1989 Freightliner FLD log truck
Started by 230Dforme, May 05, 2025, 02:49:22 PM
230Dforme
  Anyone know where to find headlight / marker light fuses
or fuse box ? Sounds like a silly question, but neither YouTube or the dealer seem to know
Under the dash in the middle there are electrical connections, but no fuses
Thankyou
Resonator
I didn't find much with a quick online search either. I'd start by checking the trim panels around the door jamb / footwell areas on each side. Some different newer trucks I drove, you would take the glove compartment out to get at the fuses/breakers.
Independent Gig Musician and Sawmill Man
Live music act of Sawing Project '23 & '24, and Pig Roast '19, '21, & '24
Featured in the soundtrack of the "Out of the Woods" YouTube video:
"Epic 30ft Long Monster Cypress and Oak Log! Freehand Sawing"
LeftFinger
used to be glovebox not sure on 89 specific
230Dforme
I saw the glove box video on YouTube, but that is for the Cascadia model, the FLD a bit earlier w an upright, rectangle grill
Nothing in that location
Freedy201
Oh man, Freightliner in the 80s was playing hide-and-seek with fuses. You practically need a treasure map to find 'em. I had one where the marker fuse was behind a panel with no label and zip-tied to a bundle of wires, no joke
arojay
Hmmm... under the hood, on the firewall, under a cover to the right(as viewed from the seat) and above the steering column??  My memory is good but it's short.
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
arojay
OR maybe under a center panel below the dash in the cab.  I can't remember between Fallen Star and Freightliner, but you are likely looking for breakers as opposed to fuses.
arojay
230Dforme
Behind the center panel in the cab is a vertical buss bar w many wires fastened to in it w hex nuts, no fuses
Will look at your next post closer tomorrow
Thankyou
arojay
That is likely your breakers.  The 'bus bar' will be hot with one terminal of each breaker and the various circuits connected to the other terminal of each individual breaker.
230Dforme
Arojay, thankyou for the advise and help. Turned out to be the dash toggle switch 😳
arojay
