Need help with a used chainsaw chaim grinder.
Started by gus1957, February 09, 2008, 07:59:39 AM
gus1957
I bought a used Emak made in Italy dated 06-1993 from ebay.
It has a pink grinding wheel which says for 3/8" & .404" made by efco.
Size  3.94"x.185"x.63"  & 100 x 4.7 x 16  which I assume is mm.
It worked on a 3/8" chain ok.
Where could I get wheels for .325" chain.
Does anybody know if these are still sold and where.
An instruction booklet would be handy as well.
   Thanks for the help.
sawguy21
Check with Bailey's or a local chainsaw dealer. The arbor size should be common.
gus1957
Emak is distributed by Tilton Equipment ( 1-800-447-1152 )and they gave me the number of a local dealer about 20 miles away.
I called and he is going to get me prices.
olyman
i use the same wheel for 3/8 and 325--if any help--and the 325 cuts like gangbusters---
pineywoods
Quote from: olyman on February 11, 2008, 05:25:22 PM
Same here, works fine on  harbor freight grinder.
rebocardo
Though I have both wheels, I too use the 3/8 wheel for smaller chain (.325 etc.) and it works fine.  Though it is a bit tough on the real small 90/91vs stuff as on my polesaws.
gus1957
Thanks for the info.
I did try the 3/8 wheel on my .325 Stihl chain and it worked great.
My brother-n-law has a harbor freight grinder and his wheels have 7/8" arbor , mine has 5/8" arbor.
Does anyone else have 5/8" arbor wheels?
olyman
the emac,jolly,oregon,and northern hyd oregon copy use 5/8 arbor.  i believe the stihl grinder does also,and maybe the silvey????not sure about the foley, though i believe it does also
