been eyeballing a tk 1200 add
Started by m wood, December 18, 2012, 08:48:59 PM
m wood
havent been able to get a response from advertizer yet, so no detailed info on THIS mill.  I found ONLY ONE youtube video of an older 1200 that was modified to a power feed.  dont care about that right now...but can that crank handle feed be by-passed to a simple push/manual feed?
thanks
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Meadows Miller
Gday
Should be easy enough if you want manual feed to take it of either just remove the rope or chain you could just unbolt the whole show Mate  ;) I take it  the one your looking at is S/Hand and has the crank feed on it   ???
Regards Chris
4TH Generation Timbergetter
LeeB
You can push it by hand easy enough. I would leave the handle on though. I used to have one and used it for about 6 years before upgrading to a bigger mill. They are good little mills and I cut a lot of wood with mine. I would use the crank to saw and pull back by hand for the next cut. The crank gives you a lot of speed control when going through knots and such. I also just pushed by hand about as often as I used the crank.
