Busted our Wood-Mizer
Started by Bibbyman, December 03, 2012, 04:58:51 PM
Bibbyman
Over 5500 hours, 10 years and a couple million board feet sawn, something has to give out. This adjustment bolt broke because nut in bed rail was pushed in.
This was the major damage – nut weld cracked and nut pushed in.
I straightened up the nut and welded it back in and repaired the cracks and puddled the dent full – thinking it would re-enforce it. New bolt was made by taking a standard hex head bolt and welding two heavy washers on the head.
I discovered the damage a day or two after sawing this big red oak log.  It was  10' long and some 30" dia.
Pretty nice log.  Squared down to 18"x18".
If the repair lasts another 10 years and two more million board feet,  I won't complain.
Sawing since '94
MotorSeven
Wow, what a cheap piece of garbage....WM should be ashamed :D ;D
I am still amazed at how much punishment a mill can take and still cut perfect boards :)
WoodMizer LT15 27' bed
QuoteIf the repair lasts another 10 years and two more million board feet,  I won't complain.
If it don't we'll know who to blame. ;)
POSTON WIDEHEAD
Now you're gonna have me looking at my little bolts.  :)
Good thing you could fix it in-house. Probably not much down time.
Good job Bib and Mary!  smiley_thumbsup
Bibbyman
I don't want to brag on it because you know what happens. But I'm constantly impressed at the use, abuse,neglect and punishment this mill has taken over the years.
The souped up hydraulics has to push everything harder.
It seems when you turn the big cants, the back end pushes up high and then drops hard.  Back in my younger days I could figure the impact of a cant dropped from a foot off the bed.
Sawing since '94
Ljohnsaw
How big is your electric motor?  I'm assuming 240 service.  Is it running the blade as well as your hydaulics?  Do you feel it is too small, just right or over sized?
Thanks,
John Sawicky
ronwood
Bibbyman,
Is there a bolt missing in the first picture Upper right hand corner?
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
customsawyer
Bibby I am with you. The fact that I overload my mill every day and that it holds together simply amazes me.
www.thecustomsawyer.com
Bibbyman
Quote from: ronwood on December 03, 2012, 06:41:47 PM
Bibbyman,
Ron
I'd already taken it out before taking the picture.
Sawing since '94
Bibbyman
Quote from: ljohnsaw on December 03, 2012, 05:50:27 PM
Thanks,
25 HP 3ph. 220v single phase running a Ronk phase converter. Big enough.
Power pack hydraulic pump has 7.5 HP 3ph motor and produces 6 gpm @ 2000 paid.  Moves things right along.
Sawing since '94
MReinemann
Thought you busted it.  Looks like a maintenance item to me.   :)  Nice work with the repair.
-Matt
drobertson
bibby, as a show me kinda guy, I am real proud of you!  thanks for the post.  david
You should be OK.  When I bought my sawmill, it had been used sawing cants at a commercial sawmill.  They regularly loaded it with the sawmill loaders, sometimes dropping the logs on the bed.  The swing arms and bolt underneath had really taken a beating, and some welding and building up was necessary.
Solomon
Judging by your pictures Bibby, its time to start shoveling some saw dust. smiley_inspector
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
POSTON WIDEHEAD
There's probably Hundred Dollar Bills mixed in that sawdust.  :D
Bibbyman
Quote from: Magicman on December 03, 2012, 08:43:45 PM
There is nothing harder on equipment than letting someone run it that doesn't own it.
Sawing since '94
clww
Glad to see you got her fixed up quickly, in-house, Bibby. You'll have to keep Mary from abusing the equipment so much. :D
Many Stihl Saws-16"-60"
18-Wheeler Driver
waho
Bibby, what are you using the phase converter for?
Bibbyman
Quote from: waho on December 03, 2012, 09:19:05 PM
We only have single phase electric service.  The motor on the mill is three phase.  The phase converter takes in single phase power and produces three phase.
Sawing since '94
waho
Thanks, that's what I thought. A few post's up you said 25HP 3 ph. Had me confused.
waho
Never mind the last post. Can't read.
Chuck White
Good fix Bib!
Another couple of million bf and you'll probably have to do it again!  ;D
paul case
Quote from: Solomon on December 03, 2012, 08:54:39 PM
I kinda think he is ok for a while.
You should see the mess under my lt40. I have had to rake out from underneath the turner and clamp and bottom rail near the axle 3 times just to keep going. I probably have a 15yard dump truck full of bark and sawdust under and around my mill. Yep I need to clean it out, but anyone can look at it and see it works. ;D
Bibbyman,
Glad ya got it fixed. PC
pc
Twentyfive three phase is considerable overkill. [no harm though]I've got a 15hp three phase running the band and hydraulic pump.The motor never gets more than warm.If I recall the LT-70 ,I ran, also had 25hp.Woodmizer engineering is a cut above most,if you break something blame the guy that watches you shave in the morning.Bibbs is right an owner/operator is the best sawyer. Frank C.
moosehunter
Bibby, is that sag in your live chain just from wear or did something happen to it? Is there any problem with it binding like that?
mh
Higher than my expectations
