Pillow block bearings?
Started by cmj, March 16, 2025, 08:50:06 PM
cmj
New diy sawmill build.  I have only around 3 hrs of running mill.  Two bearings per shaft.  1 1/4 inch shaft.  Today I could hear a thumping noise and then one bearing blew up.  Inside race cracked in half.   Blade tension was set at 25 ft lbs.  Other bearing on that shaft has play.  I put a little grease in them, but not too much.
Junk Chinese bearings?
Or did I do something wrong?
Checked the other shaft and one bearing rotates in the cast iron.  Outer race is rounded.  Other bearing does not move like that?
Larry
Kasco built a mill with 1-1/2" shafts but they had lots of bearing failures. They increased the shaft size to 2" and which solved the problem.
