Kohler 25 speed adjustment
Started by postville, February 05, 2012, 06:32:56 PM
postville
How do you adjust the engine speed on the Kohler 25?
I want to slow it down a little. Bob
LT40 25hp Kohler, Gehl 6635, Valby grapple, Ford 4600, Farmi winch, Stihl saws
Meadows Miller
Gday Bob
I take it you are wanting to adjust the full rpm speed a little Ill take a look at My 30hp Kohler on the Lucas as It runs at 3600rpm wide open if its like the other motors I have adjusted it should just be a set screw with a lock nut on the throttle linkage I take it you only want to drop it a couple hundred rpm and what type of mill is it on Mate ;) ???
Regards Chris
4TH Generation Timbergetter
postville
LT-40. Sawing frozen wood and was recommended to slow the band speed down. Bob
MartyParsons
Hello,
I have attempted to slow the engine RPM down and lowering the Surface Feet Min. with just the adjustment of the governor. I found out that when this happened I changed the RPM and SFM but had no power at this RPM. So the correct way would be to change the pulley to get the correct SFM and keep the engine at the max torque rpm.
Just my opinion.
Marty
