Metal plate embedded in tree??
Started by dustycoyote, October 28, 2024, 12:06:16 PM
dustycoyote
Hi all,
A few years ago I purchased some forest land. In the middle of it I found a tree that has a metal plate embedded in the side of a tree. Its obviously been there for many years and the tree has grown around it largely.
I am wondering what it is. Ive thought it could be an old survey marker, or a tag applied as part of a forestry project or something, but haven't been able to find out exactly what it is.
Any help would be much appreciated.
The plate has "D181" stamped on it. There could be additional stamping that is now obscured.
The land has been private property since the late 1800s.
I would post a picture but I'm not sure how to upload one here.
Texas Ranger
Unless a high value tree (With metal in it?) I would take a wood chisel and hammer to it and find out what is afoot.
dougtrr2
reride82
What state are you located in? What color is the plate, is it yellow by chance? If the tree is a bearing tree, it will have some data stamped on it to describe where it is in reference to the survey corner, ie distance and direction. It will also have the township, range, section, date, and surveyor info stamped on the plate and any other location data. You may have to chisel some of the wood away from the plate to read it.
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
dustycoyote
I wouldn't think it is a high value tree.
Mature lodgepole pine. Maybe 14 inch diameter.
In Idaho.
The plate is just silver colored steel or aluminum. Maybe I will have to dig it out to see if there is more stamped on it.
Ron Scott
Since the marker is in the middle of the property, it would not appear to be a land survey marker. It is more likely a Research or Tree Inventory Marker from years past.
National Timber Volume Surveys are done every 10 years across all forest lands so it might be one of such survey markers used by the USFS National Survey.
~Ron
Here is a link to the USFS land survey markers and what they might look like.
USFS markers
Hope you can reveal what you have found.
dustycoyote
What height off ground? Looks like possible deer stand strapped to that tree at the moment.
Does not look like a marker from what is visible.
dustycoyote
It's about 5 feet up the tree.
The straps are from a trail cam. Not a tree stand.
DDW_OR
