Author Topic: Table finish.  (Read 918 times)
Offline 240b
Table finish.
« on: November 30, 2012, 11:55:23 AM »
I am building a new table for the kitchen. The top is two pieces of ponderosa pine. the pieces are 22"x93" they were kiln dried.  Any thoughts on a durable matte finish? Trying to stay any from anything shiny.  thanks
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Table finish.
« Reply #1 on: November 30, 2012, 11:04:39 PM »
If you do not use some type of varnish, the finish might not hold up.  I would check with Sherwin Williams.  Their alkyd varnish is very good, and you can get it in a satin finish, but that might still be too shiny for you.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Table finish.
« Reply #2 on: December 01, 2012, 07:09:32 AM »
i've really come to like a hand rubbed finish of comprised of on part each boiled linseed oil, spar varnish, and mineral spirits
lots of dull bands and chains
Offline T Welsh
  • Woodmizer LT-40-HD http://www.welshtreeservice.com
    • Welsh Tree Service
Re: Table finish.
« Reply #3 on: December 01, 2012, 07:23:17 AM »
I have been using Tung oil for years now and love it. I am a natural finish type of guy! But being a table top it needs a protective type of finish as in poly or varnish.Both come in satin and you can put on numerous coats. Tim
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
Re: Table finish.
« Reply #4 on: December 01, 2012, 09:38:26 AM »
I have used "Bona Traffic" floor finish.  It's a two part water bourn finish that is self leveling and is very easy to work with.  It wears like iron and you won't get water rings from glasses.
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline Tree Feller
Re: Table finish.
« Reply #5 on: December 01, 2012, 12:11:06 PM »
I would use a polyurethane finish just for the durability. If satin is still too shiny, you can always knock down the gloss with sandpaper.  Experiment on some scrap to find the grit that gives you the look you want.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Table finish
Started by Brad_bb on General Woodworking
Last post July 03, 2012, 07:51:52 PM
by Tree Feller
Trying to decide on a finish for a table
Started by Crusarius on General Woodworking
Last post April 06, 2021, 08:31:03 PM
by Crusarius
what type of finish on a table top
Started by Randy88 on General Woodworking
Last post February 06, 2016, 07:13:07 PM
by tule peak timber
Restaurant table finish options?
Started by wildbill on General Woodworking
Last post February 02, 2016, 09:46:44 PM
by POSTON WIDEHEAD
