Dynamic Green Products Inc.
Author Topic: Are there any easy mods for a stihl 310?  (Read 2314 times)
Offline Modat22
  • I love my dog.
« on: November 14, 2005, 12:37:39 PM »
I've got a 2 year old stihl 310 with a 24 inch bar, it was the biggest I could afford at the time. I'd like to squeeze a bit more performance from the saw and can't find much info on good ol' google. Probably because I'm not sure what to look under.
Thanks in advance.
Offline jokers
  • Chainsaw Freak
Re: Are there any easy mods for a stihl 310?
« Reply #1 on: November 14, 2005, 04:19:51 PM »
The best bang for your buck would be to modify the muffler and readjust the carb. Search threads for muffler mods or open your muffler outlet(s) to between 80 and 100% of the cylinder exhaust port. Also port match the exhaust gasket and muffler inlet.
Start on the smaller side because it can be tough to put metal back and consider how the new or larger ports will redirect the exhaust flow, will it bounce back and burn your fingers in a long cut or will it melt any plastic?
Russ
Offline Modat22
  • I love my dog.
« Reply #2 on: November 14, 2005, 04:34:54 PM »
I don't think it would hurt anything as long as it doesn't redirect the exhaust straight up.
Offline sawguy21
« Reply #3 on: November 15, 2005, 10:34:04 PM »
Don't get carried away. The 310 is a consumer saw and does not have the bottom end to withstand heavy modding and the resulting high rpm's.
Offline macpower
    • Mackenzie Power Equipment
« Reply #4 on: November 20, 2005, 01:19:26 PM »
Sawguy is right. Don't get carried away. The 310 does a pretty good job out of the box. Do you need the 24 inch bar? That saw would be at its best with an 18-20 inch judging by the few that have come though my shop.
Purveyor of Stihl chain saws.
Thomas 6013 Band Mill, Kubota L3400DT, Fransgard V3004, 2 lazy horses and a red heeler
Offline Modat22
  • I love my dog.
« Reply #5 on: November 20, 2005, 06:28:41 PM »
I use the 24 inch bar often, I bought it 2 years ago and I'm outgrowing it fast.
Offline sawguy21
« Reply #6 on: November 20, 2005, 10:12:19 PM »
I would suggest a larger saw if you need the 24". I use the analogy of a 35' fifth wheel travel trailer with all the bells and whistles being pulled by a six cylinder half ton. It will hook up, the truck will pull it but is it going to be adequate. Go to a MS390 or better yet a MS440 if the budget will allow. Are you running 3/8 chain as I have not seen .325 on a bar longer than 20"
Offline Modat22
  • I love my dog.
« Reply #7 on: November 20, 2005, 11:28:35 PM »
aye 3/8 chain, I'm looking at some used saws now. A neighbor has a older model 066 I'd like to buy or trade for.
Husqvarna 359, easy mods?
Started by gman98 on Chainsaws
Last post April 27, 2020, 10:23:49 PM
by MikeColes
stihl ms250 mods?
Started by bushhog920 on Chainsaws
Last post July 16, 2011, 09:07:40 PM
by CT Trapper
Muffler Mods to Stihl 036 Pro
Started by David Noll on Chainsaws
Last post December 17, 2010, 08:11:13 PM
by Al_Smith
grin
Stihl 036 PRO muffler mods
Started by Stihl 036 pro on Chainsaws
Last post March 30, 2015, 11:54:57 PM
by JohnG28
