Remote band mill, how can I avoid walking and measuring ?
Started by chainsaw_louie, May 31, 2025, 10:21:01 AM
0 Members and 4 Guests are viewing this topic.
chainsaw_louie
Im trying to figure out how to be more efficient when running the LT40 remote by myself and minimize my trips to the log deck.
When I watch the videos that folks post of milling with remote operator consoles,  when squaring a log into a cant or trimming edges of boards,  there isn't much walking down to the far end to measure the height of the log and calculate the depth of cut or toe-board height. Somehow they know the proper height to cut at without measuring or so it appears.
How do they make efficient and accurate cuts without getting an actual measurement of the the log's far end height from the bed rail ?    Miscalculating, wastes wood ,  time , fuel etc.   I find myself either taking a walk to the far end with a tape measure and measuring or I run the saw head down and lower the blade to the top of the log ...but then I still have to walk down to read the small numbers off the vertical scale.  Or, I guesstimate and often have to make a second cut.
Besides using a laser to see how a log lays on the deck,  is there a  technique(s) besides walking down and measuring that gives the remote operator the necessary height information?
Using the vertical scale to measure the far end works but if a log requires turning it means a back and forth trip of the saw head to enable the hydraulics.
Thanks .
SawyerTed
Which setworks?
With the Accuset 2, I normally don't measure but once and many times not at all.   There are enough settings to really reduce the number of measurements necessary.
One key is small end toward the sawyer.   For me this allows me to sight better for adjusting the toe boards.
I tend to have to take more measurements when cutting 12/4 plus live edge material, one or two off kinds of stuff.
rusticretreater
Small end towards head.  Set head height with ample clearance, run down to the other end, lower to the log and take a reading.  Adjust toe board, take a reading.  Return and cut.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
barbender
I would think situating the small end towards the head of the mill would eliminate most of your problems.
customsawyer
With LT40 side supports, they're a little under 12" high. Eyeball how high things are compared to those side supports. In time your eye will become "calibrated" to where you can tell a 1/4" difference from one end to the other. You will know that you need to set your blade to whatever height to clean things up. You might need to lower your side supports to cut at that certain height but you won't have to go to the other end with a tape measure.
www.thecustomsawyer.com
TreefarmerNN
Small end toward sawyer.  Consider marking the uprights with lines every 2".  Logs bigger than the uprights mean just eye balling how high it is above the upright.
Woodmizer used to sell a sight gauge which was basically a piece of spring mounted on a clip at the height of the blade.  I could use that as a fairly decent gauge of the height of a log but it means bending over to sight down it.
GAB
When sawing top down, if your leveling roller is up you are more apt to notice it  after turning a partially sawed log.  This helps in reducing the number of extra long door wedges.
GAB
barbender
In addition to the height of the backstops, I also "gunsite" from my board dragback to my blade, to guage where I'll be at on the far end.
chainsaw_louie
I'll try to remember to load the small end of the log towards the head,  that makes sense.
I have the Simpleset set works .
Its difficult for me to read the height gauge numbers when its 6' or more away. Larger letters would sure be helpful , or binoculars !
SawyerTed
Do you use a cheat sheet?  A cheat sheet will help cut down on the measurements with a tape or rule.  A cheat sheet makes a sawyer use the scale more.
chainsaw_louie
Quote from: SawyerTed on June 01, 2025, 02:05:19 PMDo you use a cheat sheet?  A cheat sheet will help cut down on the measurements with a tape or rule.  A cheat sheet makes a sawyer use the scale more.
Could you explain what you mean by a cheat sheet .  Thx .
barbender
When I make a cheat sheet, it is numbers that give me a starting point so that I land on my desired cant size with the dimensions I'm sawing. Say I'm sawing 6/4x6" boards. I'd have the numbers 6" (cant width) 7⅝, 9¼, 10⅞, 12½ etc. Those numbers give you 6/4 accounting for ⅛" saw kerf. So say you open a face, and take a 6/4 flitch. Flip 180°, and now you can use whatever one of those numbers gives you an opening face. Keep sawing down with those numbers until you get to your 6" cant width.
I have a fraction calculator app on my phone that has saved me from standing there with drool dribbling on my chin while trying to figure out the numbers for my cheat sheet😊
I establish a "target" on the log whether I actually mark it or not.  That is like saying that you need to know where you are going before you leave home.
I walk to the end of every log that I saw to get an initial measurement and pinpoint my initial face opening.  To me, that first face opening is the most important pass that you make because it is the basis for the entire log being sawed.  On the second face opening I use the side supports as a guide to determine whether the log is level.  After that, my cant size has been established so I use either my cheat sheet or my fuzzy brain to lead me through the remainder of the sawing.
Opening Face LINK
Old Greenhorn
Attached to this should be a copy of my cheat sheet in PDF format. We run accuset II on an LT50 and really don't need or use it very often. What it's most handy for is to give me that target that others refer to letting me know what can't size I need to hit in order to come out with an even number of boards at a given size and not have an odd sized dog board. There are many other ways it is handy, but that's the main one. On my manual mill this would get used all the time, but I still do those numbers in my head.
WV Sawmiller
  I'll try to send you a copy of my cheat sheet if I ever re-learn how to attach something besides a picture.
    Magic makes a good point about walking to the end of every log. If I don't see a distinct pith/heart check (crack) on my end of the log I am sawing I always go check the other end to see if there is one there and place it in the vertical position before I start sawing because I want it horizontal when I turn the cant at the end to start sawing my finished boards. There may be exceptions when sawing something like posts or such but they are rare.
  Most hardwoods I saw have a heart check, sometimes they have 2-3 to contend with. Softwoods may or may not have a check.
  Remember your depth of cut on your first and third faces determine the width of your finished boards. The depth of cut on your 2nd and 4th fact determine how many board you get. This is where your cheat sheet comes into play so you finish on a finished board and don't have to make an extra cut or end up with a thick or thin board on the bed at the end of sawing the cant.
SawyerTed
Quote from: chainsaw_louie on June 02, 2025, 09:08:29 PM
A cheat sheet gives the cant size in increments that correspond to your board thickness plus kerf.  So the cheat sheet informs the sawyer what the target sizes are without measuring and without pause for calculating.   The staring cant size allows all boards to come off equal, even the dog board/bottom board if the thickness is 1" or greater.  If sawing boards less than 1", a cheat sheet allows all dog boards to be equal thickness based on whatever thickness you want.
A cheat sheet allows the sawyer to work down to a specific cant size and have all boards come off the same thickness.
This is especially useful when sawing products that do not align with the 4/4, 5/4, 6/4, 8/4 scales.  For example 5/8" clapboard.
Even for the standard x/4 scales a cheat sheet gives the target cant heights so you don't necessarily have to measure every time you turn a cant.
The cheat sheet doesn't eliminate an inspection of the log or initial measurement to establish a starting point.  It doesn't eliminate measurement for centering the pith.
A cheat sheet eliminates the need to channel Jethro Bodine's ciphering (Ought plus 1 is ought kind of thing).
My (older) Setworks does not know where the head is as does AccuSet, so my cheat sheet simply gives me the starting height to reach various points within a cant.
I established it years ago when I first started sawing but I seldom ever refer to it anymore.  As I said above, know where you are going before you leave home and you will arrive at the proper location.
SawyerTed
If you don't know where are going, any road will get you there.  Lewis Carroll
If you don't know where you are going, you might wind up somewhere else.  Yogi Berra
The cheat sheet, as MM says, lets you know where you are going.
WV Sawmiller
Old Greenhorn
Yup, that worked. I was curious to see what your looked like but I don't have Word.
WV Sawmiller
Tom,
   Did it open for you? If not I can attach the pdf download.
    I list every mark from start to finish on mine but you could just mark the start (Max height on your mill) and a few intermediate points and start at one of them and print it on a post card sized paper. I keep mine in a gallon zip lock bag with a couple of HF magnets holding it to the cover of my control box where it is convenient to use.
Old Greenhorn
The file is just fine. But I do not have MS Word, so when the file tries to open, the computer wants me to buy a subscription for Word and I ain't gonna do that.
Brian_Rhoad
For those of you needing to open Office files, LibreOffice is free and will open Office files.
LibreOffice
WV Sawmiller
Old Greenhorn
yup and now I recall that you and I do ours opposite from each other. You start from the bottom up, and I start from the top down.
