Dynamic Green Products Inc.
Author Topic: Solo Peterson Millers, Milling Structure  (Read 1441 times)
Offline Nate Surveyor
  • If you like work, you will always be happy!
« on: November 14, 2007, 03:01:33 PM »
I have:
divided the areas around the mill into segments.
Like laying 9 playing cards on the table
123
456
789
The mill is Number 5. I push the horizontal cut going south, or down the page.
I pull with the blade vertical, going back north.
In slot 6, by the HIGH track I have unmilled logs, on RR tracks for an infeed deck.
In slot 1, I have my waste trailer.
In slot 2 I have my MILLED good wood.
I'd like to move my waste trailer to slot 4, but I have a NON running pickup there, for parts storage. It is up on blocks, and not quite enough room for the scrap trailer.
Anyway, How do you do it?
N
I know less than I used to.
Re: Solo Peterson Millers, Milling Structure
« Reply #1 on: November 14, 2007, 03:52:21 PM »
My favorite layout   just not a swingmill
When working alone
You may also like to visit this old thread on "least expensive ways to increase production:(Link to a 2 page thread started by Bibbyman
Offline Part_Timer
« Reply #2 on: November 14, 2007, 04:38:18 PM »
 If I have short logs or help I have the trailer with good boards in slot nine.  That way I can just toss the board over the rail and onto the trailer to save walking down and back the length of the rails.  It saves a lot of steps over the length of a day.
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
Offline Firebass
« Reply #3 on: November 14, 2007, 11:31:10 PM »
Nate
I have found this to be my best set up so far with my swinger.  One thing that a band miller might not consider is that the slabs are light enough on a swinger that you can easily toss them a good distance. ;D..  You just have to clear the chip pile ;)
http://www.ssindustrial.net/layout.jpg
Firebass
Offline scsmith42
    • Whispering Pines Farm
« Reply #4 on: November 15, 2007, 01:16:13 AM »
Nate, for description purposes I'd like to add one more row to your example, let's call it 10, 11, and 12.
1,   2,  3
4,   5,  6
7,   8,  9
10,11,12
My Peterson is set up adjacent to my kiln.  The mill has 66 feet of track, which occupies positions 5, 8 and 11.  My kiln occupies  9 and 12, with the loading door in between 6 and 9.  Coming out of the kiln door is a set of tracks, which occupies position 6.  This is where my kiln cart sits when I'm milling.
My waste pile is in the same location as yours - ie position 1.  I keep a tractor with a grapple parked there, and the waste slabs are tossed on the grapple forks for transportation to the burn pile.  My log pile is in position 4 (or 4, 7, and 10, depending upon the length of the log).
Small logs (16' and under) are milled in position 5, and the boards are offloaded about 8' over to the kiln cart in position 6.  On longer boards that are not going to be kiln dried, I will park a trailer at 2 and 3, and offload the long boards to the trailer.  For longer beams, I'll offload via forklift over the 4, 7, 10 side (prevents me from stockpiling additional logs there though).
I have low/low tracks.
Occasionally I will set up multiple bunks, two logs per bunk, and have one of my helpers loading one set of bunks while I'm milling on the other set.  This helps keep my producting running as quickly as possible, (and helps to utilize all of that nice track!)  The only drawback is the longer walk from the bunks in position 8 up to the kiln cart in position 6.
Scott
Tom's 3638D Baker band mill
Offline Ianab
« Reply #5 on: November 15, 2007, 01:44:50 AM »
1,   2,  3
4,   5,  6
7,   8,  9
10,11,12
Last time we set up the mill 1,4 & 7 was a stream. 2,11 & 12 was a swamp. 3,6 and 9 were the hill we had to carry the boards up. 10 was where I could stand.
We still got the logs sawn though  ;D
Cheers
Offline scsmith42
« Reply #6 on: November 15, 2007, 01:49:55 AM »
Ian, I'll bet that my setup is more practical, but that you've got the better view!
Scott
getting to know other peterson millers on the web
Started by artenvielfalt on Sawmills and Milling
Last post April 30, 2005, 08:16:52 PM
by maple flats
peterson millers and nail kontakt
Last post May 19, 2005, 08:25:28 PM
by sigidi
Portable setup for Solo milling
Started by sgschwend on Sawmills and Milling
Last post May 28, 2009, 11:42:28 AM
by sgschwend
Advice for more efficient solo milling
Started by jovol on Sawmills and Milling
Last post January 08, 2020, 11:54:34 PM
by Brucer
