Mounting a Husky Rim Sprocket, Which way does it go?
Started by JOE.G, July 17, 2012, 09:05:04 PM
JOE.G
Just wondering if it matters which way the Sprocket goes on, Writing toward the saw or vents or what ever they are toward the saw? thanks
P.S I have heard different opinions on this.
Husqvarna 562XP Woods Ported .025 pop up MM
Husqvarna Rancher 55 2005
Husqvarna 450 Anniversary Edition 2010
STIHL 009 1998
STIHL HT 131 Pole Saw 2012
STIHL FS 110 R Trimmer 2010
STIHL BR 600 Magnum Blower 2012
Caloren
My Stihl manual says the 'vents' as you called them, go on the outside. I believe the Oregon instructions say the same thing.
Loren
Stihl MS 170, Stihl MS 310, Stihl 028 AV Super, and half a dozen other no-accounts! Cat D4 D.
JOE.G
I didn't quite know what they were called, So Writing goes in toward the clutch drum, When I buy the Husky ones They don't come with anything.
STIHL 009 1998
HolmenTree
Quote from: JOE.G on July 17, 2012, 09:05:04 PM
Joe those "vents" are called ports, sounds like you have a 8 T 3/8 rim. Their purpose is to expel wood chips/debris from the sprocket and also promote cooling.
Always face the ports away from the clutch drum whether it's inboard or outboard clutch design.
JOE.G
Ok Ports out writing toward the drum, I think it is a 7 tooth 3/8. When Rim Sprocket is on saw I should see the ports.
STIHL 009 1998
HolmenTree
Quote from: JOE.G on July 19, 2012, 07:38:40 AM
All the 7T 3/8 rims I get now a days are radial port design [ ports on the edge of the rim where chain runs on.] My 8T rim's ports are on the side.
JOE.G
Maybe I got a old stock, I am pretty sure it is stamped on there 7  3/8, I can count them also, I know it is a Husky OEM Sprocket. I may be wrong but I ll check. I remember when I got it a couple day's ago I even asked the dealer about the 8 tooth and he said I wanted the 7 for the Rancher.
STIHL 009 1998
