Garden build 2025
Started by DDW_OR, February 26, 2024, 04:46:15 PM
DDW_OR
Will be starting a garden in 2025
What crops. Bushes. Fruit trees. Fruit vines.
Montana zone 6a. 5a. 5b
What would you recommend
All suggestions welcome
Also building a 12x32 twin wall polycarbonate greenhouse
Use sawmill for 2x6's
Then build frame
Then stain with airless sprayer
Then put twin wall on
We have grown peach trees. Ugly looking but VERY TASTY.!!!!!!!!!
Where killed over 30 years ago in February after 2 weeks of warm weather that got the trees to start budding.
Still remember the taste.
Have not tasted the same since.
Also killed the cherry trees around Flathead Lake
Will plant the trees along the property line
Then bird netting when fruit is growing
Berry bushes between trees
rusticretreater
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
twar
When I was at the U in Missoula, a neighbor had an impressive apricot tree. I remember her giving away apricots to any one who would take them.
DDW_OR
Watched a couple videos on greenhouses buried 2 to 5 feet into the ground
Then adding geothermal heat loops 8 feet underground. 70 to 100 feet long. Ground temperatures that deep are near constant 40 to 50 degrees. In most of the videos they are growing oranges
DDW_OR
found this useful site for when the sun will be directly overhead
https://www.suncalc.org/#/48.368,-114.1725,16/2024.03.06/12:47/1/3
then use your shadow and two stakes to mark your shadow
then orientate the build to that
will still use the Outdoor Wood Furnace, OWF, to heat the soil in the ground.
and may add the geothermal heating
part of the Geothermal loop will use the OWF trench to re-gain some of the heat lost
DDW_OR
Plan to build it like a Polebarn
I got several cardboard tubes used for shipping chimney pipe sections. About 3 ft long
Frost is 5 ft. So 2 tubes per post
Then the metal bracket into the wet cement. Then the 4x6 post on the bracket
6x6 on the four corners
Build it once. Use it for 50 years
Will see how the twin wall polycarbonate holds heat in the winter
May add a 1x2 spacer then a second sheet on the outside
Southside
I bought orders of lady bugs and added them to our 300 sf experimental greenhouse this winter, basically zero aphids now on kale leaves that are in contact with the ground and those were definitely the ones harboring the most in the beginning.
Plan now is to have a 30'x100' in place for late summer and I definitely will run tubing under the raised beds to tie into the OWB.  May just grow greens / cool season in it over the winter as those have done really well for me this winter then use it to get a jump on field transplant starts.  Around here it's just too hot come summer to have anything in there so thinking I will toss some really long season soybeans in there mixed with sorghum as a cover crop / nitrogen fixation / green manure.  Till it all in come September and plant cool season crops.
White Oak Meadows
DDW_OR
and i will make all of my raised beds the same.
in late fall i will move the coldframe into the greenhouse. one more frost protection layer
DDW_OR
the house, greenhouse, and OWF trenches will form an almost equilateral triangle that will be used to put three empty, ADS 4-in x 100-ft Corrugated Solid Pipe
about a total of 250 feet of trenches
two fans in the greenhouse, one pushing into the pipes and the other pulling from the other end
the trench from OWF to house is too shallow, 2 feet, it will melt the snow on the ground.
and a good friend is giving me a lot of 4 ft chain-link fence. about 900 feet with concrete posts and most of the pipe. my fence line is 550 ft. never worked with chain-link.
DDW_OR
Took a screen shot of my Property. then outlined each building in yellow. then removed everything else
trenches with water will be about 8 feet deep
trenches T1 and T2 will have the following
a heat loop from the OWF.
four air pipes around the OWF line
electrical
an empty 1 1/2 inch black HDPE pipe
Trench T3 will have
four air pipes
electrical
a  1 1/2 inch black HDPE pipe with a one inch PEX pipe inside for water
so the air pipe flow is 300 feet long
Greenhouse to T3 to T1 to T2 to Greenhouse
Trench T4, 5 ft deep
electrical
Trench T5, 2 feet deep
electrical
DDW_OR
The greenhouse pit
Dig the inside down about 4 feet
Line pit walls and bottom with foam board
Add a foot of dirt
Then pex pipe loop
Then fill with three feet of dirt
OWF water temp is 180 to 190 degrees
Do not want to cook the roots.
Have temperature probe in dirt
Pex pipe pump turns on at soil temp 40 degrees
Turns off at 50 degrees
Interesting!!!
I have a root cellar on one side of my basement, It's under the sunroom. Maybe 12 by 16 feet. The floor is lined with stones. It's about 6 feet under ground, with 2 feet of exposed concrete. I kept track one winter. When it was in the singles numbers seem like it got down to 46° then it would go up to 50 with higher temps. I only checked it one year. Just the sides and ceiling has 2 inch foam board.
DDW_OR
Just had a thought.
55 gallon open top barrow
copper loop from OWF to heat water inside barrow
then a second copper loop to the pit PEX loop.
nope, too complicated.
so OWF ThermoPex has two Pex lines inside, Send and Return
DDW_OR
Also was told about foam foundation blocks
Two birds with one stone
Would not need the tubes
DDW_OR
Will not do the foam foundation blocks
Too much $$$
DDW_OR
where do you get sprinkler system parts
besides Home Depot, Lowe's, Ace, true Value, Facebook, and Ebay
DDW_OR
Here is a good vid of how I plan to build my raised beds
Mine will be 5x10 and 36 high I have lots of 3x10 white metal roofing
May coat the inside with something to reduce rust
https://m.youtube.com/watch?v=fThviH71CaI&pp=ygUWRGl5IG1ldGFsIHJhaXNlZCBiZWRzIA%3D%3D
reride82
Check out Bob Quinn out of Big Sandy, MT. He built an underground greenhouse that uses geothermal to heat it. He's been growing citrus, peaches, apples, cherries, etc in a much worse climate than the Flathead  ffcheesy He has pioneered many organic and homestead ideas in the past, and he's a great guy to boot!
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
DDW_OR
DDW_OR
The triple wall polycarbonate was delivered
November 6 two trees will be dropped
Will be clearing and flattening the greenhouse location
Have other properties before the snow comes
DDW_OR
The garden slopes from North to South
the Garden Tool Room will have no Polycarbonate
it will be insulated and be kept at 40 deg during the winter
 this is the future layout plan for the 1.5 acers
the yellow round is fruit trees
the long orange lines are berry bushes on the inside of the chain link fence
red lines are property lines
Pink lines are irrigation
the yellow rectangles are the different trailers we have. will be selling some
Multitek is a firewood processor
Timberking is a sawmill
will be a total of 9 to 10 gates
some locations will have a double gate, 12+12
will use the Bobcat E80 excavator to remove the top foot of yard soil\rock, then use a vibrating screen to sift the larger stuff.
then mix topsoil with the small stuff and add to the yard.
land is on top of a Glacier till rock pile. can leave the water hose run all week with out a puddle
DDW_OR
did the price of buying each individual part, and compared it to the 57253, 3 valve system.
will be using the Orbit Manifold 57253 cheaper and should be more reliable.
during this winter i am drawing many plans
watering
electrical
Cameras
i found on Craigslist a red 2,500 ft 1.25 inch roll of PEX for under $800
will be running a PEX 1.25 inch line from the house to the Greenhouse ( GH ) .
lines to the raised beds, fence growing, and fruit trees will all be 3/4 inch PEX-B Blue. and designing it so i can hook up an air compressor to winterize the lines outside the GH.
the lines inside the GH will be run down the center then to the wall raised beds
the camera POE Ethernet cable will be inside a White 3/4 Pex pipe, or the red 1.25 PEX
will add an empty 1.25 in each trench for the future, if i get the big roll
will be converting the 2 car garage into a work shop and adding heat from the OWF.
