Re: Posting Photos
« Reply #18 on: January 20, 2006, 06:02:23 AM »
Louisiana Country boy
homemade mill, 20 h.p. Honda & 4 h.p. for hydraulics.  8 hydraulic circuits, loads, clamps, rotates, etc.
Offline highpockets
  • I'm old
    • our page
Re: Posting Photos
« Reply #19 on: January 20, 2006, 06:06:06 AM »
posting photos
Started by Maine logger88 on Forestry and Logging
Last post November 18, 2013, 08:21:58 PM
by Maine logger88
Posting photos
Started by rhead on General Board
Last post September 22, 2015, 09:12:37 PM
by POSTON WIDEHEAD
Posting Photos
Started by ironmule2004 on Technical Support Topics
Last post January 30, 2006, 11:35:20 PM
by Shotgun
POSTING PHOTOS
Started by KDEC19 on General Board
Last post March 14, 2004, 07:45:25 AM
by etat
