Dynamic Green Products Inc.
Author Topic: Looking for Planer Blades and Bandsaw Blade Sharpening Info  (Read 1481 times)
Offline cloair
« on: January 01, 2008, 02:02:13 PM »
I am looking for a couple old heavy duty planer blades 1/4" thick to make drawknives out of.  Would like 3 to 4 12" pieces anyone know where I could find some? I also just bought a woodmizer blade sharpener any tutorials out there on how to sharpen bandsaw blades? I have Munkfors blades so I also need a cam for the sharpener, where can I get that, I will check with menominee saw tomorrow? Thanks
Woodmizer Lt 30, Ford 555d Backhoe, JD 450B Dozer
Offline logwalker
  • Got Logs??
Re: Looking for Planer Blades and Bandsaw Blade Sharpening Info
« Reply #1 on: January 01, 2008, 03:10:50 PM »
If you have any old cams with the sharpener that you aren't using you can take your time and grind them to work for the Munks. I did that with the one I have. I bought a couple super sharps bands from cook's to see what he was bragging about. But I needed a cam to sharpen them as they have a very steep rise on the back of the tooth. It worked and didn't take to long. Joe
Offline beenthere
« Reply #2 on: January 01, 2008, 03:15:47 PM »
cloair
Where are you located?  not in your bio.. ::) ::)
Offline theorm
  • Still learning
« Reply #3 on: January 01, 2008, 04:27:43 PM »
Try your local golf course. The reel mowers have a stationary blade that is 18" to 24" long. They only last thru so many sharpenings, then get recycled. The blades have a cross-section of about 1/4 by 2". Ask for the maintenance guy that keeps the mowers running.
Theo
 8)
The essence of loyalty is reciprocity.
Offline cloair
« Reply #4 on: January 01, 2008, 06:51:06 PM »
Beenthere I live by Duluth, MN.  Theorm, thanks for the idea of the mower blades I am friends of  a local golf course owner, I will check with him.  Logwalker, the sharpener should be here Thurs. I will check out the cams, should be able to grind one to work, Thanks for the good information. I will also updat my bio.
Offline jpgreen
  • My Boy- Snoopy Dogbone Green
« Reply #5 on: January 02, 2008, 10:52:06 AM »
How did you like those Super Sharps LW?
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
question
Sharpening planer blades
Started by DanG on Drying and Processing
Last post August 16, 2006, 12:12:37 PM
by foose89
Sharpening Planer Blades
Started by Corley5 on General Woodworking
Last post October 16, 2015, 06:49:55 PM
by Just Me
Started by Kasba on General Woodworking
Last post February 12, 2017, 10:49:56 AM
by Kasba
Sharpening Disp. Planer Blades?
Started by Kevin_H. on Sawmills and Milling
Last post April 14, 2006, 08:00:16 AM
by jpgreen
