Dynamic Green Products Inc.
Author Topic: WM Grinder solution question  (Read 617 times)
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« on: December 23, 2013, 09:54:34 AM »
I have a grinder set up to grind my own blades on rainy days like today. I am out of the blue solution that WM sells and I won't be putting in an order for a while.
Is there any other additive I can buy locally to put in the water to help prevent rust on my blades and grinder machine?
Thanks for your advice.
Jim Rogers
Offline j-dland
Re: WM Grinder solution question
« Reply #1 on: December 23, 2013, 10:34:36 AM »
   I was told... The grinding solution is a kind of Water Soluable oil. Not sure about that spelling. A google search might help.
David
Offline Jim H
« Reply #2 on: December 23, 2013, 10:46:25 AM »
You could just spray it down with wd-40 after use. I actually used mine for for years with plain water, electrical problems finally killed it, not so much the rust. You should be fine skipping the solution for a few months.
2008 LT40HDG28, autoclutch, debarker, stihl 026, 046, ms460 bow, 066, JD 2350 4wd w/245 loader, sawing since '94 fulltime since '98
Offline pineywoods
« Reply #3 on: December 23, 2013, 10:49:11 AM »
water soluble cutting oil from any machine shop supply. In a pinch, borrow from your neighborhood machine shop...
Grinder Head Angles on a TECOMEC chain saw grinder--Same grinder as Oregon 511
Started by hydro2 on Chainsaws
Last post November 29, 2005, 01:15:23 PM
by rickk
CBN Grinder Question?
Started by Papa1stuff on General Board
Last post March 25, 2011, 11:44:45 AM
by Papa1stuff
Stump grinder question
Started by bmc2006 on Forestry and Logging
Last post June 22, 2015, 05:07:55 PM
by s grinder
Oregon 511AX Grinder Question
Started by spinner on Chainsaws
Last post November 09, 2013, 09:32:08 AM
by ladylake
