Dynamic Green Products Inc.
Author Topic: Which Moisture Meter?  (Read 2362 times)
Offline WoodHacker
    • Wood Hacker - Hacked Sticks, Stumps & Logs
« on: October 26, 2010, 05:56:22 PM »
Thinking about buying a moisture meter for checking wood in my solar kiln and was shocked to see the range of prices.  Wow!
I wouldn't trust the $6 meter and don't think I need the $300 meter.
Which meter do you use or recommend?
Butch
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Which Moisture Meter?
« Reply #1 on: October 26, 2010, 06:14:01 PM »
I have the $400 Wagner pinless meter.  You get what you pay for and there are no free rides.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline WoodHacker
« Reply #2 on: October 26, 2010, 07:29:23 PM »
My Google-foo must be week today as I did not find the $400 pinless meter.  Kind of makes one wonder how 'pinless' works...
Butch
Offline poolman
« Reply #3 on: October 26, 2010, 09:23:15 PM »
I have a Wagner radio wave meter also.I bought it in 94 and I paid 350 for it with shipping.It uses a magnetic Field and it reads 3/4 inches deep in the wood.It is very fast and accurate.When You really need to test a lot of boards a pin meter would be a bad choice.You can buy a pin meter for 30 bucks online.Keep in mind my wagner works to todays standard after many years of use.I hated paying for it but its a life time tool i think.A 9 volt battery lasts a year in it.But if You need to spend little on a pin meter try harbor freight tools and get one made in china.Good luck ,Brian
Offline Knute
« Reply #4 on: October 26, 2010, 10:03:02 PM »
I have a Lignomat Mini Ligno E which works well for me.
Offline WoodHacker
« Reply #5 on: October 27, 2010, 12:49:33 PM »
Is it true that a pinless meter does not work well on rough sawn lumber?
Butch
Offline poolman
« Reply #6 on: October 27, 2010, 08:01:50 PM »
A radio wave meter works on any type of lumber.I am on my second sawmill and have been sawing and testing moisture since 94.I would not have the time for a pin meter.My time is important to me and what i do must be fast. It reads 3/4 inches deep in any type of lumber, in  1 second a board.Try that with pins. Good luck ,Brian
Offline trapper
« Reply #7 on: October 27, 2010, 08:16:26 PM »
opinions on deimhorst j-lite woodcraft has for $130 now
Offline Knute
« Reply #8 on: October 28, 2010, 10:10:04 PM »
Delmhorst has been around for a long time. I was going to buy one but was given the Lignomat for a gift, and it has worked real well for me. Looks like the price is about the same as the j-lite.
Offline boman1
« Reply #9 on: October 28, 2010, 10:21:10 PM »
I bought one on eBay for 35.00 it works fine for what I use it for.
Offline paul case
  • Original wearer of the PCM.
« Reply #10 on: October 29, 2010, 09:22:40 AM »
mine came off ebay about a year ago and cost $16 and shipping was free and it still works fine. pin type of course.pc
pc
Looking for a moisture meter
Started by JFarmer on Drying and Processing
Last post July 07, 2012, 04:27:11 PM
by YellowHammer
Moisture Meter
Started by Bill Gaiche on Drying and Processing
Last post July 07, 2014, 11:00:04 PM
by YellowHammer
moisture meter
Started by xlogger on Drying and Processing
Last post January 23, 2017, 05:00:13 AM
by xlogger
DIY Moisture Meter
Started by lowpolyjoe on Drying and Processing
Last post June 17, 2013, 12:45:24 PM
by lowpolyjoe
