Black walnut staircase shrinkage
Started by stumpy, November 26, 2008, 12:01:05 PM
stumpy
I am sawing some walnut for a customers staircase.  It's a rustic staircase with 2"x12" treads and risers It will be kiln dried.  How much shrinkage should I expect?  Would I end up with 1-7/8" by 11-7/8" ?
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Stumpy
Just follow the formulas Swampdonkey provided in that other thread.  ;D ;D
Sawing the logs, right?
Kiln dried to 8% mc ?
Figuring 12" green could end up around 11 3/8" dry to 8%
The thickness would be 1-7/8 as you figured.
 :D :D :D It's really not that ominous considering you only need two of them formulas. It's just easier for someone else to do the math.  ;)
Ditto to beenthere's shrinkage.
stumpy
I'm sorry, I missed something.  Where are the formulas?
Sorry stumpy, I'll type the relevant ones in here so you don't go bonkers with all the math jargon
for black walnut Gg = 0.51, Vsh = 12.8% to oven dry condition, Tsh = 7.8% tangential shrinkage. The Wood Handbook has these figures from USDA site, Table 3-5 lists volumetric and tangential shrinkages from green to oven dry condition, Table 4-3a lists specific gravity green and 12%..
thus FSP = Vsh% = 12.8% = 25% no shrinkage at this MC
                Gg       0.51
Gg is what we call specific gravity in green condition
So,
→8%MC = 7.8% * (25% -8%) = 5.3%
  Tsh       25%
Be careful, use the MC% you will be reducing the lumber to in the kiln. Here we used 8%.
And applying to your dimensions.... 2" x 12"
2" - (2" x 0.053) = 1.89 " (~1 and 7/8") thick, rounding down
12" - (12" x 0.053) = 11.36" ( ~ 7 and 5/16") wide, rounding down
oh and yes factor in your planing after kilned, so probably closer to 13" wide by the time an 1/8th comes off each edge. Hope it doesn't cup when it comes to planing the flat sides, but factor planing, otherwise a good 3/8" thicker.
But it was discussed in here.
stumpy
Thanks SwampDonkey and Beenthere 8)  And speaking for all of us Mathematically challenged folks, another big Thanks 8)
Keep in mind this is empirical data (averages) from many wood samples. You can sample your own wood and find your own values, but I doubt it's worth the effort other than to satisfy or enhance your understanding. You'll probably find that you loose around 1/8" for each 2" width/thickness after kilning to 6-8%. Always good to do the math to familiarize your self with the wood species and shrinkage you would expect when you kiln to what ever moisture content your client expects.
I edited my previous post by inserting "%" by the numbers in the Tsh % formula so you can see they are calculated values and not constants. In the dimensional change calculations those decimal fractions are Tsh% @ 8% MC/100.
