Resawing Blades
Started by Shawn, November 22, 2005, 10:20:13 AM
Shawn
For resawing lumber, I'm researching which is better. Skip tooth or hook tooth. I imagine more TPI means smoother cut, but takes a little longer.
Shawn...
Change is part of the design process.
Admit nothing, Deny everything, Make counter-accusations
Modat22
On standard shop bandsaws you want more teeth per inch for resawing. I assume its similar to bandsaw mills but if you have a surface planer around it might not matter much.
Heres a good little guide for regular shop band saws. Theres a decent explaination on blades as well.
http://www.woodshoptips.com/tips/011303/011303pt1.pdf#search='best%20resaw%20bandsaw%20blade';
iain
I keep a good selection of blades for all my shop bandsaws
it really dont take much time to change them, espec if you aint got lots of marks to remove after
but unless i need a VERY good job on the cut, i use whats on and feed accordingly
iain
iain
Sorry forgot to say that about 6tpi is the most used on dry stock
upto about 4or5" deep, after that the gullets aint deep enough to clear the amount of saw  dust produced
iain
