Author Topic: Conceptualizing my pedestal stand/table  (Read 15811 times)
Offline SwampDonkey
  • Large Tooth
« on: August 25, 2007, 01:17:37 PM »
Here is an idea I have for the joinery of my table I'm going to build this winter. Remember this is still evolving.
Might beef it up a bit on the legs and joints like this.
wood I'm considering in the project:
pedestal column : turned black cherry
legs: yellow birch
square table top: white ash (square centre) with walnut (triangle) perimeter , bread board white ash.
square table top side trim with hanging drawer: butternut
Still cogitating.  ;D
Move'n on.
Offline Larry
Re: Conceptualizing my pedestal stand/table
« Reply #1 on: August 25, 2007, 03:24:29 PM »
Not for sure what a halfing joint is...a top view might further my education.
I like walnut and ash together...always seems to bring the complements.  Watch the grain direction on your top...end grain against edge grain is bad.  I would really consider using home made veneer and possibly book matching the walnut.  It might also be interesting to do something with the ash.
In any case it will be interesting watching you build it.  I look forward to seeing the pictures.
Offline SwampDonkey
  • Large Tooth
« Reply #2 on: August 25, 2007, 06:22:58 PM »
Won't be any end grain touching on the table top, shown in last post. Board edges are the faint dashed lines in previous post. The halving (helps to be able to spell  ::) )joint on the underside of the table top served two functions. 1) to secure and strengthen the biscuit jointed boards, 2) to mount and re-enforce the side pieces such as the side matching the drawer face.
Not concerned about the feet as the grain will be parallel to the floor surface. Looking at an old piece tells me the worst failure is between two species of wood that have a wide margin of shrinkage such as an open grain wood (ring porous) with a closed grain (diffuse porous) wood. Not much shrinkage between ends, if any. Just edge to edge. ;)
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #3 on: August 25, 2007, 06:32:38 PM »
I don't have the luxury, unfortunately, to gather book matched walnut up here in the north country. Be lucky to get the walnut.  :D :D I might use birdseye on the sides under the table top.  ;)
Move'n on.
Offline Max sawdust
  • If it's got to do with making sawdust; count me in!
    • truetimbers.com
« Reply #4 on: August 25, 2007, 09:21:20 PM »
SD,
I call that a lap joint ;)
Can you optain a thick piece of walnut and just saw it in half to make a Bookmatch?
Looks like an nice winter project, can not wait to see it done.
max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: August 25, 2007, 09:31:25 PM »
While I have never built a table like that, especially the base, have you thought about attaching the legs as sliding dovetail pins with the tail slots on the post?  I saw Norm on the New Yankee Workshop do one like that.
Your plan for the joinery for the legs and post is still not clear to me from your drawing.  Are you planing to make the legs as one unit, mortise the post, and slide the mortised post over the leg unit?
Offline Don K
  • wanna lick some wood??
« Reply #6 on: August 26, 2007, 04:49:12 AM »
You read my mind Danny. I was thinking the same thing when I saw donkey's drawing. I like Norm. He knows his stuff.
Lucky to own a WM LT40HDD35, blessed to have a wife that encouraged me to buy it.     Now that\'s true love!
Massey Ferguson 1547 FWD with FEL  06 GMC Sierra 2500HD 4X4 Dozer Retriever Husky 359 20\" Bar  Man, life is getting good!
Offline SwampDonkey
  • Large Tooth
« Reply #7 on: August 26, 2007, 06:36:07 AM »
I don't know how well that fits on a turned column though guys. Be gaps on the edges and a lot of swing from side to side. Would work perfect if the column was square. You probably need a beefy dovetail. Half inch?
I've seen it done like this on our big red pine table, the wood is 2" stock.
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #8 on: August 26, 2007, 06:41:18 AM »
Along that line yes, but a little more complicated. ;)
Move'n on.
Offline Norm
« Reply #9 on: August 26, 2007, 07:56:24 AM »
;D ;D ;D
Sorry just couldn't help myself. :D
Offline pigman
« Reply #10 on: August 26, 2007, 08:39:22 AM »
Norm sure does  know his stuff and Patty knows a lot too. ;)
SwampDonk, you could leave the bottom  of the post square. That would make it easier to attach the feet.
Here is a table I did earier this year with the bottom of the post left square.  On this table the post is 5", but I have done post the same way on smaller tables.
Bob
Offline SwampDonkey
  • Large Tooth
« Reply #11 on: August 26, 2007, 09:20:05 AM »
Pigman,
That's a great idea to. Nice table. I have some 6" x 6" cherry I hope to use. Did you dovetail? or tenon the feet? I tend to want to tenon mine, a beefier joint since hardwood is heavy. What did you use under the table surface? A piece of bent veneer? How tall was the table? 30"?
Move'n on.
Offline WDH
« Reply #12 on: August 26, 2007, 11:06:39 AM »
Hey Norm, if the shoe fits, wear it ;D.
Very fine table, Pigman!  That finish is smiling :).  Excellent methodology to keep the post square at the feet attachment points.  Now, I need to make one too ::).
Offline Burlkraft
  • Professional survivor......Still a wooodturner
« Reply #13 on: August 26, 2007, 11:59:19 AM »
Nice table Bob..... ;D ;D ;D
Why not just 1 pain free day?
Offline Norm
« Reply #14 on: August 26, 2007, 12:35:57 PM »
Beautiful table Bob. :)
Offline pigman
« Reply #15 on: August 26, 2007, 01:27:46 PM »
SD, On this table I think I tenoned the feet. On some tables with pedestals I dovetail. I put a metal plate on the bottom of the post for support.  The skirt is bent lamination. When I started the table the client just wanted a 4' round pedestal table simliar to a picture he showed me. When I was half done with the table the design changed to an extention table with a 20" leaf. ::)  I was glad he changed his mind because I coundn't get the full circle skirt to work.  The half circle was a lot easier. I sawed the top in half and  bought wooden slides from Rocker.  The table is 30 " tall. The client was going to use the table as a card table until the boss found out about it and wanted the table for a dinning table, hence the design change. ;)
Bob
Offline SwampDonkey
  • Large Tooth
« Reply #16 on: August 26, 2007, 03:57:04 PM »
 :o :o :o :o :o  I hope your client made a generous donation to the Heart and Stroke Foundation. ;D
Move'n on.
Offline Don K
« Reply #17 on: August 26, 2007, 08:00:50 PM »
Norm, when I typed that I knew you were going to jump all over it. :D :D :D ;D
Honestly though, you and Patty do some beautiful work.
Don
Offline WDH
« Reply #18 on: August 26, 2007, 10:48:02 PM »
Bob, what kind of wood is that table?
Offline pigman
« Reply #19 on: August 26, 2007, 10:57:59 PM »
It is black cherry with some cherry stain on it. I do not like to stain cherry, but the customer pays the bill. ;D  They wanted it to match some cherry cabinets they were installing in their high end house. I have a picture of the rather large house, but being they are verry private, I will not show their house to the world. ;)
Bob
New Pedestal Table
Started by Tam-i-am on LogRite Tools and Rite Leg Co
Last post November 11, 2016, 06:59:26 AM
by Tam-i-am
30acres stand and stock table and board feet
Started by empireeast on Forestry and Logging
Last post August 06, 2007, 07:31:44 PM
by empireeast
Is anyone concerned about weight with large Harvest table/threshers table
Started by Leegej on General Woodworking
Last post April 11, 2017, 09:41:32 AM
by Leegej
Sliding table rip attachment for table saw?
Started by Brad_bb on General Woodworking
Last post May 06, 2019, 08:42:43 AM
by jimparamedic
