Tally-I/O
Author Topic: Check this mill out,,,,  (Read 1895 times)
Offline Danny_S
« on: May 30, 2004, 06:42:23 PM »
http://www.selectsawmill.com/index.htm
If'n you havent seen it allready..  I like it ... I like it alot.... :D
Plasma cutting at Craig Manufacturing
Offline D._Frederick
Re: Check this mill out,,,,
« Reply #1 on: May 30, 2004, 07:41:48 PM »
Danny,
What would you do about blade maintenance, those swage tooth saws are not cheap to keep sharp?
Offline Danny_S
« Reply #2 on: May 30, 2004, 07:49:18 PM »
Well when you win the lottery, blade maintenance is not a big issue..... now to win the lottery is!!  :D
Yea, they would carry a higher maintenance cost for sure, I just like the theory behind it and the mill itself is a nice looking machine.
Offline sawinmontana
  • Living in Gods country!
« Reply #3 on: May 30, 2004, 09:01:02 PM »
I just had a logging truck load sawed. The mill, about 40 miles from me, had a select sawmill. I was really impressed watching it. It sawed both directions. I went in the filing room and talked to the filer. With the right grinder and other tools It didn't look that complicated. Maybe not easy.  I liked the idea of getting 50 to 100 or more sharpenings out of a blade.
« Reply #4 on: May 31, 2004, 09:02:42 AM »
With a blade well over $200, metal is a real problem as is rocks in the bark. At the least, the logs should be washed and checked for metal.
Offline WV_hillbilly
  • Work can be shocking at times . Bellaire , OH
« Reply #5 on: May 31, 2004, 07:54:53 PM »
   What type of guides do they use on the blades ?  Cause if there is teeth on both sides of the blade how would they keep the blade on track .
Hillbilly
Offline EZ
  • Betya can't cut just one!
« Reply #6 on: June 01, 2004, 05:05:17 AM »
They dont use any guides. The tension on the blade keeps the blade in place, I think the tension is something like 5000 lbs. Seems kinda weird with no guides but with a 4 to 6 inch wide band it works good. I seen one of these mills at the state fair a few yrs ago,had 2 guys off bearing and they were really sweating to keep up.
EZ
Offline FeltzE
  • Fayetteville NC, Stop by and visit some time!
    • Feltz's Sawmill
« Reply #7 on: June 01, 2004, 07:41:24 AM »
I've looked at those sawmills, Nice!
If I was going to operate on an 8 hr shift basis I'd have one. But I would say they aren't economical for operating in a portable mode with residential timber sources. As the cost to maintain the blades would render the saw a financial deficit in tramp metal and dirty wood.
A friend of mine has a peterson swing blade, One set of nails renderd $50 in retipping in one pass. Replacement blades tallying in at over $200. It was an eye opener at how economical a 1 1/2 band is in comparison when replacing damaged blades!
Eric
Before Pulling Your Mill....Check and Re-Check!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 09, 2018, 01:44:17 AM
by Ianab
Check out this mill...
Started by Coon on Sawmills and Milling
Last post April 20, 2011, 02:17:52 AM
by backwoods sawyer
Check out this old mill 1925
Started by Kbeitz on Sawmills and Milling
Last post May 22, 2016, 01:26:37 PM
by GeneWengert-WoodDoc
check out these engines for my mill
Started by ozarkgem on Sawmills and Milling
Last post May 15, 2014, 08:07:11 PM
by ozarkgem
