MS460 Compression 120 psi
Started by terrifictimbersllc, June 07, 2010, 09:34:58 AM
terrifictimbersllc
Haven't worked on a cylinder before.  Saw runs fine.  Is it a good time to do something if so what?
ladylake
 If it runs good , has decent power leave it alone unill it doesn't.   Steve
SawTroll
Try to change the piston rings only, if there are no sign of scoring.
Information collector.
JohnG28
ladylake
chevytaHOE5674
Quote from: SawTroll on June 07, 2010, 09:01:44 PM
I agree if there's no signs of scoring then it is a perfect candidate for a ring job. If it goes too far then you will be looking at a piston and cylinder replacement.
terrifictimbersllc
When does one use a cylinder hone to resurface the cylinder walls?
ladylake
 Make sure to use your compression tester on a different saw before ripping it apart, testers can vary quite a bit.    Steve
terrifictimbersllc
Quote from: ladylake on June 09, 2010, 06:27:15 AM
I did, thanks, and then checked it by blowing into it with my air compressor line at 2 different settings.  The compression gauge has a valve that traps the highest pressure reading.  It was right on.
tlandrum
stock ms460 are around 150-155 your getting a little low. id rering it and drop the cylinder down so that the squish is at about .020 and she'll pep right up. have you opened up the muffler on it. if not try opening it up to about  70% of cylinder opening. jmho
www.wickedworksaw.com
wickedworksaw@gmail.com
Husqvarna and jonsered dealer
chainsaw porting for high production work saws
4233465399
terrifictimbersllc
Quote from: tlandrum on June 09, 2010, 08:40:40 PM
Thanks.  What does this mean?    Didn't open up the exhaust yet, also what do you mean open up to 70% of cylinder opening?
JohnG28
That refers to the exhaust port on the cylinder...open the exhaust port on the muffler until its size is roughly 70% the size of the exhaust port on the cylinder
tlandrum
dropping the cylinder down with a thinner base gasket will decrease the clearence between the piston crown and cylinder top. this will increase compression.you want about 20 thousands between cylinder top and piston crown.
4233465399
Al_Smith
Quote from: terrifictimbersllc on June 07, 2010, 09:34:58 AM
Key words--saw runs fine ----.Leave it alone then . ;)
boobap
it may be running fine, but i doubt it is creating its full power...how many hours would you guess are on it? i would start by pulling the decomp and checking that it is not all carboned which prevents a full seal and would also lower compression...
terrifictimbersllc
Quote from: boobap on June 14, 2010, 05:15:28 PM
Guessing maybe 100 hours?  5 yrs old with 2 yrs of 3 cords per yr and 3 yrs of portable sawmill business.  Thanks for the decompresser idea would like to go looking for an easy out.
boobap
I have the 460 service manual and IPL if you want them...just PM me your email address
boobap
with that much use, i would guess it is time for a ring job...if not more. rings are fairly easy to do on those, and even more now that you have the service manual!!  8)
ladylake
 A 460 should last 1500 to 2000 hours before it needs rings, If it runs good and has good power leave it alone, maybe check the decompression valve as mentioned above .   Steve
SawTroll
Quote from: ladylake on June 18, 2010, 07:17:37 AM
Different saws live different "lives" - so the hours isn't really relevant when there are indications of a problem.... ::)
ladylake
Troll You know as well as me that a lot of 460 saws will last 2000 hours, unless it injested a lot of dirt or something  I'd be looking at a faulty comp test, leaky decompression valve  . Maybe pull the muffler off and take a look, it could half burned up. If not scored put the muffler back on and run it.   Steve
SawTroll
Yes, that is basically what I said - each saw has a "life" of its own, depending on several factors - just counting hours  :P is meaningless!   ::)
terrifictimbersllc
 I was in to the Stihl dealer Saturday and the mechanic who has worked on saws a long time said that 120 psi is good.  I asked him what the compression on a new MS460 is and he said 120-130. So there's nothing needed to be done.    Thanks to everyone for ideas.
ladylake
 Most new saws run around 140 to 160# cold, when warm maybe 10 to 15# less. Also when testing several hard pulls with the throttle open untill the gauge quits going higher get the right reading. As mentioned above if it runs fine run it, no way it should be wore out at 100 hours unless it's started to melt down. It take about 5 minutes to pull the muffler of and look at the piston and rings.   Steve
chevytaHOE5674
Quote from: terrifictimbersllc on June 30, 2010, 08:09:34 AM
He lied to you. I have a brand new 460 in the box and it pulls 155psi, and my 3 other 460's pull between 150 and 160 with hours upon hours of use.
