Need some ID help
Started by archeryplus, March 26, 2024, 09:18:05 AM
archeryplus
Could use some guidence on this one .
Elm??
Thanks for your help.
RR
Need a much better pic to identify, as well as a sharp knife prepping the end grain. Can you help with that?
archeryplus
I have the pics in the gallery but havent figured out the way to post them better yet.
Will work on that tonight and thanks for the response.
archeryplus
see if this is better
1000017336
1000017337
1000017335
Make a clean cut across the end grain with a sharp knife or a sharp chisel. The look for the wavy lines between the annual rings.
Compare to the images in this link
archeryplus
Thank you I will dothat first thing in the morning
doc henderson
no ones' pics will be as good as in that pic.  you can get a foreign made microscope that uses your phone and get pretty good pic or sharply shaved end grain.  not sure how much they are now (was cheap), but if you will have several of these questions over time, it might be a good investment.  It almost looks like maple with some heart wood.
Also a clean cut with a good saw blade and scanned on printer/scanner makes for a good pic. Here of a crosscut on piece of oak.
7/8" x 3-3/4"
Swampdonkey showed me this trick a few years back. This would show quickly if ash or maple. Phone image should work as well.
The scope Doc mentioned would be a better way, as well as a 10x hand lens.
This is some elm pictures.
board surface
end grain
archeryplus
Thanks for all the advice, I will cut and take a good look today,  maple is a possibilty, I never thought of that.
Don P
A scanner is my hand lens. I have more uses for a scanner day to day although a scope would be nice. This is the scanner zoomed in on some red oak end grain.
doc henderson
Don, how do you then get a digital pic to put on here?  do you just scan it to the computer??  that looks good
Absolutely, a magnifier phone app is the handiest tool, plus you can add it to your photo album.
EDIT photos of my pants leg added:
Don P
Doc, it is just a thin slice on my flatbed office scanner, saved as a jpg and reduced/cropped, whatever it takes to get the detail/ size to work out for whatever I'm looking at.
I don't know how you all keep those phones intact. The pup ate my 10 year old little pocket camera... which I thought was pretty "hardened". My wife gave me her old smart phone for the camera. I proceeded to turn that into a brick within a month  ffcheesy.
doc henderson
nice ideas and it may lend itself to increase quality and ability to ID wood.  might make a good thread/tutorial on its own.
A scanner effectively zooms when taking high res images. Just crop out enough to see and not end up with a 20 meg photo.  :thumbsup:
archeryplus
Didnt get the best magnified poic yet but does this help anyone for ID
Don P
You're looking at a ring porous wood. It has very distinct medullary rays. Look at beenthere's pic again.
doc henderson
I think it looks a little like magic Mans jeans?   :uhoh:   ffsmiley
Looks like an oak wouldn't you say?  :thumbsup: There's many species of oak, but they are separated into red or white oak. This looks like a red oak species.
archeryplus
Thanks for all the advice.  I did think it looked like beentheres pic when I compared them.
I also have the magnifier app Magicman suggested.
I have worked up a dozen good sized red oak and just never came across a look like this.
red oak vs white oak, you can blow through the pores of most red oak. Not white oak.
Judging by the bark picture and your most excellent magnifier picture, I would lean heavily toward one of the Red Oaks.
61.
Southside
Quote from: Don P on March 27, 2024, 09:05:23 AMI don't know how you all keep those phones intact. The pup ate my 10 year old little pocket camera... which I thought was pretty "hardened". My wife gave me her old smart phone for the camera. I proceeded to turn that into a brick within a month
Don - I have a Kyocera Duraforce Pro II phone, have had two or three of them in a row now.  Without a case it's mil spec waterproof, shock proof, and big enough that my fat thumbs don't have a hard time hitting three buttons at the same time.  CAT makes a similar phone.  Some say they aren't the fastest but for what I do it has never been an issue at all and the thing is tough as nails.  The first two basically wore out over the years, the first test I had with the first one I was climbing out of a skidder and the phone fell into a mud puddle.  Instead of saying some mighty bad words I just picked up the phone and walked over to a non muddy puddle to rinse it off.  Now THAT was a good feeling.
White Oak Meadows
archeryplus
Added a picture with the magnifier app
