Author Topic: Making Siding for Barn?  (Read 2415 times)
Offline luke
  • My motto "I can"
« on: October 27, 2003, 09:46:48 PM »
We are thinking about building a 30'x40'x12'  "pole barn". The lumber we have thought about using for the siding is KD Yellow Poplar. Would a shaper and some v-groove carbide bits, do the job, for making about 2,000 board feet of barn siding?
V-Paneling Cutter PC-19-010
1-1/4 inch bore, carbide tipped, use with 3/4 - 1 inch material
Checking into grade sawing, building a dry kiln and moulding machines.
Offline J_T
  • Some of anything beats all of nothing Even in Dukedom Tn
Re: Making Siding for Barn?
« Reply #1 on: October 27, 2003, 10:19:26 PM »
Around here they use board and batten . We lazey 8)
Jim Holloway
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
« Reply #2 on: October 28, 2003, 04:19:13 AM »
Hi luke.
I think T&G edges will rot faster than Ship Lap with Batten.
Poplar is OK but It's no White Oak, most other Oaks, Hemlock.  I think I would use SYP and have it pressure treated ($.10 to .15 bf) , before using Poplar.
But since it is kiln dried ??? I guess it's what you have readily on hand.
And keep it away from the ground if possible..
JIM
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
Offline MemphisLogger
  • Don't trash that tree . . . TREECYCLE!
    • Midtown Logging and Lumber Co.
« Reply #3 on: October 28, 2003, 06:11:29 AM »
I vote for plank and batten but using poplar I'd go for some deep eaves and some treated wood for a skirt--don't let that tulip wood touch the ground, it'll get et in no time!
Scott Banbury, Urban logger since 2002--Custom Woodworker since 1990. Running a Woodmizer LT-30, a flock of Huskies and a herd of Toy 4x4s Midtown Logging and Lumber Company at www.scottbanbury.com
Offline Don P
    • Calculator Index
« Reply #4 on: October 28, 2003, 04:43:07 PM »
But...poplar makes excellent siding if kept dry. The grainery where I'm working is weatherboarded in 3/4 x 6 poplar, unfinished...from the 1860's, as are many of the local homes of that period.
I was preparing today some poplar that was sawn 60 years ago. It was stickered in a barn to dry and was intended for drop lap, the round tuits never came round  :D. The powderpost beetles had been tuit so I gave it a libation of borates and will apply a water repellant finish.
I've got the 2 piece set of router v-groove T&G bits, used them for making soffits. I had a devil of a time getting the T into the G...too tight a fit. Finally made a fence on the handheld router and with a straight bit shaved a little of the backside of the T to let it slip in easier.
Offline luke
  • My motto "I can"
« Reply #5 on: October 28, 2003, 08:43:34 PM »
Don.P,
true, poplar has been used for siding for many years. I painted a early 1900's two story Victorian home that had poplar beveled siding on it. And yes keep it dry, a nice sized overhang, with borate for the bugs, and wood preservative, should make it last a while longer. The reason I suggested tonge & groove or v-groove is, I have seen some local sheds, with board and batten siding on them, and they look cheap. If I build a pole barn, I want it to "increase" the value of my property, so that when I have it appraised, it will appraise for more money.
I know that the "deluxe" pole barn package you can buy from 84 lumber will look good with the painted steel, it would cost about $10,000.00 for a deluxe 30'x40'x12' with insulation and electrical wiring. I wonder which pole barn would raise the "value" of your property more, the one from 84 lumber, or one hand custom built?
Offline solidwoods
« Reply #6 on: October 29, 2003, 04:10:41 AM »
Oh yes
Metal makes a nice side also.  Also Used/repainted.
Fire proof also,,helps stop fire spread like from a grass fire.
JIM
Ret. US Army
N. Central TN.
Offline mitch
  • May your saws run true.
    • Shag bark farms
« Reply #7 on: October 29, 2003, 03:29:51 PM »
Luke,
I agree with the previous posts...tongue and groove will just trap moisture. All of my buildings are board and batten. Rough sawed with a circular mill
full sized images at
http://shagbarkfarms.com/Photos/
Barn siding
Started by sallvord on Sawmills and Milling
Last post December 03, 2013, 03:57:23 PM
by Gentlewolf
Barn Siding
Started by chazmonro on General Board
Last post August 08, 2006, 09:13:11 AM
by Quartlow
Barn siding
Started by broker farmer on Sawmills and Milling
Last post March 15, 2006, 10:44:27 PM
by woodmills1
Barn siding
Started by witterbound on Timber Framing/Log construction
Last post November 29, 2007, 10:40:14 AM
by witterbound
