Loss of our Tamarack (Eastern Larch)
Started by Jeff, September 15, 2010, 12:55:25 PM
Okrafarmer
Quote from: Jeff on September 17, 2010, 10:51:30 PM
my neighbor Lou has many over 20"dbh and hundred foot tall.
Yes, that's the size of most of the big ones I saw in Maine. Ours was over 24", nice and straight and had massive (for a conifer) limbs reaching out for at least 20 ft. from the trunk.
Now selling Logrite tools!
I can't remember the specifics on the heights of any of the big ones I've seen, but I'm pretty sure it tops out around 80 feet as it doesn't get the height of red or white spruce. Sometimes it's deceptive on the  heights if your main stand is cedar or something that only grows about 60 feet. ;) The diameters that I have seen do approach 30 inches like the aspens and those long reaching branches most loggers hate. :D They seem to be bigger where there are settlements, out in the back country they are not so common because it's mostly shade tolerant species out there with the exception of white birch and aspen. Most aspen out there is road side or around wet areas that were logged. We have larger tamarack up here than in the south, one fellow was looking for some big ones from down south. Wasn't going to be paying much for the timber to make up the trucking so the deal died. He was going to use them for sewage systems I think. I don't think you can build a new house these days on a wooden cesspool sewage system, so it may have been down in northern NS. I guess the tamarack are mostly around the bogs out back. But still any thinning near boggy ground is mostly spruce, fir and cedar. Even on my land I introduced every tamarack there. Moose ravage the things. ::)
Okrafarmer
My dad used it for  truck bedding and other tough use application. I think they used to use it, along with hemlock, for railroad ties a lot, if I remember correctly.
Jeff's tamarack grows a bit straighter than here. A lot of ours is full of spiral grain, far worse it seems on old fields. It's a bit nicer in natural forest floor, don't know why. They have to grow fairly tight here to be anything to rave over. ;)
Ron Scott
Jeff,
It looks like a tough job on salvaging just the larch, but it appears to be the primary objective. Can you take out some additional species along with the larch for a possible commercial sale and to make the access and falling easier?
Can a faller buncher get on the area or is it too wet? Have you been able to get in contact with Dr. Hyde yet and discuss your larch situation?
~Ron
No contact with Dr. Hyde yet. I'll try again on Monday.
I think my ground is just to sensitive have a commercial logging done in there without changing it forever from what it has been, according to my neighbor, for all of his 80 some years and more.
You won't want that big equipment in there unless the ground freezes up well in winter. The trouble to, is I can't see the economics of it. With whomever you hired, they'd gut the place just to make it profitable for them to operate. There is a lot of stems but the average is on the small side. We aren't talking high value species either. Cedar, as long as it takes to grow to get to decent size never has been worth much compared to spruce. The black spruce is still pretty small, with a few scattered sizable ones, ones you are just beginning to get more growth due to diameter. However, the overall stand could benefit from a thinning at some point to release the maple and spruce somewhat. Jeff, how's the shoulders? Well, assuming your looking for some work. :D
That ground never freezes. To much organic action going on below. What ever needs done, I'll be the one doing it.
Ron Scott
Yes, I thought that it was inoperable. Nature will have to take its course.
~Ron
Clark
Quote from: snowstorm on September 16, 2010, 08:42:48 PMin maine we call it european larch desiese   the story i heard was it came from europe with some hack ... larch....that was used for pillings at the cargo port in eastport. it has killed most of the hack up here
I'm not so sure about that.  I know that when they originally brought the European larch over here they had a problem with continental vs. maritime seeds sources.  One (I can't remember which) did pretty bad over here while the other was fine.  It was a seed source issue that has since been worked out but I think European larch got a bad name in the process.
I don't think tamarack is headed the way of the chestnut.  It's a very fast growing tree on upland sites and does well on the wettest sites also.  It will stand more water than cedar, black spruce or black ash.  I think tag alder tolerates slightly more but not much more water than tamarack.
Unfortunately it has a variety of hosts that tend to kill entire stands.  As has been noted it's a cyclical thing.  It could also be one of those things that once you learn about it you start noticing more and more of it until you think the end is in sight for that species but in reality your perception has just widened.
Jeff it's too bad that you lost a bunch of big ones.  If it's any consolation I don't think that they tend to make it past 100 years in these parts.
Talking of size I don't think I've seen one hit 90'.  100' is big and over 20" dbh is notable around here.  That's forest grown stuff on pretty wet ground.  On dry ground they can really take off.  I cored one this last spring that was 15" dbh and 32 years old, pretty phenomenal growth for the frozen north.
Clark
SAF Certified Forester
I don't agree with your assessment of white cedar not growing on sites that are very wet compared to tamarack. In my woods the really wet sites are dominated by cedar. I introduced tamarack to cedar sites that were cut because it's a fast growing tree. Those same sites have natural cedar growing back as well. I've seen areas that tamarack grew with the cedar and the tamarack are now stubs, the cedar will live there 3 times as long. I have cored a good many white cedar around 16 cm dbh on the real wet sites and they are between 140-180 years old. Shade tolerant trees are slow growers. Also, any bog, I mean with picture plants and sphagnum, over north are growing with black spruce and tamarack side by side in the moss. I have thinned boggy ground, because it was an island of land in the middle of a site, that had no tamarack, just black spruce and cedar. Now, tamarack will grow quicker than any species on those wet sites for sure. I have 8 year old tamarack on wet ground as tall as 14 year old black spruce on dryer ground. They are 14-18 feet tall. Also, my black ash are in those same wet places with the cedar and tamarack and very slow growing as well, not many amount to much in decades. Black ash will grow slow even on dry land. Also I don't have much alder, but I have willow to no end. We are talking about ground that would be growing just cattails and sedges if wetland trees and shrubs where not present. I call tamarack the tree that will grow on water, but that ain't exactly true now is it? ;)
Clark
Quote from: SwampDonkey on September 19, 2010, 02:40:30 AM
That's interesting Donk.  My observation comes while fishing and looking at these low areas that extend into the lake.  Invariably the black spruce, black ash and cedar will fade out and the tamarack will continue out towards the lake farther.  Maybe that is a regional difference?  Or I'm viewing something a little bit different than normal next to the lake?  In either case we're definitely splitting hairs!
Clark
Jeff,
My friend says it looks like dendroctonus simplex, or larch beetle.
What he says is: "Out here it acts as a secondary pest, knocking off stressed trees. Perhaps his trees were under stress from drought or high water table? That's what usually knocks them off!"
Jeff, I have  Forest Insect & Disease Leaflet # 175 he sent. It's 500 kb, so I can email it to you if you wish. Maybe it will come up in Google or on the USFA website if you prefer.
My friend is coming back east to his mom's. Her brother, his uncle, passed away yesterday. I knew him, he worked for father a few years back.
Yea, email it to me, or attach it to a post yourself if you can, because it comes in under the limit.
I should of, could of, seen this coming. Actually I did notice it clear back to this post in 2007, but did not give it the weight I should have.
https://forestryforum.com/board/index.php/topic,24810.msg354740.html#msg354740
Here are two pics of one of the effected trees back then, and a picture of one of the healthy ones, both from that original thread.
Ok, I see now. You musta raised the limit from 250 kb or whatever it was. Here's the document.
Skimming through that leaflet I noticed they mentioned the larch beetle can sometimes be a secondary pest coming in after the trees have been hit by budworm or sawfly and defoliated somewhat causng stress to the trees as well. You've got budworm looming nearby, I did not notice any in the vicinity but they are up around the Soo and down along I75 a ways I noticed, giving the spruce a pounding.
I had big plans on doing a salvage harvest this summer, and getting all the logs sawed into beams, timbers and cants, but some medical issues this spring and then a pretty involved shoulder surgery pretty much trumped those plans. However, today I started on this project. I'm still only about 70% on the shoulder recovery I would estimate, but I've found I can start and run my new Stihl that Tammy and the kids got me for Christmas.  It sure do feel good to be at least a little bit productive. :)
I only dropped, trimmed and bucked about 6 trees today, It was a pretty good first workout, outside of PT. I don't feel I over-did, but I can still feel it. ;D At least a start eh?. I'm skidding them into the edge of the field with my atv and logrite arch. The only problem I have I think is that there are going to be a whole heck of a lot of logs and I have no easy way to pile them, but I'll figure something out.  :) The logs are in better shape then I thought they would be so far, they have degraded some, and some of the first to die may be to far gone, but the ones I have cut so far will definitely have some recovery.
Lynda came back and took a picture before her and Pete headed for home. She took a video while I was bucking some logs, then I set a camera up and videoed while I felled a couple smallish larch.  It's been a good day. :)
You maybe able to parbuckle them using skids and chain/ropes and the ATV like they would use a horse. Be careful not to roll them on yourself.  If you could use a couple standing trees as stops on the back of the wood pile, it would be safer. Make a trail out from the stops into the woods or if you have a couple big old spruce yard trees you can use as stops. Use the skids on the slope of the pile to gain mechanical advantage of a straight ramp without the bumps of the piled logs. Anchor the chains or ropes to the stops, run the ropes over the top of the pile to the log and wrap around the log ends. Throw the ropes back over the pile toward the stops and pass them between, tie to ATV hitch and roll them babies up the pile. Slide the ropes off the ends of the log. Repeat. Don't try to roll them up a steep pile, I don't know if your ATV's would have the weigh or power. Maybe if the winch was used and the ATV anchored.
Don't over do it, I don't wanna have to be cutting and piling logs next August. :D ;)
red oaks lumber
first it looked like an episode from ax men ;D
Good job, Boss.  Your shoulder is coming along nicely for you to be able to do that.
I had to play axmen once today. These trees are so dried out on top that they have very little momentum when they begin to fall, and to start out, I didn't have much of a place to start dropping them because they are so thick, so it takes very little to hang em.  The first one hung, then the second one hung trying to knock that one down, but that opened up the opportunity to drop a bigger tree to take them all on down to the ground. Fun! :)
Quote from: WDH on August 22, 2011, 09:02:51 PM
I've got a pretty good comfort zone now to work with. Hopefully just getting out and living will increase my range of motion, which has been my biggest limiting factor.  It's coming along.  :)
treefarmer87
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Peter Drouin
Good job. best of luck with your recovery.
A&P saw Mill LLC.
License NH softwood grader.
