Author Topic: How to mount this cabinet?  (Read 4284 times)
Offline Brad_bb
« on: September 29, 2012, 01:41:45 AM »
I recently purchased this vintage mail/paper sorting cabinet for my office.  I have removed the door and plan to mount it on the wall at eye level.
The problem is how to mount it to the wall?  Here is where i plan to mount it.  The vertical tape represents the studs in the wall(actual 2" rough doug fir).  They are on 16 inch centers.  The horizontal tape represents the width of the cabinet (21.5 inches).  As you can see, the cabinet would only cover one stud.  The cabinet weighs 70lbs.  I considered a french cleat, but that would make it stick out from the wall a bit.  Any good ideas?
Should I just mount it to the one stud?  What type of hardware?
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: How to mount this cabinet?
« Reply #1 on: September 29, 2012, 03:14:31 AM »
Since it only covers 1 stud, have you considered building a nice decorative shelf that covers 2 studs and then set your antique on the shelf?
Building a shelf and staining it to match your piece IMO would look really great.
Offline SwampDonkey
  • Large Tooth
« Reply #2 on: September 29, 2012, 03:49:36 AM »
A shelf would probably be best, as with any bracket you would be drilling into the cabinetry to mount it.
Something like a slip past bed rail fastener would have to be screwed to the side.  The wall bracket would be screwed length wise with the stud. Most other ideas I see would straddle the stud with screw holes on other side of it.
Move'n on.
Offline beenthere
« Reply #3 on: September 29, 2012, 09:07:57 AM »
I think I would put a angle shelf bracket upside down (and screwed to the stud) to catch and support the weight at the bottom of the cabinet, and then put a screw at the top of the cabinet into the stud to hold the top.
This all dependent on the construction of the cabinet itself. And maybe if you can center the cabinet on the stud.
Offline Tree Feller
« Reply #4 on: September 29, 2012, 11:09:50 AM »
You might be able to use flush mount hangers top and bottom on the single stud, depending on the weight rating.
That's what I used to hang the Flag Case/Shadow Box I posted here, although they were placed on 5/8" Pine paneling. The flush mount look is what I was seeking.
There are lots of brands/types of flush mount hangers. Rockler, Woodcraft, Lee Valley and even Home Depot carries them.
BTW, that cabinet is a really neat piece of history. I love it.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Offline clww
  • Oh yeah? Watch this!
« Reply #5 on: September 29, 2012, 12:38:16 PM »
I would find/build another cabinet-type base for it to sit on. I'd go for something wider, so you can center it up.
Many Stihl Saws-16"-60"
18-Wheeler Driver for CFI
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #6 on: September 29, 2012, 04:36:15 PM »
If a hardwood french cleat is too thick could you use aluminum down to 1/4" thick, countersunk screw heads?  if you don't want to open up the drywall to put in some kind of horizontal backer, you could use two of those screws with expanding wings one on either end of the cleat, behind the drywall.  I would think if the limit is 70 pounds that wouldn't be too heavy esp. if the cabinet is pretty much centered on the one stud.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #7 on: October 03, 2012, 12:23:57 PM »
Use some sheet metal and bend a offset like a Z and make the stud mounted plate in shape of triangle with mounting holes verticle. Then make horizontal mounting plate fastened to back of cabinet, you will have a little bit of slide adjustment side to side. If there is too much of gap in back of cabinet to wall, you could tack a small piece of filler trim around back or side of cabinet.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
« Reply #8 on: October 03, 2012, 04:17:26 PM »
I would second the table. Not much wider but deeper front to back. That would give a sorting/reading area.
Bill
Offline hackberry jake
« Reply #9 on: October 03, 2012, 06:50:50 PM »
It would depend on the construction of the cabinet. Is it solid wood? If so what species? Plywood? If so how thick? I would probably just predrill and use two small lag bolts through the back of the cabinet into the stud. If the construction is stout enough. Good call on removing the cheesey door.
Offline samandothers
« Reply #10 on: October 03, 2012, 07:03:43 PM »
x2 on the french cleat.  Maybe two.
Offline Don_Papenburg
  • I need money
« Reply #11 on: October 03, 2012, 11:24:30 PM »
How about some short dark feet that would let it rest on the radio and not be too conspicuous?
Offline Lud
  • Impetuous.... Homeric....
« Reply #12 on: October 04, 2012, 07:26:28 AM »
Seventy pounds is kind of heavy for wall mounting.  How about a standing desk wide enough to straddle the radio.   Inch and a half long legs coming up to a chest high desk with a shelf or two deep enough support the file rack.  A slanted lid that folds out to a flat desk would not have to be that deep to be useful. 8)
Offline Brad_bb
« Reply #13 on: October 12, 2012, 01:47:28 PM »
Lud, I haven't done anything yet.  Can you post a napkin sketch so I can be sure I understand what you are envisioning?
Thanks, Brad
Offline Lud
« Reply #14 on: October 13, 2012, 03:59:43 PM »
I don't capiche " napkin sketch"  ( tho I have drawn a bit in bars!) :D
Online PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
« Reply #15 on: October 13, 2012, 06:44:54 PM »
... tho I have drawn a bit in bars!...
Well, I was drawn into bars quite a bit early on during my time in the Navy, but that's a whole 'nother story.  :o
Herb
Offline Brad_bb
« Reply #16 on: October 17, 2012, 01:05:56 AM »
Just a quick hand sketch, nothing fancy, no sketch up or 3D cad.
Offline Lud
« Reply #17 on: October 18, 2012, 08:04:09 AM »
...........and take a pic of the drawing and post that?  OK.   I can do that.  I thought you were naming some 'puteree stuff. ;D
Offline Lud
« Reply #18 on: November 03, 2012, 09:05:23 AM »
Hey Brad,  here's your napkin sketch.  Sorry it took so long.
Hope you can see how the standing desk straddles the radio and supports the file box.   Flipping out the slanted lid would give you a writing surface...possibly covered with hard leather and could have some cubbies like a roll-top for pens, etc.
Good luck!
Offline learner
  • Learning and passing on what I know.
« Reply #19 on: November 03, 2012, 09:55:31 PM »
Use 4" by 2" L-brackets. Cut into the wall enough for them to be screwed into the studs flush with the wall. One on top and one on bottom. Drill extra holes into the l-brackets for needed additional support screws.
Both brackets will support the weight of the cabinet, it will be flush with the wall and should support an additional 70lbs weight.
Use 4" by 4" brackets for additional strength. Judging by the height you will be hanging it at, the brackets should be hidden. Use 3" dry wall screws and you should be able to Dance on it with NO worries. From the looks of the top and bottom board thickness, a couple of 3/4" screws will hold it firmly to the wall.  Go half inch is the boards are thinner and you should get the same support.
WoodMizer LT40 Super Hydraulic, MF-300 FEL, Nissan Enduro 60 forklift, 2 Monkey Wards Power Kraft Radial arm saws, Rockwell series 22-200 planer, Prentiss 210 loader
front mount or rear mount snowblower
Started by glassman_48 on General Board
Last post January 11, 2018, 05:58:07 AM
by glassman_48
My mount for a deer mount
Started by Weekend_Sawyer on General Woodworking
Last post May 05, 2012, 06:53:44 PM
by barbender
Bob Cat Mount
Started by Bill Gaiche on General Woodworking
Last post February 22, 2015, 08:51:50 PM
by clww
Never seen a mount like this but I LIKE it!
Started by POSTON WIDEHEAD on The Outdoor Board
Last post August 11, 2018, 07:01:28 PM
by barbender
