My miter saw bought the farm
Started by woodsteach, March 16, 2006, 02:04:36 PM
woodsteach
I have been cutting cants for a pallet guy and he will also buy pallet boards from me which I have been getting from parts of the log that would have gone to waste. (I have a Brand X)
The problem is my miter saw.  With all of the starting and stoping of cutting the boards to finished length shot craps.  It is an older 90's Delta something.  I was wondering what you think I will most likely get the saw fixed sometime but it will just happen again.
So should I get a radial arm saw, or fix the miter saw and somehow clamp the on switch on and let the miter saw run all the time.
I have a guy who wants to sell me an old radial arm saw for less than $100.
Tell me what you think
Paul
Brand X Swing Mill, JD 317 Skidloader, MS460 & 290, the best family a guy could ever dream of...all provided by God up above.  (with help from our banker ; ) )
Woodsteach,
You're asking for an opinion and I've got one...  or two..   :D
I think RAS's are dangerous.  They are especially dangerous in a repetitive operation where you will become complacent.  The blade turns such that it will climb out of the cut.  When it does, here it comes, 90 to nothing toward you.  People have lost fingers, hands and arms to those things, just in casual sawing.  If you really put it to work, I think you are tinkering with the development of a bad injury.
The miter saw is the safer way to go, but don't wire around the safety device which turns it on and off.
My suggestion would be for you to buy or build a saw for cutting to length.  End trimmers are commonly used in the production line in front of planers.  An example that you might make would be a skill saw turned upside down at a given place on a table.  Turn another upside down at a given place on the other end of the table.  You can push boards through or build a live chain that will carry them through.  If you line one end up with the place where you want the cut, the other saw will automatically cut the other end off at the proper length.
you might go through the ends that drop off, every hour or so and collect pieces that are long enough for another board.  You might save the problems by having the boards almost the proper length to begin with.
The skill saws can run all of the time.  They have blade guards that will  help to keep fingers out of the blades and trash from being thrown.  The sawdust is usually channeled to a specific area on the saw where you could even hook up a shop vac and get rid of sawdust.  There would be less material handling and you could pass the cut board all the way through so that it stacked on the backside of the table.
If it works good enough, you can buy tools like this from commercial manufacturers.  Then you would have a dependable, labor saving and relatively safe device. :)
Kevin_H.
woodsteach,
We are running 3 chop saws in our shop, 2 12" dewalts and a 10" delta, What we have found is that the saw will last a lot longer without the constant start and stop, we use a spring clamp to hold the trigger in the on pos. ( Sorry tom )  The saws all have blade guards on them that cover the blade.
The nice thing about the dewalts is that for a set price you can get them rebuilt, i think it is something like 150.00 and that will fix any thing and everything wrong with it.
Since we run the saws for long periods of time we keep alot of extra brushes on hand, they are pretty easy to change.
I think if we need another one we might try the rigid brand from home depot as they have a lifetime
I think right now on the home depot website you can get a reconditioned 10 ridgid for something like $129.00
I tried to get the link to the chop saw to work but I couldn't ... :(
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
Dan_Shade
my dad is minus a finger thanks to a radial arm saw.  I had one climb out of a cut like tom said one time.  I have one, but it scares the crap out of me.  almost as much as a jointer does....
I'd stick with the chop saws, you can get them cheap enough.  was it the switch, or the motor?
lots of dull bands and chains
slowzuki
I will pay closer attention when using the radial arm saw I think, I always had felt safer than a table saw and that is probably what leads to accidents.
I've had a radial arm saw and table saw for 40 years, and now also have a 12" compound sliding miter, and a 10" compound miter. Each have their specific uses and limitations. Also, each demands respect and constant alertness or something bad could happen.
I will say, I am more confident using the RAS than any of the other 3.  I've been using the RAS for several days in a row now, and suspect I will for another two weeks. The 10" miter just sits there. Doesn't cut wide enough.
I do wish the 10" RAS Rockwell Delta had an electric brake rather than a manual one though. It will coast for a long, long time.
I've had more violent kicks from pinching out of my electric hand saw than I ever have from my RAS. If I let it eat wood too fast, it just binds and locks up. Do have to watch flying pieces and good fence support for the wood to rest against.
All tools are dangerous and can hurt. I'd not like to try to guess which are less dangerous than others.   :)
Don P
I've worked around both in production, and had friends mangled by both. The RAS bounced on a fast release, caught a board being fed across it and ran over a thumb. The radial arm is statistically the most dangerous tool in the shop I've been told.
The spring broke on a chop saw and the saw came down across the back of a hand.
Needless to say I try to religiously stay out of the path no matter what. Rushing almost never speeds you up.
I've replaced the switch on my DeWalt miter saw, its no problem.
At the shop we switched to Whirlwind Chop saws with rollertable infeed and outfeed and adjustable backstops. Check the used dealers, you'll never look back  :).
HORSELOGGER
I think I have inflicted more pain upon myself , overall, with hammers, screwdrivers and knuckle busters from wrenches slipping than anything from a saw (so far) Oh... And I did take a 1x8 about 2 inches south of my special spot when my old wedge bed planer rejected it ( always stand at an angle now ;) )
On the chop saw thing, I am looking for something right now to end trim flooring and last week looked at a RAS called the "Original" made by the Original saw co. It has a safety stop on it so that if you are cutting a max of 6 inches, the stop could be set at 7 inches and it would not be able to run out of the cut and eat you. Also had a auto return, but it was kinda heavy to pull and I would not want to yank on it all day trimming flooring. I have 2 tired dewalts... a 10 and a 12. The twelve sits next to the SLR and I use it to chop out the real nasty stuff as I rip out blanks for the moulder. The fence has never been square. On the dewalts, the fence is a single aluminium piece with a half moon behind the blade connecting the right and left sides. It is flexes in at the center and does not give a dead square cut. The 10 inch is dead square, but can only cut a max 5 inch floor and is tired. I have a 7 inch floor to run next month, so am looking for a new saw. The sliders are nice but I only need a 90 degree cut, no beveling or compounding, so hate to spend the $ for stuff I wont use. Anybody have one of the new Bosch sliders?
Don I like the pop n chops too but space is limited After I run a floor, I set up the table of the SLR as a chop station by clamping the chop saw to it. Remember that gravel pad next to the shop we built? Maybe this year I can slow down and build the addition :)
Heritage Horselogging & Lumber Co.
"Surgical removal of standing timber, Leaving a Heritage of timber for tommorow. "
wiam
I was always taught to push a ras when crosscutting.
Will
HORSELOGGER
Wiam, I was thinking the same thing. ;)
Horselogger, I have one of those cheapo 12" sliders on the way from Harbor Freight...should be here any day.  I'll file a report when I get it.
Wiam
Don't know how one would start the saw (ahead of the board), hang on to the saw at the same time, and also hold the board down too. Seems one would need to have three hands or use a clamp every time to clamp the board down.
How do you do that? ???
My compound sliding miter with the switch in the handle will allow me to cut that way, and that is how I cut with it. I like it too. Just not as deep (wide of board) a cut as the RAS.
Larry
Wiam,
I converted to the push stroke some 20 years ago.  Guy that taught me was from across the big pond and said they thought Americans were crazy using the RAS with a pulling stroke.
The self feeding of a RAS can be tamed somewhat by using a blade with a very small or even negative hook angle.
slowzuki
Whoa wait a second, people cut towards themselves with the radial arm? I don't even know if our little craftsman can do that with how we have the backstop set on the table. Hmm, I'll have to look ???
isassi
Seems like we always beat up on the radial arm saws and how dangerous they are. I agree with most, they are VERY dangerous, as is ANY power tool with a blade that can in anyway contact an operator. I do not know or remember where I read it, but it seems like a table saw won hands down for the number of injuries, but that may be directly related how many table saws are out there vs. radial arm saws which are not that common in home shops. I own two of them, and they have their purpose, and are no more or less dangerous then standing 3 feet away from a 52" saw blade running a circle mill. It is about the operator, not the tool. Kinda like gun injuries.  :P
To the original thought, I agree with Tom, that a trim saw would be the way to work repetitive cutting to length, and it would be very easy to fabricate such a saw. If I milled for a living, I would build one rather then buy one, all you would need to do is look at how they are constructed to get an idea.
Makes me wonder if we are talking about the same thing here, when we say RAS (radial arm saw).
Yep!  That's a Radial Arm Saw to me.
Dan_Shade
how do you "push" with one of those?
pull the saw out, set the board in place, then push back?
Dan, I'd be interested in learning that trick too  ;)
wiam
Quote from: Dan_Shade on March 17, 2006, 01:20:58 PM
Yes Dan you got it.  It is that simple.  When done this way it can't climb.
Beenthere,  My ras has a fence like yours.  The board will sit on the table if I do not hold it down.  Then I just start the saw and usually I push it through with the same hand I turned it on with.  The fence will hold the board.  MY OTHER HAND IS NOT NEAR THE BOARD.
Will
Wiam
Sorry if this appears that I am trying to argue with you, but hope if I am wrong that I learn something new.
In this picture, I think I am showing the board behind the saw, such as you have described is the way that you do the sawing on your RAS. As I see it, that board will NOT sit on the table without some serious effort to hold it down when those teeth in that blade engage the upper right corner. It will toss that board up like there is no tomorrow, and it will go flying. And that fence will not hold that board. Now, this is just as I see it. Am I wrong?
I only persist with this as it seems a very dangerous method of using the RAS is being proposed.
As I normally use my RAS with the board against the fence, and the blade started behind the fence, the board is held by the fence and the teeth begin their cut in a downward motion, pushing the board against the table as well as against the fence. If drawn to fast forward, the blade can climb into the cut and sometimes has to be held back so it is not too agressive.
Here is the normal, and I believe safe position, for starting the saw and the cut across a board. Am I wrong?
wiam
Have you ever pushed a ras?  I ahve never had a board lift by pushing.
Will
How about a picture of you doing it?  :)
woodsteach
Thanks for the great replies.  I just can't imagine pushing a RAS.  I have been teaching high school woodshop for the last 10 years and have always had a RAS and teache the kids " keep your hands 6" away from the blade and you'll have all 10 fingers at the end of the day."
I have had a hard time adjusting to the slidding miter saw with the cut on the return stroke is that what you are talking about with the pushing of a RAS?
The switch on my Delta is ok it is the "drive belt" connecting the motor to the arbor.  the saw model is 35-080 i think so I'll most likely for now find a belt and replace it.
I like the different views on RAS safety.
Paul
LeeB
Wiams method is the same method recomended for an SCM, which to me is about the same as an RAS. They to can also climb cut. LeeB
