Electronic distance measuring equipment
Started by doctormink, April 07, 2010, 10:48:45 PM
doctormink
Just wondering if there have been any discussions on this forum about electronic distance measuring equipment. I am talking about the equipment used to measure distance to trees in basal area plots. Who has tried it, How does it work?
Brian Beauchamp
If you're just measuring basal area, I'd suggest using a prism. I'd like to know how well these devices work for others too though.
VT_Forestry
I use a hand-held laser device that will get a distance down to 1/10th foot.  It works well and will do height too.  Saves a lot of walking  :D.  Only drawback to it is a thick understory...can't shoot that laser through leaves and brush to get to the trunk.  Other than that, it definitely makes my inventory job a lot easier, especially when collection of a lot of heights is involved.
Forester - Newport News Waterworks
doctormink
Vt forester, that's what I'm looking for, but would like to have something that will see through the greenery a little better. I have heard some will do that. How much do they cost? Pretty expensive I guess.
DirtForester
If we are talking about cruising purposes, I am not sure what this saves.  For measuring limiting distance, you still need a dbh so you still have to walk to the tree anyway.
If it's a good tree, grow it!
www.smithandwessonforums.com
Clark
Quote from: DirtForester on April 08, 2010, 12:34:12 PM
Many of them measure the distance to the tree then measure the height.  So it saves some walking and your tape also.
Beyond that, I'm worthless to this thread!  I've only ever tried out co-workers devices to see how they work, not for actual field work.
Clark
SAF Certified Forester
captain_crunch
I borrow my SIL's hunting rangefinder ;D ;D ;D
Old cutter I worked with took his Ax abd held handle where at arms length it touched his nose. Then with Both eyes open backed away from tree his hand was at ground and end of ax at tree top then counted paces to tree. Kind of a primitive Right angle idea. Bot lots of falling down in brush when I tried it ;D ;D
woodtroll
doctormink
Woodtroll, I will do at least 500 this year.
doctormink
Dirt forester, yes you have to walk to the tree, but sometimes bigger trees can be 75 feet away or more, it can take a while to run the tape through the brush, sometimes you can't see too well. I have heard some of those electronic devices see pretty well through brush and leaves, otherwise they would be worthless.
VT_Forestry
I agree that you'll have to still walk to trees, this just whittles down the borderline trees so you're not streching tape to trees that will ultimately be called "out".  But then again, accuracy could come into play because technically the limiting distance is measured to the center of the tree but the laser only measures to the front :)
Brian Beauchamp
Quote from: VT_Forestry on April 09, 2010, 07:51:35 AM
I forget the factor right offhand, but it may also be measured to the front of the tree. I had one subcontracting job with the USFS that used this factor for their limiting distances.
Beweller
Non-electronic.  Use a 10:1 prisim.  Position yourself so the tree is just "in".  You are now 33 diameters from the tree.  Walk up to the tree (no tape, no pacing) and measure the diameter.  Done.
Beweller
doctormink
ccBrian: I will be working on a forest service contract this summer, It calls for measuring to the face of the tree, it takes a different chart for this. I don't know why they do this, but maybe they assume some of their contractors might use electronic distance measuring equipment. I don't like to measure to the face of the tree with a tape because it seems to make the tape pull out much easier, and just when you get almost to your distance it pulls out and you have to do it all over again.
