Cabin Addition
Started by Magicman, December 21, 2010, 10:37:04 PM
Nail it up quick, before she can change her mind again....   ;D ;D
But you will do everything to make her happy.  We know.
Peter Drouin
Nice job MM, I have a [she] too, for over 30 years, and like you she can have the house any way she wants :D have fun
isawlogs
Always, always, did I mention one should always check with the boss before putting anything together, no matter how well intentioned one is, check with the boss.  ;)
   Marcel
LeeB
Quote from: isawlogs on January 10, 2013, 06:24:05 PM
And make her put it in writing. :D
Wow, you could drive a herd of elephants thru that opening (if you had any elephants, but I don't think that they are native to Mississippi.  I think that you will have to go to Texas to find some to test it out).
It is my understanding that elephants can not exist in a Sweetgum environment.  That means that I am safe, because I noticed a Sweetgum tree yesterday.
We were able to spend a couple of more days working on the Addition.
The first order of business was the A/C duct.  Since there will be a new central A/C-heating unit located in the Addition "mud room", duct had to be run which would not only service the Addition, but would also tie into the existing duct work.  I had purposefully left an overhead access to the existing duct which would also serve to house the registers for the Addition.
Two 8" ducts servicing the existing Cabin as well as the Addition.
And then have to drop below ceiling level to enter the mud room.
A 4' closet will be on the right side of the room.  The ceiling will be 8' on the left and then step down to 7' to accommodate the overhead duct.
We were also able to make good progress applying the "Pickling Stain" (white wash) on most of the walls.  This shows the Pickled wall on the left compared with the unfinished wall on the right.
Flooring should be next.
Mooseherder
Great progress.  Keep on rolling. :)
Glenn,
I heard a rumor that he might need a pecan table for the addition  :)
Mooseherder
It's only got one leg to it. :D
Besides, he wants one sans breadboard. ;D
Yep, yours might be too fancy for him  ;D.
Mooseherder
Peter Drouin
Tree Feller
Quote from: Magicman on January 10, 2013, 09:43:48 PM
You're right, MM. We have lots of Sweetgums here in East Texas, too, and no elephants. I think the Sweet Gum Balls are too hard on their feet.   :D
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Warbird
I was able to spend a few hours today on the AC/Auxiliary Heat return air chamber.
The first order of business was determining where the return air vent would be.
And then cutting the 20"X20" opening for the grill and return air filter.  Next was building the platform that will become the bottom of the return air chamber.  I should be able to complete the return air chamber and mount the air handler on the next trip.  Another small step.   :)
Good stuff!  (you made a fine mess, too!)
Well really I have a fine mess.  After the last wall gets stained, flooring will be next, so everything gets cleaned up.
I am starting to get excited because I am finally able to visualize all of the steps until completion.   smiley_thumbsup
There will be a grand "Chickin Crispin" this Spring......probably in June.   smiley_gossip digin1 food6 digin_2
Planman1954
One small step for Magicman.....one giant LEAP for Magic woman!
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
After this storm last night, we postponed sawing for the rest of the week, so that gives me a few days to work on the Cabin.   8)
Due to the roof line, etc. the mud room is 17" lower than the Cabin Addition floor, so I had to build a platform first and then build the return air plenum on top of that.  That 17" space will be used for boots, etc.
Now it was time to fabricate the two 8" outlets for the duct.
I thought my tinsmithing turned out OK.
The air handler has to go on top of the plenum, so I must do some figuring.  I can't pick it up.   :-\
I started stacking cribbing under the air handler and was getting nowhere fast.  Gotta be a better way.
Rope blocks to the rescue.   ;D
Yup, within 4" of getting there.  I am out of rope block height and I can not lift it any higher.  I need help.
That is my kind of help.  Fifteen seconds and it was sitting on top of the return air plenum.   :)
POSTON WIDEHEAD
Geeeee....what does it weigh?
Probably a bit less than 100 lbs, but there was nothing to hold on to.   Just too cumbersome to handle without help.
It is standing tall now.   ;D
fishpharmer
Air handling is tricky business, turned out well. smiley_thumbsup
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
