Author Topic: OK Stihl guys...I've got a question...  (Read 2962 times)
Offline Captain
« on: November 06, 2005, 09:28:52 PM »
Actually, I need help.
I've got an older 028 WB in the shop.  It needs a carb.  The Tillotson that is in it is shot...too much water for too long.
I'm trying to find a replacement carb.  My Walbro Catalog lists a WA 128 for an 028 AV.  The Tillotson body style looks like a WA series Walbro.  Does anybody know if that will fit and work??  Any other suggestions??
Thanks!!
Captain
Offline Rocky_J
Re: OK Stihl guys...I've got a question...
« Reply #1 on: November 07, 2005, 06:33:39 PM »
I can't say for sure. I do know that the 028 shared some parts with the later 026, and the 026 used Walbro carbs on most of the model years. I don't know if the early 026 uesd the Tillotsons or not?
I'd research at  acresinternet (chainsaw collector's corner) to see what other saws used the same Tillotson carb you have. Then I'd look and see what other carbs were used on those saws. So if A and B interchanged, and B and C interchanged, then C should also interchange with A.
 8)
Offline Kevin
« Reply #2 on: November 07, 2005, 08:59:34 PM »
The WB should take a Tilllotson HU or Walbro WT, either one.
Offline Captain
« Reply #3 on: November 08, 2005, 06:16:05 PM »
Thanks Kevin.  It looks correct, but I was concerned about the linkage.
I don't suppose you know what model WT, my catalog does not list it.  I think the WA 128 supercedes to a WT model actually....
CAPTAIN
Offline Kevin
« Reply #4 on: November 08, 2005, 09:56:27 PM »
I can't say, this might give you a comparison ...
walbro
There's only a few to choose from ...
WT
Offline dozerdan
« Reply #5 on: November 09, 2005, 07:32:09 PM »
Captain
 Yes the Tillotson and the Walbro carb that they used on the 028s are interchangeable. No alterations are necessary.
The 026 carb will not work on the 028.
They came factory with the Walbro WT 16.
Later
Dan
Danny Henry
Central Pa.
Home of the Original Power Ported Saws
570 658 6232
dozerdan@sunlink.net or
dozerdan@nmax.net
Offline Captain
« Reply #6 on: November 10, 2005, 07:26:34 PM »
Thanks all..my information was not old enough!! :)
CAPTAIN
Question for the CTL guys.
Started by BargeMonkey on Forestry and Logging
Last post January 05, 2018, 01:33:09 PM
by BargeMonkey
Another question for the WM guys
Started by delvis on Sawmills and Milling
Last post October 05, 2014, 05:48:47 PM
by Dave Shepard
Hi guys, quick question
Started by bryce2000 on General Woodworking
Last post March 02, 2020, 05:46:07 PM
by bryce2000
question
Question for Electronics guys
Started by Fla._Deadheader on General Board
Last post February 19, 2003, 04:53:02 AM
by Fla._Deadheader
