Dynamic Green Products Inc.
Author Topic: Clutch for engine on homebuilt bandmill.  (Read 1791 times)
Offline Andre
  • Andre'
« on: November 20, 2002, 06:45:35 AM »
Does it work OK to just use an idler pulley to loosen up the drive belts?
I think I will be getting the 28 HP Kohler command pro engine.  I have not found out if there is a PTO clutch option but I will bet it would be expensive if it is available.
I know it would make more financial sense to just buy a mill but I have my own ideas and building the mill is just as much fun as sawing lumber.
See ya
  Andre' B.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
Re: Clutch for engine on homebuilt bandmill.
« Reply #1 on: November 20, 2002, 07:11:24 AM »
My lumbermate 20hp Honda has a centrifical clutch right off the crank shaft. Works great.
I run a Torro 3 blade mower deck that uses an Idler to start/stop the blades. You only start and stop it a couple of times a day and the belts do wear out. I would think that starting and stoping after each cut would realy go through the belts. IMHO.
Let us know what you come up with.
Imagine, Me a Tree Farmer.
« Reply #2 on: November 20, 2002, 07:49:41 AM »
Andre,
An Idler would work.  I've seen them used on  little manufactured mills but they don't last too long.  The bearings are usually not up to the strain.   If you use an Idler make it with something substantial like automotive wheel-bearings and a trailer spindle.  Make the wheel big enough that the bearing isn't spinning a million miles an hour. :D
The other option is to do like WoodMizer has done and make the engine movable on an axis.  When you lift the engine, you tighten the belt and Rev up the engine too. :)
Offline Andre
  • Andre'
« Reply #3 on: November 21, 2002, 04:39:11 AM »
Thanks, I know about moveing the entire engine but that seems like a lot of work.  I think I will start with an idler system, seems the simplest way to start, maybe change later.
See ya
  Andre' B.
Woodland mills clutch upgrade ??? bigger engine, but what clutch?
Started by mattyo5 on Sawmills and Milling
Last post August 23, 2016, 10:05:04 PM
by larrydown60
Another homebuilt bandmill question
Started by dancan on Sawmills and Milling
Last post July 05, 2005, 08:34:49 PM
by dancan
First 4 stroke bandmill, old homebuilt unit.
Started by T_H_J on Sawmills and Milling
Last post June 16, 2020, 07:27:23 PM
by firefighter ontheside
Well, I'm gonna replace the motor on my homebuilt bandmill
Started by duaneb on Sawmills and Milling
Last post April 14, 2012, 09:35:29 PM
by Al_Smith
