Dynamic Green Products Inc.
Author Topic: my acme band saw blade (captive needle bearing )roller blade guide  (Read 2522 times)
Offline buildthisfixthat
the set up is fully adjustable
shop built bandsaw mill
Offline beenthere
Re: my acme band saw blade (captive needle bearing )roller blade guide
« Reply #1 on: January 13, 2012, 07:57:24 PM »
Just not sure what all is in that pic. A backup bearing for the blade I see. What is above and below the blade?
Offline bandmiller2
« Reply #2 on: January 13, 2012, 08:15:06 PM »
Looks like its lifting the band and not pushing it down the 1/4" that is usual practice,suppose it would work the same.It dosen't lool like you  could cut a 1" last board,too much bearing below the band. Frank C.
« Reply #3 on: January 13, 2012, 08:52:08 PM »
ahh good observation  bandmiller ..actually i just noticed that after loading the photos however that is one of the benifits of my dual bearing guide ,stableize the blade by means of support on both sides of the band and also the backup bearing ,ill try to get some better pics of the bearings with the blade removed
« Reply #4 on: January 13, 2012, 08:55:33 PM »
                                               each needle roller bearing is 1" dia on a shaft and 1-1/6 wide rideing on the blade
Offline customsawyer
    • The Custom Sawyer
« Reply #5 on: January 15, 2012, 09:53:24 PM »
As long as it works for you.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline bandmiller2
« Reply #6 on: January 16, 2012, 07:27:05 AM »
Almost anything is forgiven as long as the lumber comes out true and straight,usally several ways to do something on a mill,but it seems theirs a best way too.My homebuilt guide system has a small hardened pad under the band only about 1/2" so I can cut down to a one inch board and clear the bunks.I not really sure support under the band is needed,if you hit tramp the band is going to go where it wants, a keen well set band will cut true.Frank C.
Offline 5quarter
    • Blue Harbor Refinishing
« Reply #7 on: January 16, 2012, 09:34:15 AM »
Looking at your picture, it appears that the needle bearings extend over the teeth. How does that affect your set? can't tell if they're tapered...
   Bandmiller2...You're right. a lower skid plate or bearing isn't needed to make straight lumber, but it will minimize the severity of a dive or waves through knots.
WM blade guide roller upgrade...
Started by ElectricAl on Sawmills and Milling
Last post September 06, 2002, 06:26:04 AM
by Bibbyman
roller blade guide adjustment
Started by postville on Sawmills and Milling
Last post June 04, 2011, 07:47:54 PM
by tyb525
blade guide bearing&frozen sawdust
Started by 47sawdust on Sawmills and Milling
Last post November 18, 2019, 07:44:04 PM
by Stephen1
Wore a flat on my blade guide bearing
Started by kelLOGg on Sawmills and Milling
Last post May 01, 2012, 09:04:02 PM
by laffs
