We have contest winners!
If I go TF, there's actually a good chance I'll be using cypress milled right here in FL. The thought was to cut and fit the frame here, then haul it up to SC and erect it on my property. So I would need to have the timber graded here. I'm not going to cut a frame only to find out it's not 'legal'. I'm not sure who I'd ask, since cypress isn't a hardwood, and it's not SYP. I'll call the mill and ask if they know who would grade it. All I know so far is that they don't do it.
I would start by calling the Southern Pine bureau and see what they have to say....They are the grading agency for your area, FL or SC....
Quote from: Jim_Rogers on December 31, 2007, 09:02:45 AMI would start by calling the Southern Pine bureau and see what they have to say....They are the grading agency for your area, FL or SC....As I said I'd start with calling the National Hardwood Lumber Association......
Started by Scott G on Sawmills and Milling
Started by rjwoelk on Timber Framing/Log construction
Started by ljohnsaw on Timber Framing/Log construction
Started by ex-Engineer Wannabe on Timber Framing/Log construction
