A day of firsts!
Started by Nomad, April 23, 2012, 09:41:18 PM
Nomad
     Got to the current jobsite this morning and found out my mill had somehow been rotated about 30 degrees overnight, knocking it off a pad supporting one side to level it. ???  It needed a shoehorn to get it in there.  No damage, but it took us more than an hour to get it leveled out again.  Couldn't see any evidence or possible way that could happen, but it did.
     Up til now I've taken great pride in having good situational awareness and never having sawed into my mill.  This morning, (with 6 witnesses!) I tried to saw through a backstop. :-[
     I've also never rolled a log off the backside of the mill.  Until today.  An hour after I sawed the backstop, In front of the same 6 witnesses, I did just that.  I said things like "My Goodness" and "Dear Me." >:(
     Well, tomorrow is another day.  I just hope none of those same people come by to watch the show! :D
WoodMizer LT50HDD51-WR
Lucas DSM23-19
pnyberg
I've ruined a blade on a backstop several times.  So far, I haven't rolled a log off the back side of the mill, but in one case it was only because the log wasn't round enough to roll that far.  I've worked hard on establishing a habit of putting the backstops all the up and the clamp all the way out before lifting the loading arms.  Once in a while something interrupts the flow...
--Peter
No longer milling
cypresskayaksllc
That fair I demonstrated at couple weeks ago I had a log roll off the back side. with about 20 people watching. 1st time thats happened. I had to laugh myself on that one.
LT40HDDR, JD950FEL, Weimaraner
fishpharmer
Nomad, don't worry........
you probably won't hit the backstop ever again, until you have at least seven people watching. ;) :D
At least that's my luck.
Are there cows or any other large animals with access to your mill?  They may have bumped it, If not, must be some haints :o
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Sawmill Man
Maybe my day wasnt as bad as I thought.
"I could have sworn I went over that one with the metal detector".
I always say,just want to show you want not to do.    :D
I have had cattle to do some bad things to the sawmill at night.   :-\
The other bad things were mine.   ;D
Bogue Chitto
I rolled a log off the backside of my mill. 2000 lb log.  It was after Christmas, my son left his new Christmas gift bike by the mill.  Never the less I had to run to the bike store to get the 4 yr old a new bike.  The log made it look like a pancake. ::).  By the way son was no where near mill while it is in operation.
Chuck White
I have had (if I remember right) 2 logs roll off the back side of the mill since I've owned it.
I figured that during the milling of over 300,000 board feet of lumber, that's not too bad!
Last week while sawing on a White Pine job, the back stops weren't down as far as I thought they were and I ticked the point of the first one, just enough to remove some set, but the blade cleared the second one and finished the cut!
Just a few of those things that "come with the territory"!
customsawyer
Nomad that is all just part of being a good sawyer. You have to show every one how you can deal with difficulties. ;D
www.thecustomsawyer.com
Nomad
     Yeah, this particular job is not one of the easy ones.  Lousy log pile, nails, etc.  This time it seems as if I've either got Too much help or not enough, but the only one worth his salt is a retired West Virginia coal miner.  (At 73 he's working the logs' owner into the dust.) :D
     No critters around at this place, although I've had cows get curious about the mill in the past as well.  I still haven't figured out what moved the mill.  No tracks in the sawdust around the mill except mine, so I have no idea.
Lucas DSM23-19
TreeWinder
I'd figure a way to chain it, maybe early attempt to steal it.
Ed
041 056S 056M
MS660 070 084
CS670
Baker 18M
Komatsu D-21-P ,
Speeco 35T
pineywoods
I am still with Phish.  Must have been haints.
okmulch
I figure you might as well get it all out of the way in one day! Hopefully it is smooth sailing now.
Rotochopper b66 track, #2 Rotochopper b66 track, woodmizer lt40, CAT 277b, CAT 268b, CAT 287c, CAT 277c, CAT299d2, CAT299d3, CAT 299d3, Volvo 70e,volvo70f, volvo90f, Tigercat 724g feller buncher
nas
95% of band sawyers say they have hit a backstop....  The other 5% are liars :D
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
bama20a
Quote from: nas on April 26, 2012, 02:06:34 PM
Had my mill for several weeks now & havn't sawed the first log yet :'(Did order blades yesterday,So the first thing I'm going to do is,Raise the back stop up,saw it with a brand new blade & get that over with ;D 8)
It is better to ask forgiveness than permission
Nomad
     Fish, Danny, maybe you're right :o  Got to the site today and there's an estate sale in progress.  Turns out the owner passed away a month or so ago and this is his kid moving in.  I didn't know that.
     He was only in his 60s and had health problems for awhile.  He died in the house.  He REALLY liked his trees.  According to the old coal miner he was also a practical joker!
     I'm not real big on haints.  But now, if nobody minds too much, I'm gonna break out my Ouija board and maybe think about sacrificing a chicken too (just in case...) :D
Lucas DSM23-19
Dave VH
I have a home made track under my mill, and I have probably rolled a dozen logs off the wrong side.  Most of the time my boys are watching, and laughing at me.  Oh well my track is only 4 or 5in off the ground, so no big deal
I cut it twice and it's still too short
I had another "first" today.  I have had many blades to break, and some of them in two different places.  Today's break was in two different places, and an 18" section of blade landed on the ground to the right of the loader and probably 10' from the sawmill.  I had just engaged the clutch and was about a foot from the log end when it broke.
