Bar & Chain oil
Started by Larry, November 14, 2005, 03:51:45 PM
Larry
Latest price.  Poulan $4.49/gallon...Stihl $7.49/gallon.  So what is the secret ingredient Stihl uses that makes there oil $3.00 more per gallon? ???  Does anybody think the price difference is warranted?
jokers
Nope, but you can`t get Poulan oil at the Stihl dealer either. ;)
Rocky_J
Bar lube is bar lube. It's all good and it only needs to work for one or two trips around the bar. Wally World, you can get Poulan bar lube for $2.78 per gallon. I usually buy 6 at a time and restock when I get low. I used to pay the extra for the Stihl bar lube but not any more.
DanManofStihl
I use any oil except for the walmart brand that is just motor oil. It does not work that well. I can't tell a difference from the stihl oil and the poulan oil. Also the poulan is 1/3 of the price of stihl oil.
Two Things in life to be proud of a good wife and a good saw.
Billy_Bob
I get my Stihl oil for around $5.60 or $5.30 (forget exact amount) a gallon when I buy a case. Six containers to a case.
I read somewhere Stihl oil has an anti "fling" agent or some such thing. But I don't buy it for that reason. Maybe I should?
The reason I buy Stihl oil is I was told some other bar oil is recycled and may contain metal particles. And that recycled oil will not lubricate the parts as well as new oil.
I've looked at the various containers of bar oil I have and read the labels. I have not found one which says "recycled oil" on it. I don't know if they are required to say recycled on the label or not if it is in fact recycled. Anyone know?
Anyway I have not had time to mess with it, so have bought Stihl oil. It would be nice to know if certain brands of oil are in fact recycled or not, and if recycled oil contains metal particles or not, and if "new" oil lubricates the saw parts better????
Engineer
Why couldn't someone just use vegetable oil - kinda like using biodiesel in a truck?  Oil is oil for bar lube, right?
ely
then you would be hungry all the time you were sawing,is someone cooking french fries.
heres a funny story, back when i was a small child my duty was to load all the wood i could carry in the truck while my dad and uncle cut it. they would load the bigger stuff later. well they got the bright idea of using used motor oil for bar and chain oil. it did not take long for them to figure out they were wrong on that. and these are two above average intellegent folks. i dont think it ruined the bar and chain totally but i am sure it shortened the life greatly. man it did make for a great smoke show while they figgered it out. and another uncle years later had to buy a new saw when he decided that havoline motor oil would be just as good as 2 stroke mix. go figure.lol
mike_van
I buy the cheapest I can get, usually Master Mechanic from Tru Value for 3.00 a gal. on sale.  I don't believe my chains get duller faster or my bars wear more than anyone elses.  It's like putting premium gas in a car made to run on the lowest octane - waste of $$$$$ to me.
MSU_Keith
I notice that oil viscosity does make a difference in the amount used.  For the same cutting conditions and oiler setting I'll go through 1 tank of bar oil for every tank of gas using the Stihl product, but using the Tractor Supply brand (Traveller?) I'll still have a 1/4 tank of bar oil after using a full tank of gas.  The TSP brand seams thicker when you poor it.  Can't tell if this is good or bad - more oil applied probably helps the chain life but running on empty towards the end tank of gas can't be good for the chain. ???
GammaDriver
The viscosity required, then, would probably be dependant on the temperature one would use it at (like, here in south Florida perhaps i ought to be using the thicker vis bar oil if I knew what brand it was and where to find it), and perhaps somewhat dependent on the saw's ability to apply oil (a poor oiler would need thinner oil).
My question to the pros out there (and this is arbitrary as bar oil viscosities really aren't advertised or published, so many of us really can't choose): temperature and saw being equal, do you see any reason sawing some woods would / could use a thinner or thicker viscosity oil if you did have the choice?  Do some woods make a chain lose lubrication faster, and thus require more lube to be applied?
No, I'm not nearly a pro - I'm just curious now that viscosity has been brought up.  smiley_hydrogen
Mike_Barcaskey
the Poulan at Wal-Mart is my choice also, except ours is $2.83 a gallon
I use that in the 460 mag and 361
I use QV brand veggie oil from Wal-mart in my 200's and 026, it's about $5 a gallon. Over the last year I can see no discernable wear from the veggie oil, however it runs about twice as fast thru the saw. got to refill the bar oil 2x for every tank of gas.
I use the veggie oil because it has sealed several contracts on the tree service side of my business. Some customers like the eco-friendly warm and fuzzy feeling
It matters not how strait the gate,
How charged with punishments the scroll,
I am the master of my fate:
I am the captain of my soul.
Frickman
I have a thing for using OEM parts and accesories when possible, and this goes to my saws too. I run nothing but Stihl bar and chain oil in my saws, and get incredible life from my bars. A Stihl rep told me at a show that a bar should last for three or six chains, I can't seem to remember. By keeping mw chain properly adjusted and sharp, and using Stihl oil I get a dozen or more chains out of a bar.
There are different viscosities of oil. Stihl regular bar and chain is about a thirty weight or forty weight. They have a winter grade oil that is ten weight. This makes it easier to pour and I believe it's easier on the oiler. If you can't justify buying a whole gallon of winter oil just store the summer weight in a warm building until it's used.
Many oilers have been ruined by used motor oil. The oil has fine particles, both metal and dirt, that tear up the oiler. The oiler is a pump with close tolerances and it just eats it up.
A neighbor buys Poulan Bar and Chain at Wally World. He wears out oilers and bars faster than me too.
Stihl saws have a thing called Ecomatic. When you match the correct bar and chain with a saw you can turn the oiler volume back to a predetermined setting. If you do this with a saw used professionally you are supposed to save enough oil to pay for the saw over the course of it's life.
Stihl, and all the other brands, don't make their oil, refineries do on contract to their specs. If the Stihl oil is that much more expensive I'd believe they are adding things their competitors aren't.
Captain
My experience is more middle of the road.  I use a no name brand that is a high quality cling type of lubricant.  I can sell it for $5.50/gallon.  I find the Poulan oil is consumed faster and not worth the cost savings.
On to Frickman's comment, Oregon says 3 chains = 1 bar and one drive rim/spur sprocket.  My customers average probably 6 chains.  They don't stay out of the dirt!!
Captain
sawguy21
Quote from: Engineer on November 15, 2005, 11:22:25 AM
It is your nickel but I firmly believe in using the best oil available. Veggie oil is great for quartering game but not the best for wood unless staining is a problem. The chain needs it's lube on the underside of the bar where most cutting is done. An oil not designed for the purpose will fly off at the bar tip and  leave a dry cutting surface. Why put oil in it in the first place? Heck, bars and chains must be cheaper south of the border  than a gallon of oil.
I've the same bar (Windsor 20" roller nose) on my 041 Stihl that came with the saw in '75. I have gone through more than a dozen chains (I'd guess closer to 18), and I get a new sprocket with every two chains. I use the Stihl oil, hand sharpen my chains (except if tearing up barb wire or an insulator), and think things have held up well. I have had the bar jointed twice in 30 years. I am not a professional everyday wood cutter but the saw rarely sets around very long with nothing to cut.  :)
Not sure I'd like getting a new bar with every 3 chains, in fact I KNOW I wouldn't like that. Oil may be oil, but mine will be Stihl just cause I think it deserves it.  :)
Engineer
Quote from: sawguy21 on November 15, 2005, 09:53:40 PM
Well, it was just a question of curiosity.  I use the Stihl oil, always have, always will.  I can justify eight or nine bucks a year for a gallon, that's about all I cut and all I need.  I use winter weight starting about now and going right through May.   Don't do much cutting in the summer so the gallon of summer weight oil is on its' third year.
Deadwood
I guess I have never put much stock in the bar and chain oil debate. I am sure there is a diffrence as I know true bar and chain oil is "stringy." That being said, I have always used hydraulic oil, used at that, since most of it came from the hydraulic oil changed out of the skidders.
Now I use an Oil called Brad Penn DDS Plus 9115. It's nothing super great I'm sure, but it's what we use in the locomotives where I work for Base Oil and thus a five gallon can is VERY resonable, if you read can between the lines on that one.
Basically I will use anything for oil. I have never noticed my saw getting dull quicker or my bars not lasting long enough and at 7 bucks a gallon, it only takes a few gallons to match the price of a new bar.
Just my two cents
sawguy21
I remember a logger who kept coming in with his Stihl 041 complaining that the oiler quit working. I charged him each time for cleaning the system because he insisted on using the oil drained from the Cat diesel ::) He had been doing it for years with his old manual oiler Pioneer with no problems
Al_Smith
 Well this debate has been going on for some time,internet forum wide.I use TSC oil,works ok for me.The stickiness of the bar oil is due to a tacking agent[like STP,in a way],which causes the oil to cling to the metal parts,like bar and chain.
  I've heard good reports from people using vegatable oil but I've never tried it myself.
  I run all my saws with the oilers set wide open and will say that Stihl oilers are mighty stingy on the amount they put out.On the contrary my big McCullochs will oil any bar I put on them including my big old 48" and just blow oil off the end.
I'm a believer in using a lot of oil.I've got 40 year old saws,with still usable bars,although they have been redressed a few times.
Coon
Well, well, well,  I guess I must put my two cents into this one.
I have got a really good friend that works in a refinery.  Yuppers, a refinery.  I questioned him on this topic a couple of years ago and he just said listen here......  " Do not use cheap no name brand oils in anything that you own.  They are cheap for a reason...... LOWER GRADE PRODUCT. "  He then went on to ask me what I used for bar and chain lube on my chainsaws.  I just said that I used what ever I had or whatever I could afford at the time.  He went on to tell me some of the testing he had personally done while on his inturnship at the refinery and well before he got his present job.  It turns out that the cheap no name brand oils have a totally different texture and viscosity than its more expensive brand name competitors.  He has shown me how cheap oils have a tendancy to be sort of stringy and clumpy like and comes out of the jug that way.  The same (or so say same) viscosity oils in the brand names do not come out that way but rather come out like oil should.    It's just like when you compare pouring water out of a bucket and then pouring slush out of the same bucket.
Now I hope you guys see my point.  I use only top dollar oils, lubricants, and fuels.   Just look at my old Jonsered 630 for example.  It was built in 1983 and has fell in excess of 5,000,000 bdft of saw logs and in the 1000's of cords of firewood and probably 3,000,000 bdft of bucking up saw logs.  I rest my case. :D
floyd
Those of you going thru bars, do you file the rails periodically? do you turn the bar over periodically?
   do you grease the tip?
Arer you using rim sprockets?
Do you file the drivers after you throw a chain?
Rocky_J
Quote from: floyd on November 18, 2005, 10:09:28 AM
I'm not sure exactly who this is addressed to but I'll answer anyway.
Yes, I file the rails periodically and I flip the bar about once per week (or every time I give the saw a thorough cleanup). I've never greased a tip in my life, although I use an air hose nozzle to clean it out thoroughly every time I have it off the saw. It is ALWAYS saturated with bar lube so additional grease is unnecessary IMHO.
Most of my saws use rim sprockets. My climbing saw (Stihl 200T) came with a spur sprocket and the last time I changed it I just bought another spur instead of switching it over. This was mostly due to what was available off my dealer's shelf that day.
I've never filed drivers on a chain. Years ago I learned the 'redneck' method of fixing a chain with burred drivers. Put it back on a little loose and fire up the saw, then hold it at WOT for 15 seconds. Then stop and readjust the chain. Luckily I don't need to do this very often any more. But if that doesn't work, I'll throw the chain away and put a new one on. It's been about 5 years since I threw away a chain due to boogered drivers.
I ain't recommending anything for anyone else, just saying the way I do it. I'm positive that some bookreading safety type person could poke a lot of holes in some of my methods. There are also a lot of things I do that I wouldn't let a new saw user do. I just do what works for me and I feel that I am plenty safe for my level of experience.
floyd
rockyJ, there is opening to grease tip on side for a reason. I do not grease mine very often either.
I am not telling you how to maintain your equipment, it is your equipment.
I will do same on drivers but have taken flat file to really bad burrs.
Hoop
For me to purchase Stihl bar oil at $5.00 - $6.00/gallon, they'd have to have a young shapely topless female load it on my pickup, and then linger about.  Barring that, there is no way I'd even think about buying the overpriced stuff.  I figure if one buys overpriced items, they are sending a message to the parent company.........to screw us on additional items.  There are enough over priced items in the world without paying this kind of outlandish price for bar oil.
Bar oil has a small amount of tach additive, which prevents the oil from "slinging" off.  Stihl bar oil has it, Wally World bar oil has it and so does every other bar oil.
I suspect the people that purchase overpriced Stihl bar oil are the same ones that pay inflated prices for Harley Davidson oil.
Sorry Hoop.
I buy the Stihl bar and chain oil, but don't have a HD   :D
But I still have the original bar, which just might mean I don't use the saw enough to wear it out, or that the Stihl oil does the job. But then, either buy the oil or buy a new bar. Probably comes out a wash either way. Don't know.  ::)
I be happy though.  :)
PS  I'm content without the ystf loading my oil. I can carry it, no problem.   ;)
