bandmill blade questions
Started by chainsaw_louie, May 12, 2025, 08:32:21 AM
chainsaw_louie
My band-mill came with 10 blades ,  a electric band sharpener and a saw-blade tooth setter.  All the blades have been sharpened several times by the previous owner.  I've been using these blades  to cut hardwood but have been getting more wavy cuts than I'd like, despite going slow.
- Aside from cutting straight, what are the checks to determine when a band-mill blade is sharpened and set correctly ?
- Is there a way to tell when a blade is no longer able to be sharpened and set so as to give straight cuts and should be disposed of ?
- Is sharpening a band-mill blade to be 'as good as new' or to consistently cut straight and fast ,  difficult and time-consuming to learn how to do?
I'm thinking it would be instructive to order some new blades just to compare them with the used blades I have and learn the differences between old and new blades.
doc henderson
I think that all sounds right.  I have a setter and sharpener and still working the kinks out.  did the setter come with a micrometer to check set?  Some new blades will also let you compare the resharpened blades.  Other with experience will chime in, I am sure.
woodman52
As Doc Henderson said... Also there are a lot of reasons for wavy cuts including going to slow.  Some new blades are a way to check if it's your blades.  If not do a search for wavy cuts, there's tons of posts
Cooks HD3238 mill, loader tractor +, small wood processor, Farmi 501 winch, Wallenstein LX115 forwarding trailer, 60 ac hardwood, certified tree farm
GAB
CLouie:
Recently MagicMan posted an entry about the width of the gullet on a blade that I think would probably help you.  My thinking is if the gullet is too narrow the rollers might be taking the set off of the top side and that would not be a good scenario.
Also what brand blades are you using?
What brand and model number sharpener and setter are you using?
What is the brand and model number of your mill?
Never having sharpened or set a blade I won't be of much help to you but with answers to the above questions and possibly many more some one has probably been where you are and would be willing to help you and most probably others on the FF.
GAB
SawyerTed
Here's a link to Woodmizer's Thin Kerf Bandsaw Blade Handbook.
Lots of good info about blades and geometry etc.
https://forestryforum.com/board/index.php?action=dlattach;attach=4532
Much of the info can be used with blades from other sources besides Woodmizer.
barbender
Sharpening and setting blades is even trickier than running a mill. You're shooting yourself in the foot trying to learn both at once. You're dealing with so many unknown variables, you'll never be able to accurately troubleshoot issues.
Get yourself a box of new blades. That will accomplish a few things. One, it will eliminate one variable and you can isolate issues to the mill itself.
Secondly, when you are learning to sharpen you will be starting with blades that someone else hasn't already screwed up.
In my experience, there aren't many poeple that can sharpen and set blades correctly. The majority bungle them. And learning on pre-bungled blades would sabotage your efforts in every aspect. So get those new blades.
jpassardi
Good advice from BB above. Personally I find setting to be more tedious than sharpening.
Bradm
This is one of those situations where a picture is worth a thousand words.
Quote from: chainsaw_louie on May 12, 2025, 08:32:21 AMAll the blades have been sharpened several times by the previous owner.
This is an area of concern (for lack of a better word).  I've lost count of how many bands I see that someone has "sharpened" but can't get to cut properly.  So far, almost all of them have one of the following two things in common (1 is by far the most common):
 1) Improper tooth face grind resulting in either a dubbing effect (lower hook angle than intended due to band being pushed away by the grinding wheel) at the cutting edge or a radius so large that your hook angle is negative
2) All the set has been ground out of the teeth
chainsaw_louie
The grinder I have is a Woodland Mills Grindlux 4000.
Tooth setter is also Woodland Mills.
Mill is LT40.
I looked along the length of one blade but didn't see a brand name or model number of the blade .
While I wait for new blades , I'm going to set up the sharpener and setter and see how it works and how precisely I can sharpen and set the teeth.
It looks like the setter with its digital dial micrometer can also be used to measure the set of the teeth without moving them.
doc henderson
do not fiddle much with the sharpener till it is set up.  Might be nice if it is really close to where it needs to be.
barbender
The basics of band sharpening with a drag type grinder (which yours is) is lightly touch the face of the tooth as the stone comes down, and then lightly grind the remainder of the profile. You may or may not be able to get it in one pass, but keep it light. It's better to grind light and miss some of the profile, and do a few passes. I focus on the face of the tooth, and the back of the tooth. Im only worried about the gullet getting ground to maintain the full tooth height and gullet shape.
Is your setter single or dual tooth? Typically, setters take a bit of fussing with to get them adjusted correctly. Once you do, I would advise you to just go around the blade, only checking an occasional tooth to make sure nothing is out of whack. If you try to watch every tooth, you'll drive yourself insane!
For both operations, your blades need to be clean. And sap build up will mess with indexing pawls, clamps and setter anvils.
dgdrls
https://cookssaw.com/bandsaw-blade-basics-101/
Cooks does a good job explaining blades and their features, etc
D
chainsaw_louie
There is nothing like learning by doing, so today I set up the blade grinder and tooth setter.  I watched a video that explained the key points and settings from the previous owner made things go quicker.  I was able to sharpen and set one blade:
Set = 0.020 +-
Angle = 9 degrees
This grinder only cuts the face and gullet. Is there any need or advantage to hand file or touchup the back of the teeth ??
I'm forgot to get a measurement on the thickness of the blade which from the data should influence the allowable blade set.
My hp = 28
Tomorrow I'll test the blade and see how successful my sharpening is.
That blade should not have been sharpened & set with that pitch and crud on it.
The best time to clean a blade is before it is removed from the sawmill.  Let it run with a good flow of lube or while being squirted with diesel.  A wire brush is useful then too.
chainsaw_louie
Thanks for the clean blade suggestion.
I've had good results cleaning circular saw blades using oven cleaner.  I'll clean this blade up and re-do the sharpening.
Any comments regarding dressing the back side of the teeth?
ladylake
With that much crud on the blade it wont saw straight.   Steve
ladylake
Quote from: chainsaw_louie on May 13, 2025, 10:15:40 PMThere is nothing like learning by doing, so today I set up the blade grinder and tooth setter.  I watched a video that explained the key points and settings from the previous owner made things go quicker.  I was able to sharpen and set one blade:
Set = 0.020 +-
Angle = 9 degrees
My hp = 28
You should set up the sharpener so  it hits the face and the tip of the tooth on the way up. Dont worry about the bottom of the gullet, it will hit that after a couple sharpenings.  20 thousands is not enough set to saw straight, set a least 25 thousands,   30 thousands for pine.    Steve
Stephen1
As above. The best way to tell if its sharp is there should be no reflexion of light of the very tip of the tooth, hence why you need to grind the face and back of the tooth.
SawyerTed
The tip of the tooth tends to round off or flatten when sawing.  The longer the blade is run the rounder or flatter the tip becomes aka less sharp then duller the blade.  It's a tiny amount but very significant. B
 Grinding only the face can lead to a perfectly sharp face with the tip being round or flat.   Grinding both face and back of the tooth restores the sharp tip.
I learned this the hard way.  I sharpened 5 or 6 blades and the wheel didn't contact the back of the teeth.  The blades didn't cut well.  Examination of the blades under a magnifier showed round top teeth compared to a new blade.
YellowHammer
100% good advice, a sharp tooth isn't sharp just because it's been ground, it must be shaped fully and correctly.
Here is a picture of sharp tooth and a dull tooth, right off the grinder, that I did years ago.  At the time, I thought they were both sharp, but not even close.  The corners are dull, and that makes all the difference.  The best way to see if a tooth is sharp is to get a way to look at it under magnification.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
barbender
That gunk on your blade will keep you from ever getting a consistent grind, because the tooth pusher pawl indexes off the face/corner of the gullet. If there is sap buildup, which isn't a consistent thickness, it will position your blade all over.
Sometimes I'll take a "cleanup" pass, just to clean out the gullets without really grinding any steel.
Yes, you need more than .020" set. I'd say .023" at a minimum for hardwoods, and like Steve says, up around .030" for pine etc. I just run .028" for everything.
chainsaw_louie
Thanks for all the good advice:
- clean up the blade
- grind the face and the top of the teeth to make sharp corners on the blade tips
- increase the set to .023-.026
Definitely not there yet
YellowHammer
I would like to commend and thank you, Chainsaw_louie, for being receptive to the advice being given.  Everybody here wants to help, and I for one, (and I bet all of them) appreciate your receptive attitude.  These folks are all pros and have metric poop tons of experience and they will tell it like it is.
So a heartfelt pat on the back, and get back to work!   thumbs-up
YellowHammerisms:
SawyerTed
Yellowhammer's photos capture what I was saying.
Yes Mr chainsaw_louie is right for seeking to learn.   We all were there once.   Some of us, including myself, still learn something everyday.
It was recently mentioned on here somewhere that sharpening only one face of a sawblade tooth is like unto trying to sharpen a knife and only honing/stropping one side.
Most on here know that I have never and will never sharpen a sawblade, but I am certainly a user.  My advice is to remove blades when they are no longer sharp.  If you wait until they are dull, then you have rounded that tooth tip and you will need to remove more material to regain/recover the tip.
Pushing blades to squeeze that last bit out of them is bad economics.
