Help to ID this Machinery
Started by OldIronMan, July 26, 2011, 12:58:30 PM
OldIronMan
Hi,
I'm new. Thanks for letting me play in your sandbox.  I'm an old iron history buff.  If it's old and unusual, I'll be taking a picture of it you can bet.  I came across this over the weekend in a forest.  I'm trying to follow up on a lead that it may have been used to cable logs out of the forest.  What do you think?  Do you have any information to share?   I'll be posting pics of an old saw mill for sale a bit later.  Thanks, keep up the good work here !
Work hard...play hard...
Texas Ranger
OldIronMan
OldIronMan
Quote from: Texas Ranger on July 26, 2011, 01:14:29 PM
Hard rock trencher
Excuse my ignorance, but would this be used to trench a row for planting?
Coon
Is the area you found this old iron steep hilly country? Where are you from?  Updating your profile helps us to determine many things.   ;)
BTW Welcome to the Forestry Forum.
OldIronMan
Yes, this area is hilly with a lot of swamp nearby.
Michigan, lower part.
mad murdock
what is the history of the area there?  It looks to me like maybe a piece of the main winch for a mineshaft elevator?  what are rough dimensions of the wheel? any casting marks or names or any identifying marks on any of the iron casting parts?
OldIronMan
Quote from: mad murdock on July 26, 2011, 02:22:29 PM
Marion Machine Foundry and Supply Company Marion Michigan
About EIGHT feet in diameter
I think it was moved here from somewhere else.  Look at the timbers and you can see that they were cut off at the bottom.  An elevator was my first guess, but I was thinking from a factory but you might be onto something with the mine shaft elevator.
mad murdock
with that size, I would put my money on a mainshaft, elevator tower/pulley.  They used some pretty big rigging back in the day, to make up for the non-existence of electric motors, etc.  There were a lot of mines in Michigan back in the day.  Hard rock copper mines, and I think they had some gold mines back in the day as well.
OldIronMan
Quote from: mad murdock on July 26, 2011, 03:13:06 PM
Well, nothing to do with forestry but interesting nonetheless, thanks !
Sprucegum
 8) Everything has someting to do with Forestry - look at the wood used in construction of that thing  ;)
Possibly is for mining, as mentioned.
Back in the 70's, I became aware of renewed interest in opening old mines across the US. There was interest from the Bureau of Mines in determining the residual strength of mine timbers in place for years to decide if they needed to be replaced. At the time, Bureau of Mines mentioned a gold mine in MI that was 1000 feet deep and the water being pumped out. Don't know any more about it, nor if anyone actually went into the mine after being pumped.  An estimate of wood strength can be determined using high frequency sound sent through the wood, but wasn't a reliable method at that time.
ely
it would be cool in my front yard, i could see an 8 ft picnic table in that.
Ron Scott
Are You sure that it says Marion, Michigan on it?
~Ron
Marion Machine Foundry should be Marion Indiana. I think it may be from an oil derrick and not a mine if its in the lower peninsula. I suppose it could be from a salt mine, but it would probably still be down there if it was.
OldIronMan
Quote from: Ron Scott on July 26, 2011, 08:11:20 PM
No, I made a mistake, it says Marion, IN, thank you !
Ron Scott
That's what I thought that it might say, since I wasn't aware of any foundary in Marion, MI. and the one in Marion, Indiana is pretty well known. ;) Where in Lower MI did you find it and do you know anything about the land history where it was found?
~Ron
tyb525
I drove by what used to be the foundry, on Sunday, on my way to fish. One of the many businesses that have gone under in Marion.
kelLOGg
You must have relocated it and cleaned up the iron - it looks refurbished. I don't see any trees growing up through the spokes. ;)
OldIronMan
Quote from: tyb525 on July 27, 2011, 06:03:21 PM
I think it would be interesting to see the inside of the foundry anyway.  How was the fishing?
OldIronMan
Quote from: kelLOGg on July 28, 2011, 05:08:58 AM
Yes I think someone relocated it years ago.  I know it's been in this spot for the past 30 years anyway.  It's sitting on a power line hence the lack of trees under it.  For the iron, I think it has a high percentage of iron and low in carbon, much like wrought iron which doesn't rust as much as the metal you see today.
mad murdock
Prolly the same Marion of steam shovel fame?  I bet so.
timbuck2
Early Timberjack wheel???  ha
Ron Scott
With the Marion foundry famous for is steam shovels and now out of business, I'd say that it is the winch wheel from one of their early stream shovels.
~Ron
shelbycharger400
all that old metal   has very high content of nickel and magnesium.    some of the best alloys .   now a days is basically "good" but not .              i remember reading a deal about the ww1/ww2 tanks.  the alloys were such that you had a very hard time torch cutting them ect,  were so hard , and thick that it was cheaper to sink them off the coast.       also,  noted that 1960's and back, automobiels, most scrap yards cannot send them through their shredder, its along same deal.
