Author Topic: Logosol ph260 question  (Read 1450 times)
Offline cubdriver55
« on: January 17, 2012, 07:04:31 PM »
I was wondering if anyone had a ph260 in single phase. I was wondering how well this unit works with single phase. I understand the 3 phase units are much smoother on the feed system. I have 3 phase but I found a used single phase unit for sale and I was wondering if I would be better off waiting for a 3 phase unit?
Offline cubdriver55
Re: Logosol ph260 question
« Reply #1 on: January 17, 2012, 07:12:10 PM »
Also does anyone know of any used 3 phase units for sale?
Offline logloper
« Reply #2 on: January 17, 2012, 08:56:15 PM »
We have a single phase, and it works good. We saw 1x6 and let it dry 2-3 months. Then we skip plane it through one pass. Then we set up our moulding blades and run it through the final pass. It will keep 2 people busy. Thats doing fir, aspen, and pine.
Offline sherpa
« Reply #3 on: January 18, 2012, 08:05:04 AM »
I have the single phase 260 and have had it for 6 years.  It is underpowered for wider hardwood, but works well for softwood.  About 90% of my business is running cedar and pine v matched tongue and groove, bead board and 1/4 log siding 4, 5, 6, and 8" widths.  Works great for this application.  I saw all my lumber to 1" and have no problem running it through in one pass.
Hardwood flooring which is about 10% of my business, I saw to 4/4 and pre plane down to 15/16" before putting through the Logosol.
Offline FeltzE
  • Fayetteville NC, Stop by and visit some time!
    • Feltz's Sawmill
« Reply #4 on: January 20, 2012, 04:01:12 PM »
I have a PH261 single phase. It's underpowered in my opinion on the top and bottom planer heads, but a good machine.
I have to preplane 4/4 stock prior to running for 3x4 running 6 inch wide syp in t&g applications, The feed tends to stick a bit if you have any ragged edges or ends.
Consider a larger 3 ph machine if your doing a lot of work. If you want to see one run come visit me, I need to set up and run some stock anyway.
IMO
Eric
Logosol PH260 question
Started by WLC on Drying and Processing
Last post December 04, 2016, 09:47:20 PM
by shakebone
Logosol PH260
Started by logloper on Drying and Processing
Last post February 17, 2011, 09:10:54 PM
by AvT
First run on logosol ph260
Started by MikeH on Drying and Processing
Last post July 16, 2007, 02:27:58 PM
by Dodgy Loner
Logosol PH260
Started by boardmaker on Drying and Processing
Last post September 25, 2014, 10:05:51 PM
by scsmith42
