McGill cam follower number for track
Started by mmartone, February 17, 2013, 10:14:34 PM
mmartone
Anyone know the McGill number? Theres lots of these on Ebay and I'm going to replace all six of mine as well as the guide bearings and upper blade bearing.
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
Bibbyman
Have you looked in you're Wood-Mizer parts manual?  Often times they list manufactur and part number.  May get lucky.
I've got some new ones but not going back out tonight.
Sawing since '94
mmartone
Had a look but it appears that they make many different 1 1/2 cam followers...
I did some searching once to try to beat the WM price for the cam followers.  The end result was the same as it has always been.  I get my replacement parts from WM.
Bibbyman
A couple of months back I spotted an ad on eBay for cam bearings sold by Wood-Mizer with Wood-Mizer part numbers.  The same guy had Wood-Mizer guide rollers.     All were were at a good price.   I should have bought the lot but him-hawed around until all but two of the guide rollers were gone.  He had marked them down to about half of new cost.   I got them ordered and in a couple of days they were delivered packaged in Wood-Mizer padded envelopes.
Sawing since '94
Kinda makes you wonder whether they were "back door" items??
Bibbyman
The person selling the parts was north of Kansas City.  I can see were these may be spare parts no longer needed if he sold an LT40.
Sawing since '94
drobertson
this makes sense, someone that planed ahead, maybe did'nt figure on selling out,  the last set I got was made by Carter, 16.39ea. they have held up quite well, only drawback it the slot head rather than the hex head. Not a real prob, just a difference in tools required for installing,
When I sold my Kubota the spare parts went with it.
Bibbyman
Maybe overstock?   We have 6, count them, 6 new forward/reverse and up/down switches! Four of one and two of the other.
Why?  You may ask.  About every time we go to a Wood-Mizer event, Mary would get another pair!  "We may need one and I couldn't remember if we had a spare. "  She wouldn't consult me.
We haven't used a new one in years.  I just keep refurbishing the old ones.  New ones are over $100.00!
Sawing since '94
I may have one to break tomorrow, but I do not have any spare drum switches.  Last year I called WM to order them but recanted after being told the price.  If one breaks, I'll just take a couple of days off.   ;D
I do carry the power and hydraulic solenoids.
Quote from: drobertson on February 18, 2013, 09:11:05 PMthe last set I got was made by Carter, 16.39ea.
Forgot to ask, how about some more info on the Carter cam followers?
Bibbyman
Quote from: Magicman on February 18, 2013, 10:43:15 PM
https://forestryforum.com/board/index.php/topic,24023.msg352296.html#msg352296
Check out post #11 and see how I repair a drum switch.
Sawing since '94
Most all bandmill manuf.'s are small companys and just order off the shelf components.Some are fair with a reasonable mark up outhers will take a tuck on you.Some will leave the tags and numbers on the part,thats commendable.If a fella is making a liveing with his mill waiting for parts delivery is money lost.Be alert before you need something and scearch out sources or keep spares. Frank C.
drobertson
Quote from: Magicman on February 18, 2013, 10:45:25 PM
Will do, give me a few min. just finished my first cup, moving slow this morning,
CNB-48-S  CARTER  1-1/2"Cam Follower, Sealed  bout all I have on this, hope this helps, local bearing house,
Thanks, I do not have a local bearing house, but Google works.   :)
drobertson
Lynn, there is a difference of the bearing design, it looks like the wmz bearings uses a lil larger needle bearing than the Carter,  I will leave it at that, I'm not a PE, so I can only give my experience, it has been good,
millwright
You can go to any good bearing supply house with your dimensions and they should be able to match them.
Chuck White
Good one Bibby, I did that same repair just last Spring.  $$.$$ saved.
Quote from: Bibbyman on February 19, 2013, 01:39:55 AM
drobertson
Looking foward to the cam follower quick repair!
