Author Topic: What do you use as weight  (Read 2911 times)
Offline TeenSwinger
  • Like cutting big logs
« on: December 14, 2006, 06:37:44 PM »
What have you guys found that works well for weight on the lumber stack in the kiln?
We recently bought a DH kiln and have been torn as what to use as weight.
Your experience and expertice would be appreciated. ;)
Peterson ATS 827  Nyle L200  Ebac 800  Bridgewood M-562
Offline Brad_S.
Re: What do you use as weight
« Reply #1 on: December 14, 2006, 07:17:15 PM »
I use railroad rail in 13' lengths since my kiln is built for 12'+ lumber. Got it long before scrap prices made them worth much. Rail is classified by its weight per yard of length. I'm using 80 lb. rail, but I hope to upgrade to 130 lb rail in the future.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #2 on: December 14, 2006, 07:42:44 PM »
I filled a bunch of 24" plastic planters with concrete.  not sure how well the concrete would hold up in a kiln, though.
lots of dull bands and chains
Offline Burlkraft
  • Professional survivor......Still a wooodturner
« Reply #3 on: December 15, 2006, 07:03:10 AM »
I don't have a kiln, but in my air dry shed I built the stringers in the roof extra beefy and when it's full I use 12 ton jacks to apply the proper pressure. Works good......until ya need a jack... :D :D :D
Why not just 1 pain free day?
Offline Ga_Boy
  • Been rode hard and hung up wet; more than once.
« Reply #4 on: December 15, 2006, 01:37:08 PM »
I wanted to use RR iron, but can not find it in the DC area......
So, I am using retaining wall concrete blocks.  You can pick them up at your local Lowes or HD.
Offline Radar67
  • Cuttin Wood Now For My House Later.
    • Stewart Photography
« Reply #5 on: December 15, 2006, 07:39:24 PM »
I've been strapping my piles down with the rachet tie down straps. I check the tension about once a month.
Stew
Offline Justin L
  • Pouring Concrete!
    • Old School Lumber Co
« Reply #6 on: December 15, 2006, 10:45:24 PM »
My Kiln is is the building stage, but I plan on building some 2x8 frames with a wood bottom and fill it with concrete. 71/2" is about 115lbs per SF. My frames will be 4'x4' and 4'x6' to allow for different lengths of lumber. Oh yea, I have a forklift...
I know you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant! :)
Offline Brad_S.
« Reply #7 on: December 15, 2006, 11:07:16 PM »
Welcome to the Forestry Forum Justin! 8)
Offline GregS
  • I just want to be in the woods...
« Reply #8 on: December 16, 2006, 03:39:25 AM »
I also plan on using large rachet straps.
I embedded 8 flush mounted re-rod loops into the concrete when we poured it yesterday.  I like the idea of using tension springs along with the straps so they self adjust during the drying process.  These large springs might be hard to find though.  I will see how this works out ....
Offline TeenSwinger
« Reply #9 on: December 16, 2006, 07:12:07 AM »
Thanks for the responses.  We have considered straps but the way are kiln is designed, that would be hard to incorporate.  The RR rails sounds like that is doable.  That is something we had not thought of.
Offline Justin L
  • Pouring Concrete!
« Reply #10 on: December 17, 2006, 07:41:16 PM »
Thanks Brad! I thought it looked like a good place to hang out & share some of my hairbrained ideas :)
Offline dewwood
  • Makin sawdust
    • Powers Hardwoods
« Reply #11 on: December 17, 2006, 07:59:10 PM »
I use solid concrete blocks which are readily available and inexpensive and if I need more I can get them easily.  They are reusable and can be stored outside if needed.  I just put another row of stickers on the wood and place my blocks on top of them.  You can use as many as you want.  It has helped a lot with the top boards in the stack staying flat and straight.  I also usually try to put the lowest quality boards right on top of the stack.
Selling hardwood lumber, doing some sawing and drying, growing the next generation of trees and enjoying the kids and grandkids.
Offline TeenSwinger
« Reply #12 on: December 17, 2006, 08:08:54 PM »
That sounds like a very good idea Dewwood. The boards at the top seem to take the must abuse.
Offline metalspinner
« Reply #13 on: December 17, 2006, 08:43:37 PM »
Quote
I do this as well, but I use the same top row of boards for every load.  I guess they are a sacrficial row of poor quaility boards to take the abuse of the concrete block.
Vehicle weight and towing weight limits
Started by Keith_A on General Board
Last post May 13, 2002, 07:26:52 PM
by Gordon
Weight
Started by rodbutler on Forestry and Logging
Last post September 23, 2017, 10:58:35 PM
by John Mc
weight on me
Started by caveman on The Outdoor Board
Last post July 02, 2016, 07:23:53 AM
by petefrom bearswamp
Log Weight ??
Started by jrkimroxie on Sawmills and Milling
Last post April 04, 2010, 11:36:59 AM
by Papa1stuff
