Slab wood processor
Started by Percy, August 04, 2024, 01:45:55 AM
Percy
Here is vid of the slab cutting machine I been working on for the last couple of months. Perhaps this should be in the firewood section but I thought it might bd appropriate here as dealing with slabs is a universal problem.
Regardless this is the first take of the first time we fired this puppy up.
https://youtube.com/shorts/z3-ZPz3jWbY?feature=shared
I've seen a local version that worked on the same idea. It was powered by a decent size farm tractor, and dropped the wood onto a small elevator belt that loaded it into his dump truck. He figured that even if a log was 100% rejects, he broke even selling it for firewood, as it was all processed and in the dump truck with no extra handling.
Peter Drouin
what are you doing with the wood after it's cut?
A&P saw Mill LLC.
License NH softwood grader.
doc henderson
Wow.  it does work great and seems to be a one off.  Are there machines that inspired you?  It has a Dudley-do-right flare if anyone remembers that cartoon.  :thumbsup: It is hard to tell the circ blade rpm in the video.  Any idea what it is?  looks like the blade is direct drive, how about the conveyor.  Very cool. mustache-smiley ffsmiley
doc henderson
scsmith42
I like it!
Tom's 3638D Baker band mill
barbender
Bruno of NH
Very nice
I would like something like that
SawyerTed
That's great!  Slab processing is such a headache sometimes!  This solves much of that.
Keep us posted on how it performs over time.
jpassardi
Yeah, nice work Percy. Dealing with slabs is a necessary evil and anything you can do to automate will benefit long term.
Impressive invention.
Suspect you already have some upgrades in mind to make it even better.
doc henderson
Nice pendulum design.  Looks like a counterweight to help the movement when needed to go through the wood.?
Nebraska
Me thinks that it came from a medieval torture chamber.  :wacky:
barbender
Alright, Percy! Get back here and visit about your creation!😂 You've left us hanging here🤷😊
Percy
Quote from: barbender on August 04, 2024, 05:39:48 PMAlright, Percy! Get back here and visit about your creation!😂 You've left us hanging here🤷😊
Wow. Great response. I will go into it in detail soon. I still have a component I need to add( a couple of hold down wheels to keep the short pieces from teetering over and not activating the trigger switch making for a too long piece of firewood. Plan to sell the slab firewood same price as my son. He sells for 100.00 a pickup load( u load). He had a commercial machine that does what mine does   It's where I got a lot of my ideas 😁
barbender
They say that imitation is the sincerest form of flattery, or so I'm told😊
Andries
I try really hard to be just like barbender.
Nice work Percy!
I bet that slab wood will be flying out of the logyard.
LT40G25
Ford 545D loader
Stihl chainsaws
rusticretreater
Awesome and scary at the same time.  Methinks a safety shield on each side is absolutely positively needed.  But yeah, I need one.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
customsawyer
Looks great. Anything that you can do to reduce or replace manual labor is a plus. Kind of like taking steps to save steps or something like that.
www.thecustomsawyer.com
Cedarman
I looked at that pendulum swinging and thought of the old movie with Vincent Price "The Pit and the Pendulum".  Old time horror flick.
mudfarmer
That is a cool contraption :thumbsup:  I missed an "upcut saw" for cheap at an auction (forgot about it) that I wanted to use for similar purposes. Like this but old https://www.youtube.com/watch?v=44IKcfzuwGY - big blade in a cabinet, used air to lift blade for cut and also for hold downs
© Skid-Er-Dun Slogging, a Delaware Limited Liability Corporation
Quote from: Cedarman on August 05, 2024, 08:09:26 AMI looked at that pendulum swinging and thought of the old movie with Vincent Price "The Pit and the Pendulum".  Old time horror flick.
The slabs have those thoughts in mind as they travel down the conveyor belt.  smiley_crying :SHOCKED1: running-doggy
