Dynamic Green Products Inc.
Author Topic: Dry Fuel Tank  (Read 5810 times)
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Dry Fuel Tank
« on: December 18, 2006, 09:13:21 PM »
  Today, my Fuel Tank went completely dry.  I probably worked as hard as I ever had, wrestling with a BIG Pilon Log.  Even broke my first wood handled Cant Hook.
  What happened is, I completely gave out. Got so dizzy I couldn't stand. Drank some water, slowly. Took probably 1/2 hour before I could function. Arms were like rubber bands, legs were wobbly, head was spinning.
  My food intake here is good. No sugar to speak of, especially in Coffee. VERY Little Ginger Ale. Nothing to give the "Energy Boost". Had it happen once before, climbing a steep long hill. Had to stop and rest.  Stress Test might give bad score ???  ::) ::) ::)
Online Mooseherder
Re: Dry Fuel Tank
« Reply #1 on: December 18, 2006, 09:54:50 PM »
Fla_Deadheader, Are you diabetic or anemic?  Please go see a doctor tomorrow and get a test called a Complete Blood Count.
Lane Circle Mill
Homemade Bandmill
Offline ellmoe
Re: Dry Fuel Tank
« Reply #2 on: December 18, 2006, 09:56:08 PM »
Harold,
   Better be careful. Being nearly married and all you probably ain't got no reserves! ;D
Offline Bill
  • Why Not ?
    • Photos
Re: Dry Fuel Tank
« Reply #3 on: December 19, 2006, 12:23:12 AM »
Can't think of any good reasons for near passing out. Time to see the doc for sure.
It may be as simple as something called "bonking" to athletes - You use up all the reserves ( glucose ) in your blood stream ( you did say you were working hard right ) and get light headed and can hardly walk till you get food ( glucose ) back into your blood stream.
But you won't know for sure till you see a doc.
Good Luck ( but no time to take chances ) . . .             esp with the holidays here
 :o
Offline LeeB
Re: Dry Fuel Tank
« Reply #4 on: December 19, 2006, 12:55:29 AM »
Harold,
 You got me worried about you there old son. I'm gonna have to agree with every one else and recomend a visit to the saw bones. Go get your self checked out. LeeB
Offline DanG
Re: Dry Fuel Tank
« Reply #5 on: December 19, 2006, 02:46:17 AM »
Like the others said, SEE A DOC!  You may just need more sugars in your diet, too, but SEE A DOC!  Also, work smart, not hard.  There are other ways to turn logs than manual brute force.  It may be a bit slower, but it won't put you in the grave.  SEE A DOC!, then eat(and drink) to match your workload.  Remember, that's a manual mill you have, and you're in the tropics, and you ain't as young as you once were. ::)
Oh yeah, SEE A DOC! >:(
Re: Dry Fuel Tank
« Reply #6 on: December 19, 2006, 09:08:23 AM »
 Yeah, I hear y'all.  ::) ::) ::)  Reina is away till late today, so, I am going to work on fabbin the bandmill. Got the head mounted to the uprights. Need to do all the fine adjustments, now, so I can dial in the blade. MOST of the hard stuff is done, cept for the cipherin on hydraulics and lektrik stuff.
  Biggest problem with BIG logs is having to move 'em. Once down, you have to stagger the ends, so the blade can exit to be turned. THAT'S where the trouble is. And where they lay, once ya get 'em down.
  The Pilon fell into the upper edge of a drainage. All sorts of limbs and debris under it. We use a cant hook hook to hook the log on the opposite side, and I have a 1 1/2 ton come along chain drive that we pull with. Other problem is, NO ANCHOR point to hook a chain or 1" rope, for pullin against. THEN, ya hafta not move it so far as to overdo it.
  One end of the mill is 24" off the ground, the other end we shoveled-cut our way down, so the cross member is flush and the track sits on the ground.  ::) ::) ::)
  STILL have the Butt cut and the Stump cut to figger out how to maneuver.  ::) ::) ::)
  Gotta see if there is any sports type drinks down here. Don't really believe in them, but, did try one once. Might have helped when we were sawing in 100 heat.  ::) ::)
Offline LeeB
Re: Dry Fuel Tank
« Reply #7 on: December 19, 2006, 10:16:10 AM »
Make sure you do plenty of water with the sports drink. Four to one water to the drink. It will taste awful but you can make your own with pickle juice. LeeB
Offline Murf
  • The pitter-patter of little feet..........
Re: Dry Fuel Tank
« Reply #8 on: December 19, 2006, 12:04:29 PM »
Harold, as long as anyone can remember our family has had jugs of drinks out in the fields for those working in the heat.
Always the same stuff too, juice of one lemon, and cup of sugar in a big pitcher of water.
Legend has it the acid and vitamins in the lemon juice make it easier for your body to take in the water and sugar, as opposed to just passing through.....  ::)
Don't know fer sure, but it works fer me.  ;D
Don't taste bad either, even warm.  ;)
Offline Ianab
Re: Dry Fuel Tank
« Reply #9 on: December 19, 2006, 03:18:18 PM »
My favourite hot weather sawing drink is Tropical fruit juice ( I think it's an Apple, mango and lime blend) mixed with water. About 2 parts water, 1 part juice.  It's along the lines of what the others are recomending. You cant drink enough of the straight fruit juice to keep yourself hydrated without making yourself feel ill. But watered down you can guzzle it all day and it tops up your sugar and vitamins.
Cheers
Re: Dry Fuel Tank
« Reply #10 on: December 19, 2006, 03:23:54 PM »
  Drink a LOT of fruit juice here, straight. Figgered my sugar reserve would be topped out.  ::) ::)  I usually carry lemon mixed 50-50 with water. Still no sugar. That is probably what happened, no stored energy left.  ::) ::)
  Guess I just have to stop working and start bossing, like Fred.   ;D ;D :D :D
Offline Kevin
Re: Dry Fuel Tank
« Reply #11 on: December 19, 2006, 08:33:02 PM »
My wife thought she was doing me a favour by taking the salt out of my diet.
After nearly passing out one day at work and a visit to the doc he says, do you like salt?
I says , why yes I do.
He says, then start eating it because you have low blood pressure. :-\
Re: Dry Fuel Tank
« Reply #12 on: December 19, 2006, 09:31:18 PM »
  Just had Reina check my pressure.  125 over 90.  8) 8) 8) 8)
  She says (She's a top of the heap Nurse), I had a low sugar reserve. She's always trying to get me to sugar my coffee. Been without it for so long, now sugar tastes horrible.  ::) ::) :D
Online Mooseherder
Re: Dry Fuel Tank
« Reply #13 on: December 19, 2006, 10:05:42 PM »
Thats teenager blood pressure. ;D
Lane Circle Mill
Homemade Bandmill
Offline Paul_H
Re: Dry Fuel Tank
« Reply #14 on: December 20, 2006, 07:14:27 PM »
Can you sink a Deadman or is the ground too hard/soft/muddy?
Not sweet enough eh? ;)
Glad you're feeling better.
eg  tregar  meste  p  Tulla, for  ho  var  krulla  i  ulla.
Re: Dry Fuel Tank
« Reply #15 on: December 20, 2006, 07:27:02 PM »
 With all the rain, the ground is soft. Also, it's laying in moderate jungle, where roots are really thick, so, digging is very difficult.  Smaller trees were tried, but, pulled them over pretty easy. Really difficult area and no room to maneuver a tractor, either.
Re: Dry Fuel Tank
« Reply #16 on: December 20, 2006, 09:06:46 PM »
Make you one of these, Harold.  :D :D :D :D :D :D
Re: Dry Fuel Tank
« Reply #17 on: December 20, 2006, 10:07:06 PM »
  What took ya so long ??? I been expecting that to show up for 2 days.
 :D :D :D  :D :D
Re: Dry Fuel Tank
« Reply #18 on: December 20, 2006, 10:23:02 PM »
I keep losing my engineering drawings  and Patent application. :D :D :D
Offline TexasTimbers
    • Dovetail Spline Jig
Re: Dry Fuel Tank
« Reply #19 on: December 21, 2006, 07:47:34 AM »
You still have not scheduled any tests. Blood tests are needed young man. I was diagnosed with diabetes 3 1/2 years ago at age 44. You have never seen a pic of me but I have very little fat. No telling how long I had it before i was diagnosed.
I am not saying you are diabetic, if anything based on low energy and nearly passing out it is possible you could be hypoglycemic, but whatever, quit fabbing you bandmill and let the doc be labbing your blood.
Don't know your age and physical condition but "nearly passing out"  is not entirely normal or healthy.  ::) In fact, it is usually a courtesy warning of worse things to come if you try and pretend all is cool.
This sounds exactly like my wife talking to me about sokme health issue I try and ignore. But it sure is alot easier to dish this kind of advice out than take it.  Keep us posted we are your accountability partners FloridaHardHead.  ;)
Diesel fuel contamination in 518 fuel tank
Started by giant splinter on General Board
Last post February 17, 2013, 07:31:07 AM
by Autocar
fuel tank
Started by coxy on Forestry and Logging
Last post March 11, 2017, 08:15:04 PM
by snowstorm
MF 165 fuel tank
Started by wiam on Wanted
Last post June 06, 2006, 07:28:37 AM
by twoodward15
046 fuel tank
Started by golden foot on Wanted
Last post January 06, 2010, 11:33:12 AM
by golden foot
