Author Topic: Gearmatic model 19 winch  (Read 2941 times)
Offline Stewart Logging
  • Member*
« on: January 23, 2009, 02:26:45 AM »
My drum does not want to freespool the winchline.  I can move the drum up and down with the side cover off.  I think I need to replace the inner bearing that supports the drum behind the bands.  Do I need to just replace the bearing or are there other adjustments I need to make?  The drum actually sits down on the brake drum bands.  If I lift up on the drum then it will freespool.  If anyone has replaced these drum bearings please advise.
Offline Kodiakmac
    • Upper Canada Outfitters
Re: Gearmatic model 19 winch
« Reply #1 on: January 23, 2009, 07:07:28 AM »
Sounds like you may have quite a bit of wear there, so I'd have a really good look at seats, etc. while things were apart.
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
440JD, Echo CS510, Stihl 051AV, Wallenstein wx980
Offline Ed_K
« Reply #2 on: January 24, 2009, 08:57:35 PM »
 Sounds like you're going to be tearing it down  :( . I have a manual on it if you need part #s or diagrams.
Ed K
Offline John Woodworth
« Reply #3 on: January 31, 2009, 11:59:47 AM »
Replace the inner  and outboard support bearing, it's not that bad a job, use lots of anti-seize when putting together, seal the case with sealer and use a double seal on roto seal.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
Gearmatic Model 19 Winch
Started by Scouterwillie on Forestry and Logging
Last post March 03, 2015, 01:20:14 AM
by Scouterwillie
gearmatic winch, model 19 on Cat 518
Started by logloper on Forestry and Logging
Last post May 08, 2011, 08:22:01 PM
by Ed_K
gearmatic model 21 massey ferguson 220 winch problems
Started by spencerhenry on Forestry and Logging
Last post June 28, 2005, 01:22:39 PM
by spencerhenry
Gearmatic model 9
Started by saw_nut on Forestry and Logging
Last post January 30, 2005, 06:44:47 PM
by saw_nut
