Garden Tillers
Started by yardpro, December 17, 2013, 10:23:02 AM
yardpro
Hello,
I am thinking of buying myself a garden tiller for next year. I figure that I should start looking now so I end up with something that will last. Does anybody have any experience with tillers? Just want to get some opinions on brands, types, or anything else that may be helpful.
Thanks in advance
goose63
I have a60 inch tiller pto drive for the back of tractor and a rear tine to go in side the rolls the rear tine is a lot less work than a front tine :snowball:
goose
thank you to all the vets
Planman1954
I bought one at Lowes about 5 years ago for around $300.00. It worked well for me. I plan on getting another one soon and will go with the same type. The tiller was in front of the engine, and it would get after it! I plan on using it to level the hill around my pond so that I can plant grass for a level surface to fish (areas that I can't do with my 9n tractor.) It would do a nice sized garden in no time. It was similar to this:
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
BBTom
I am using a Troy-Built Horse that my brother purchased in the early 70's. He moved to town and I bought his tiller from him.  About 5 years ago I finally replaced the old 8 hp Tecumseh engine with a 5.5 hp honda.  The Honda has more power than the old worn down Tecumseh had.  I did replace the tiller drive gear once and it has used up two and a half sets of tines, but for the amount of use this tiller has gotten I feel like I have gotten my moneys worth and then some.  Close to 40 years on the same tiller makes the per year cost pretty cheap.  I can still get parts for it, too. It may still be running 40 years from now.
m wood
are you in an established garden patch only?  then a good front tine could work for ya.  If you plan on cutting any sod or virgin ground your gonna want a beefy tiller.  I have always recomended a rear tine with a minimum of 7hp.  I hate wrestling a front tine in a job thats too big for it.  But like bbtom said, his 5.5 honda powers right thru.  I DO like those bullet proof hondas.
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Those older Troy-Bilt's were excellent tillers. Then they started making them cheap, I suspect when the company was bought out IIRC. Then they existed under the good name of the original company.
dutchman
yardpro, where are you located?
what kind of soil?
Welcome to the Forestry Forum, yardpro.  I wonder about your forum name??
drobertson
It depends on the budget and size of garden, close quarters and limited budget make a front tine a good choice, a bigger garden with room makes a rear tine a good choice, they can get into the back pocket, but makes the chore a little easier.  This past spring a neighbor tilled me a new spot with a 5' rear tine pto driven, it made quick work of the sod,   david,
sawguy21
What others have said, it all depends on what you want to do with it. If you have a small developed plot a mini tiller such as a Mantis will do a fine job. A larger area with heavy soil will require a heavier unit, here a front tine with a five or six hp engine will do the job but be aware it is a bucking bronco and hard work in unbroken ground and soils such as clay.
If you have a large garden with room to turn around a rear tine will do a great job but are more expensive and require some caution. The reverse rotating units such as Snapper will really dig, great for breaking sod,  but will bury the wheels easily in soft soil making it a bear to get unstuck. The forward rotating models like the old Troy-bilt or BCS do a beautiful job but be sure there are no roots, the high speed tines hit one the operator will be pitched into the next county. Take it from one who knows. :D The ultimate is the Honda FR800 but there cannot be any debris in the garden to get caught in the counter rotating tines. Expensive breakage will occur. Most important, get a higher end used one rather than a new cheapo from a box store. Trust me on this, I make my living selling parts and dealing with service issues.
Philbert
Front tine tillers let you till right up to fences, walls, timbers, etc.  They store in less space if that is an issue.
Rear tine tillers are better for heavier work, new plots, etc.
Either one, learn to 'rock' them onto and off the tines to control depth and movement, instead of fighting them.
You can rent some and see what works, what you like, etc.
Philbert
OutdoorGuy
A lot of this depends on how big of a garden you have and what you plan on using the tiller for (weeding, breaking new ground, etc.). For weeding, a cultivator will probably work for you, while breaking new ground will require a larger, more powerful garden tiller. I found quite a bit of information at Tillers Direct. They had a pretty nice selection of garden tillers and buyer's guides, which you will probably find helpful.
Here is the link to their site: http://www.tillersdirect.com/
Woodcarver
We have a Honda front tine tiller that we bought in the late 70's.  Our garden now is a little less than half an acre.  It was larger when our three kids were still at home and we raised asparagus, strawberries and raspberries to sell.
We've replaced the tines once.  The drive to the tines is a chain that runs in oil.  We replaced the gasket on the cover when it began leaking oil about 10 years ago.  I've replaced the spark plug a few times.  Other than that we've done nothing to it.  It still starts on the first or second pull and runs well.
Just an old dog learning new tricks.......Woodcarver
I brought a Troy built about 13 years ago,the Horse Model. I think 8 hp. I have not done a thing to it,needs tines now. I have used it alot. But just in the spring and fall. One of those things that I don't reallty feel I have ever really got my money back on. It only gets used spring and fall. I mulch with newspaper and hay between the rows. I also have the Pony model. It's much smaller than the Horse and much eaiser to turn. I might use that between the rows this summer.
Quote from: Magicman on December 17, 2013, 09:18:05 PM
Interesting eh?
Quote from: Jeff on December 18, 2013, 10:18:56 PM
Interesting eh?
Yup, I usually look.  His first post two months ago was about chainsaws, and with a link.  ??
m wood
interresting?! and no return since his OP.
I am Mark
Norwood mark IV
4' peavy
6' peavy
stihl 034
check out FB
Quoteand no return since his OP.
...under that name....  ::)
He and OutdoorGuy have similar taste, because they both favor the same LINK seen in Reply #10.
I restored the missing post from our recycle bin that was deleted for spam. Got to thinking it was better to keep the topic intact as sort of a warning sign post to members and guests.
OK, that tied them closer together.   smiley_thumbsdown smiley_thumbsdown
Al_Smith
Quote from: Magicman on December 18, 2013, 10:36:15 PM
Enlighten me .Were they perhaps a type of chainsaw that resembled a very popular brand made in Sweden noted for quality and robustness per chance ?
