Reclaimed lumber, Filling holes.
Started by Warren, May 30, 2025, 09:59:58 AM
Warren
In my reclaim project, I have a certain number of cants that have multiple holes drilled from wide face thru to wide face.  Apparently they were braces (?) that were originally bolted into place.  Trying to figure out how to fill the holes. First thought is to drill them out and glue wooden dowel rods in place.  My daughter asked if it would be possible to put a scab on the back/bottom of the piece and fill the holes with black epoxy?   While the epoxy would add a distinct contrast to the finished flooring, not sure the impact on resawing, planing, sanding and finishing?   Biggest concern would be that the resin would "smear" during mill work.
Anyone else have experience with filling holes and then milling/finishing over?
LT40SHD42, Case 1845C,  Baker Edger ...  And still not near enough time in the day ...
Interested to hear more about the problem.
What diameter holes ?
What thickness will the flooring be that needs finishing ?
What do you mean by "cants" ?
Is working with these cants with holes worth the extra expense ?
Can you make a sample and do one each way for comparison?
Warren
Quote from: beenthere on May 30, 2025, 11:12:44 AMInterested to hear more about the problem.
Hole diameter approx 1/2" up to 5/8"+/-. I am thinking bore out to 3/4" and then plug with a dowel and glue.
Flooring will be finished at standard 3/4" thickness.
Cants = reclaimed wood members out of an old tobacco warehouse and a distillery.   Lengths vary from 4ft to 7ft.  Cross sections vary from 4"x6" to 5.5"x 5.5" to 4"x7".
Holes on the ends (last pic) will go away with end trim.
I "could" resaw the cants such that the holes are horizontal. However that would end up yielding a lot of narrow ~3" stock that I would prefer to avoid.
Quote from: Magicman on May 30, 2025, 01:27:57 PMCan you make a sample and do one each way for comparison?
I will probably end up doing this  ^^^^.  Given the depth of experience here on the FF, I was hoping someone might jump in and say "BTDT.  Don't do that."   Or "If you do this, then do xyz..."
Hole1a.jpgHole3.jpgEnd Hole.jpg jump
Warren
Jump right into the first phase, that is sawing these cants (or one or two of them) into the rough flooring sizes and then show us the holes, splits, solid wood remaining, and how the rough cuts look that you might fill with dowels or epoxy. That will assure you that these rough blanks are worthy of moving to the hole-filling part of the process.
I would think you will get a lot of valuable information on how far you want to proceed past the initial sawing phase.  :wink_2: :wink_2:
Anxious to see some of these cants sawn into something. Will that be happening anytime soon?
Problem I see with filling the holes in the beams first is getting a decent seal on the bottom of the hole. Epoxy will seep out any hairline crack. I've done a bit of epoxy filling in knot holes in large slabs, and nail holes in reclaimed wood. Being able to tape up the bottom of the hole / crack is sometimes a challenge. It works best if you have a planed surface to work with. Once you have the holes in the boards filled, then they will plane again (to remove any excess epoxy and glued on masking tape), sand and finish normally.
It will be a bit of work as you will have to treat each hole in each board individually. I'm usually just doing one table top, or a couple of boards for a woodwork project. But if you line up a row of boards and do multiple pours in a session you should be able to get through them. You usually have to pour twice as the resin seeps into internal cracks inside the holes, so you have to top up most of them later.
Maybe an experiment where you resaw and fill one beam, and plug and resaw another? Then you can compare the results with the amount of work.
P.S. As the epoxy is your Daughter's idea, get her to help with the time consuming stuff, the taping up and pouring.  :wink_2:
customsawyer
I had a customer that I did a bunch of reclaimed pine flooring for. His holes were a little smaller, 3/8"-1/2", but he drilled them out to a consistent size and then filled with a walnut dowel/plug glued in. The contrast came out amazing. I have a picture of it on the bragging board on my website.
 https://assets.zyrosite.com/m2WBonJRyzfQPp2w/finished-flooring-mP4PPQZZM5Tp77Mb.jpg
Edit: In looking at the picture, I'm not sure it was pine flooring. That's what I had in my head. This might have been the fir that a customer brought. It had been the bleachers in some gym. Made a beautiful floor but all the bubble gum was the devil to clean out of the planer.
www.thecustomsawyer.com
Warren
I have two different/parallel projects going.   First, flooring for daughter.   She wants hardwood.   I have about 400 hardwood cants approx 4"x6" x 4ft +/-.   She wants rustic look.  Skipped planed, etc.   I will need to cull out heart check.   But other defects, if not egregious, are part of the "patina" she is looking for. No holes in the hardwood.
Second project, the cants with the holes are old growth pine ( I think).   average 10 to 20 rings per inch in the outer faces.  I decided to follow Ianab's route of reasoning in re: holes.   Bought a selection of pine, oak, cherry, walnut and Purple Heart (?) dowels, 1/2" and 3/4" diameter.   Have two flavors of deep pour epoxy and epoxy dye inbound.   If the second batch of epoxy arrives tomorrow, will make a weekend project of drilling and filling holes.   Then, two weeks to ensure I don't put bum's rush on the epoxy cure time.
My wife is also wanting hardwood floor.   I am going to saw out some of the pine cants.   With the tight ring spacing, and a warm finish, she might consider...   Will never know until I put samples in front of her.  :)
Backup, I have an extended family member who runs a rustic "wedding venue".   She is interested in some reclaimed material to form an "accent wall".   She may be interested in portion of the pine if we don't go the flooring route.   Again, appreciate everyone's input and counsel.   Thank you...
chainsaw_louie
Quote from: Warren on June 05, 2025, 06:49:56 PMI have two different/parallel projects going.  First, flooring for daughter.  She wants hardwood.  I have about 400 hardwood cants approx 4"x6" x 4ft +/-.  She wants rustic look.  Skipped planed, etc.
Could you please explain what you mean by " skipped planed " ?  Thanks.
Ljohnsaw
When your boards are not perfectly flat and you run them through the planner to not make them perfect. You get an alternating smooth and rough(er) sections.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
customsawyer
Around here we use the term "Skipped planed, or Hit and Miss planed". I plane my 4/4 hardwood down to 7/8". Sometimes there are areas that don't clean up. This isn't a problem because there is still another 1/8" left for the customer to plane to 3/4". They get to use the face that best suits their project.
Warren
Quote from: chainsaw_louie on June 14, 2025, 11:27:39 PM
A couple examples below.  Basically rustic farm house look.  Even though daughter and SIL are building a new house, she is planning to dog / kid / grand kid proof the floors.  She WANTS the "patina" to cover over (camouflage?) dents, scratches, etc.
They are actually moving in this weekend.  They put down a low cost vinyl composite floor that they got for a very low cost.  However, once she got her hands on it, not crazy about it.  The hardwood will be the final solution once it is ready to go.
I can see the point. If you start with a perfect floor, you notice the first dent / scratch. If it's got a few saw marks and dings in it to start with, who cares if it gets a few more.  ffcheesy
