Tally-I/O
Author Topic: Picked up a new contraption today.  (Read 2935 times)
Offline Just Me
« on: December 30, 2010, 01:16:00 PM »
 I mentioned to a friend of mine with a circle mill that I was thinking about building my own slabber as I can't see paying what they get for a dedicated slabber, or even what an attachment costs for a swing mill. He told me about a contraption that another friend of mine had that was out in his scrap yard.
 What it is is a chop saw of sorts that was used to cut TJI's [engineered floor joist]. It is a six foot chain saw bar, driven by a 5hp 3 ph motor, with the bar mounted on a pivot. The TJI's were slid up to the stop in a stack and the bar pivoted down and cut the whole stack at one time.
 I liked the price, free, and he is going to deliver it to me on his rolloff. I just have to make him a table when I get it working and converted into a slabber. It would be good for cookie making right now, it could slice off the end of about a 4' log.
My camera was dead, but when I get it home and get some pictures I'll post them[If I can figure out how..] and get some ideas from you fellows.
Later, Larry
Offline Captain
Re: Picked up a new contraption today.
« Reply #1 on: December 30, 2010, 01:23:53 PM »
Congrats Larry!  Waiting for the pix!
Captain
Offline r.man
« Reply #2 on: December 30, 2010, 03:21:12 PM »
Nice friend and a great find. I would have loved to have had access to that machine when I handled bundles of hardwood slabwood for firewood. Sounds like it should convert easy and the price was perfect.
Offline Brad_S.
« Reply #3 on: December 30, 2010, 06:33:26 PM »
If I ever got an oppotunity to get something like you have, I would build something like this: http://www.lmsaws.com/chainsawlog.htm
I think you will need to upgrade your horsepower though.
Offline barbender
« Reply #4 on: December 31, 2010, 12:02:30 AM »
That's a score ;) I bet that was an expensive peice of equipment. Now you need a 20 horse vertical shaft engine, you should have found one at the junkyard while you were there ;D
Offline Just Me
« Reply #5 on: December 31, 2010, 07:06:55 AM »
 Its kind of like this but with more iron.
http://www.lmsaws.com/portableyard.htm
And less HP >:(
I have a larger three phase motor around, 11hp I think, may try it with that.
What about making it run off of the remote on my tractor? Enough flow? New Holland 2320 45 hp, but I know farm tractors do not have so much flow as compared to industrial equipment.
Offline sgschwend
  • My new Brand X sawmill
    • Brideck Enterprises Portable Sawmill Service, Washington
« Reply #6 on: December 31, 2010, 11:56:23 AM »
I assume you are going to turn the bar sideways and put a ripping chain on.
The bar will likely not be flat because of its own weight.  One way to flatten the bar is to place shims (outside only) under the bar ends, then when the bar fasteners are tightened they will deflect the bar into being level.
Should be a great project,
Offline Just Me
« Reply #7 on: January 09, 2011, 10:30:12 AM »
 I knew there was something out there that I could use for rails/raising&lowering mechanism that was cheap and easy to find but I just couldn't think of what it was. This morning it hit me....
A boat hoist.
Going scouting at the marina's......
Offline tyb525
  • Always learning.
« Reply #8 on: January 09, 2011, 10:41:57 AM »
I've seen those advertised in sawmill & pallet trade magazines, never seen them used anywhere but commercial mills.
Offline metalspinner
« Reply #9 on: January 09, 2011, 10:44:45 AM »
Just Me,
The boat hoist is a great idea for a railing system on a saw.  While in Michigan this past summer, I saw those things everywhere and had the same thoughts as you.  I even sized up the hoist at the families cabin to check clearances and structural needs. :D My uncle thinks used ones may be available for around a grand.
One was available here on Craigslist not so long ago, but I missed that opportunity. :(
Picked up a new toy today
Started by Busysawyer on General Board
Last post May 17, 2018, 09:39:46 PM
by Busysawyer
Picked up some Red Elm today!
Started by burtle on Sawmills and Milling
Last post July 29, 2018, 09:06:33 PM
by burtle
Picked up a new saw today
Started by Busysawyer on Chainsaws
Last post August 04, 2018, 01:07:21 PM
by thecfarm
Picked up my mill Today
Started by NHHillbilly on Sawmills and Milling
Last post May 14, 2009, 08:43:01 PM
by NHHillbilly
