Author Topic: American Elm, twig dropping question.  (Read 6218 times)
Offline chainspinrunner
« on: May 07, 2012, 06:18:21 PM »
I have an American Elm on the property about 23in. dbh, and about 75 ft. tall. The tree has an outstanding shape and crown, but this spring the past few weeks, the tree has been dropping twig ends. About 6 inches of the ends of the braches which are woody. The break is not clean and the leaves are still very green. The tree has just started leafing out in the past two weeks and is dropping this new growth everyday. I understand that the Dutch Elms Disease discolors leaves and this is why I am not sure of why this is happening. There has been previous elms taken down on the property, but none close enough for root grafting. The Grey squirrels have been up in the canopy, but I can't reason why they would 'snip' a twig end off. The trunk is clean and no visual signs of fungus, disease, etc... Also the tree doesn't have any deadwood in the top either. I am going to try to research this some more and pinpoint the reason for dropping the twigs. So we can either save the tree or remove it before it causes damage.
Grose
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: American Elm, twig dropping question.
« Reply #1 on: May 07, 2012, 09:52:33 PM »
I am interesting to see what you find out.  Sounds like something is chewing them off.
Offline chep
« Reply #2 on: May 08, 2012, 08:39:53 AM »
 Good to read you here g. Pictures of the twig would be helpful! Dutch Elm disease generally shows up as more then one dead leaf. The whole branch will die (called flagging). It sticks out pretty quick. I wouldnt go bucking the tree yet.
  My first instinct is to make yourself some squirrel pie. Know what Im sayin? Go get em dusty
« Reply #3 on: May 08, 2012, 05:12:05 PM »
 Chep, glad to hear from you also my man. I hope you are still at it just as I am! We need to connect soon and catch up. The squirrels are my #1 target, found it happening on a Sugar Maple not far from the Elm. The leaves on both are still very vibrant and green, the twigs look like they have been chewed by something probably climbing varmints. The property I am working on is a sanctuary and i wouldn't be surprised if squirrels are the target. heh. I will keep my eyes out and let you know.
Grose
Offline SwampDonkey
  • Large Tooth
« Reply #4 on: May 08, 2012, 07:01:14 PM »
Squirrels is my theory. They clip red pine bows here and spruce for the cones and also chew sugar maple bark and twigs in the spring and lick the sap flowing down the stem. Seen them with my own eyes. There has been one real busy squirrel here this spring along with the dang darn sap suckers (often 4 at a time on a tree) and they are both mouthy varmits when you intervene. :)
Move'n on.
Offline WDH
« Reply #5 on: May 08, 2012, 08:14:58 PM »
Mouthy varmits?   :D :D
Offline ArborJake
« Reply #6 on: May 08, 2012, 08:30:29 PM »
Tree rats that's what I call um. They chew the bark of off Norway Maple around here all the time. I had one run right down my back in a tree. I've also seen them fall 20-30 ft. They usually sit for a while and then take off like nothing ever happend.
thick and thin lumber company. qaulity manufacturer of saw dust and slab wood.
Offline Clark
« Reply #7 on: May 09, 2012, 10:12:05 AM »
Here's a really bad answer:
I recall a professor in college telling us about one of his yard trees and I want to say it was an oak, dropping twigs like you are talking about.  At the time he was teaching a bugs and crud class I was in but he was more concerned about us learning scientific names (past and present) of the various bugs and diseases than the practical ID and management of them.  Plus he had a thick German accent which was difficult to understand.  All of which means I didn't learn a whole lot there.  Back to the story...he said the solution was to collect the twigs and burn them.  Some insect was in the tree and the grubs would bore into the twigs and then cut themselves and the twig free of the tree as part of their life cycle.  Your story reminds me of this professor's story.
For the life of me I can't recall what the insect was.  If you suspect that the damage could be done by an insect or you're able to find a grub/larva in one o fthe twigs I would take a picture of the it and send to a University or Extension bugs and crud person.  They should be able to set you right.
Then again, it may just be squirrels!
Clark
SAF Certified Forester
Offline WDH
« Reply #8 on: May 09, 2012, 08:43:25 PM »
The twig girdlers are bad to cut off the twig tips in hickory, but the cut end is very neatly done with a perfect cone -shaped cut ring around the twig to the point that the twig breaks off.  There is some jaggedness at the break point.  Do the twig ends look like this?
http://www.ces.ncsu.edu/depts/ent/notes/O&T/trees/note96/twigg5a.jpg
Here is a website that describes twig girdlers.  The longhorned beetle is the most common girdler.
http://www.ces.ncsu.edu/depts/ent/notes/O&T/trees/note96/note96.html
Offline Ron Scott
« Reply #9 on: May 15, 2012, 06:35:50 PM »
I would say that it's the squirrels cutting the twigs which they do often on my maple yard trees.
~Ron
American Tree Farm Question
Started by Jeff on Ask The Forester
Last post January 18, 2010, 10:03:17 AM
by Samuel
question
American Loggers TV Show Question (anyone from Maine or who knows)
Started by Rednecklogger on General Board
Last post August 19, 2013, 10:28:55 AM
by Rednecklogger
guess this twig
Started by redpowerd on Forest Education
Last post May 25, 2004, 05:49:18 PM
by Minnesota_boy
sad
Walnut Twig Beatle (WTB)
Started by metalspinner on Forest Education
Last post October 13, 2010, 01:09:26 PM
by Autocar
