Author Topic: LT 40 Pressure  (Read 1926 times)
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
LT 40 Pressure
« on: April 13, 2010, 10:15:16 PM »
Mill, 1997 LT40HD24
Problem. All of a sudden the pressure gauge starts jumping by a couple hundred pounds and the is a noticeable vibration of the sawhead.
History, everything fine til I sawed some really sticky pine, had a lot of trouble with sawdust build up under the belt on the powered band wheel, more than I have had since I bought the mill new. Now sawing oak, still getting some build up occasionally, never had that before.
Trouble shooting, changed blades several times, changed bandwheel belts, grooves are clean. Spin off side wheel by hand, bearing seems good, no sound. Take blade and belt off, put motor in gear, no vibration on the saw head. Take drive belt off and spin by hand, sounds fine.
The only thing I have found so far is the drive belt, looks new, it is the notched belt, about half of one notch is gone, hard to believe that is the problem.
Haven't had a chance to call WM yet. Anybody have any ideas?
Bill
Offline taw6243
    • Silverwood Sawmill
Re: LT 40 Pressure
« Reply #1 on: April 13, 2010, 10:39:52 PM »
What about the adjustment  of the blade scraper in front of the blade guide roller?
4500 hours on my 2004 LT40HDG28, CBN sharpener and auto setter, 25" woodmaster planer with 9'auto leveling bed and trac vac chip handling system, 1998 L3010 kubota, 2010 L3200 kubota Festool TS75 rail saw with 42", 75" and 106" rails.
Offline WH_Conley
Re: LT 40 Pressure
« Reply #2 on: April 13, 2010, 10:52:25 PM »
It has clearance.
Bill
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: LT 40 Pressure
« Reply #3 on: April 13, 2010, 11:44:56 PM »
First thing, it sounds like a cracked saw, but you have tried several with no change or pitch under the belts and you have addressed that as well. Check for cracks in the wheels. Can you see a vibration in one wheel or both or in the drive belts?
Re: LT 40 Pressure
« Reply #4 on: April 13, 2010, 11:49:29 PM »
It still sounds like there is something under one of the tires.  If the pressure gauge is the one for the band tension, then it is moving because the tension is changing.  That is indicative of the idle side wheel being moved, such as would happen if the band was traveling over a hump.  When there is something under the band-tire, there is usually an accompanying roaring sound.
Wipe the V-groove down with WD-40 or something like that, in case the sides of the groove are sticky.
Check both the power side and idle side grooves for a buildup.  Use a screwdriver and run it along the bottom of the groove as you turn the wheel.  It doesn't take much.
swap band-wheel tires one side for the other.
Offline WH_Conley
Re: LT 40 Pressure
« Reply #5 on: April 14, 2010, 12:38:51 AM »
Backwoods, I have not looked for cracks in the wheels, I will do so.
Tom, It is band tension gauge , I read your tutorial of "Let the Bandmill Roar".  I used a paint scraper. The grooves seem to be clean. The one thing I have not checked  is cleaning out the drill, balancing, holes to make sure they are clean.
Bill
Offline amberwood
    • www.amberwood.com.au
Re: LT 40 Pressure
« Reply #6 on: April 14, 2010, 01:22:25 AM »
Grab the drive whel and give it a good shake laterally. If the bearings inside the carrier have let go it might be causing the drive wheel to whump around in an elipse pattern causing the blade tension to go up and down. MIne lasted 3800hrs and would have lasted longer if all of the oil had not snuck out.
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
Offline Chuck White
  • Sawing Mobile since 2005
Re: LT 40 Pressure
« Reply #7 on: April 14, 2010, 06:06:43 AM »
I think amberwood has it.
I believe it's the main drive bearing.
I would also put a band on and close the top sheild (for safety), put the mill in gear and go around
so you can watch the wheels and the band and check to see if any of your vibration is visible.
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: LT 40 Pressure
« Reply #8 on: April 14, 2010, 06:57:27 AM »
Sounds like you have something under the belt or in the grove. If the tension gauge is moving the blade is getting tight and then loose.
If you need to check the drive bearing, the brake needs to be released and the drive belt also needs to have no effect on the bearing. Pull the clutch engaugement mid way to check the bearing. I would think if the bearing was loose the blade tracking would be effected.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
Re: LT 40 Pressure
« Reply #9 on: April 15, 2010, 01:23:33 AM »
Check for sawdust building up in the balancing holes on the driver band wheel. If you find any be sure to clean the holes completely. It's not that the sawdust causes an imbalance -- it collects more sawdust and making a bump under the band.
Bruce    LT40HDG28 bandsaw
What Pressure to use
Started by Mark M on General Board
Last post November 14, 2004, 11:23:20 AM
by Mark M
Self done pressure treat???
Started by shinnlinger on Sawmills and Milling
Last post February 15, 2008, 06:34:29 PM
by Fla._Deadheader
208 tj hydraulic pressure
Started by Firewoodjoe on Forestry and Logging
Last post July 15, 2020, 04:52:46 PM
by mike_belben
Pressure Washer
Last post May 05, 2004, 04:08:12 PM
by SwampDonkey
