Makita 7900 Review
Started by weimedog, June 24, 2025, 01:20:16 PM
weimedog
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
ehp
Like most saws that come out , the first run are the fastest and best then the saw factory slows the saws down , most times by the coil to limit the saws rpms , the 7900 is a good strong saw , biggest weak point was the rewind then the off/on switch but for the power this saw made to weight was very good , very close if not stronger than the husky 385 and thats no lie , owned a lot of them and still do , ported a ton of these saws that got shipped all over the world , built some for dolmar that were used in Africa by their race team , piped , ported but ran on gas , I wished they still were being made cause I would be running them in the bush
hedgerow
Years ago I had three  Dolmar, Makita saws two six thousand series and one 7900. Bought them new on the internet for cheap. Great saws and the two guys that helped me cut wood loved them. One recoil on one and probably at least two on off switches on all three. Then parts got hard to get even air filters. I sold two and gave the newest six thousand series to one of the guys that helps me out on the farm. He still uses it around his acreage for clean up. He doesn't burn wood. Went all Stihl after that.
Corley5
The local Jonsered dealership brought Dolmars in when I was still hand cutting. Tried to like them. They cut nice, balanced well. Nice saws. I had couple 7900s and 7300s? The mounts were weak. Every logger who tried them had the same issue. Replacing mounts was a constant. I went back to 2172s.
