Dynamic Green Products Inc.
Author Topic: Lucas mill recommendation for personnel use  (Read 2185 times)
Offline alsayyed
« on: May 01, 2006, 11:38:31 PM »
Today I have received an email from Lucas milling machine. I have requested cataloge then they sent me the information by email.  I have found out there many types of machines and the price is ranging form $5000 and up.
I could not make my mind for which I want, actually I want for this machine for persoannel use and be able to slab some logs.
The cheaspest model is
Model 613 160mm / 6.25 inch Cut
Model 618 - 160mm / 6.25 inch Cut
Please who owns the Lucas mill please speak out which you one you recommend. And how dose it work?.
Offline Dakota
  • Swing'en in South Dakota
Re: Lucas mill recommendation for personnel use
« Reply #1 on: May 03, 2006, 01:24:26 AM »
I bought the 613.  This model has a 13 hp Honda engine.  I quickly found out that I needed a bigger engine.
The 618 has a 18 hp electric start B&S.  I upgraded to this engine.  It made all the difference.
If I had  to do it again, I'd get an 8" model.  I like my Lucas but I'd look at the Peterson also.
Dakota
Dave Rinker
Offline brdmkr
  • I need to slow down...
« Reply #2 on: May 03, 2006, 08:13:02 AM »
I have a 618 and I like it.  It does a good job for me.  There are times that I would like to have the 8 inch cut of the 827.  I think the swing mills work best with large diameter logs.  If you have smaller logs (less than 14 inch diameter) and a method to move the logs, I would consider a band mill.  I love really large logs with the Lucas 8)
Offline arnold
« Reply #3 on: May 12, 2006, 07:19:28 AM »
The best mill is the 618 for easy use.
If you can afford buy the 827 for production.
Have fun
Offline Part_Timer
« Reply #4 on: May 12, 2006, 06:49:51 PM »
I have the Peterson not the Lucas but horse power is horse power and more is better.
I have a 8"25 hp and love it.
Get the most HP you can afford you won't be disapointed
Just my .02
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
Offline getoverit
  • freeing trees from silence
« Reply #5 on: May 12, 2006, 08:49:42 PM »
I also have a Peterson, but it is the 10" model ATS. Mine has a 13hp Honda, and I wish I had a 27hp.
Go for all the power you can afford!
Any Woodmizer personnel post here?
Started by mart on Sawmills and Milling
Last post January 11, 2020, 05:53:28 AM
by MartyParsons
Chainsaw mill startup recommendation
Started by llb022 on Sawmills and Milling
Last post January 08, 2019, 05:03:31 PM
by egmiii
Looking for Recommendation on Bar and Chain on Stihl 084 Alaskan Mill
Started by tomjones2a on Sawmills and Milling
Last post November 20, 2015, 09:29:35 PM
by tomjones2a
Looking for a recommendation on a chainsaw mill for some White Pine beams.....
Started by rasman57 on Sawmills and Milling
Last post August 02, 2014, 06:05:15 AM
by rasman57
